Question about Dodge 2008 Dakota SLT
Need wiring diagram for stop lights and high 5th light
  • Dodge Master
  • 2,963 Answers
DIYer? I reommend repair manual from your auto parts store, or try filepeep.com or manualslib.com You may be able to find via google images search.
Posted on May 03, 2015
I need a color code for the brake light wiring diagram for a 2000 s10 blazer
The S10 and the Blazer are identified as two different vehicles. The left stop light wire is YEL; the right is DK GRN. The center high mount stop lamp wire is LT BLU.
Oct 30, 2016 | 2000 Chevrolet Blazer
2008 lincoln navigator shifter locked no brake lights is there a way to test the brake switch
Yes , with a volt meter . Find the switch an back probe wires ,testing for voltage in , then press the brake pedal an check for voltage on wire going out . You'll need a wiring diagram so you know which wire is the right one's . You can find free wiring diagrams at http://bbbind.com/free_tsb.html enter vehicle info . year make model an engine size .Under system click on lighting ,then under subsystem click on stop lamp . none of the brake lights work including the high mount stop lights ? A electronic module (smart junction box) controls the lower brake lights . The high mount are controlled directly from brake light switch .
Sep 25, 2016 | 2008 Lincoln Navigator 4x4
I have a 1994 Ford Explorer need to find out where the fuse box is to change out tail light fuse?
There is no fuse for the tail lights , Do the headlamps work ? Power for the tail lights comes from the headlamp switch ! Find yourself a wiring diagram an check the circuit ! You can find a wiring diagram here http://bbbind.com/free_tsb.html .Do you own a test light or a volt meter ? Do you know how to read a wiring diagram ? There are alot of videos on youtube on trouble shooting automotive electrical circuits , under standing wiring diagrams etc... Did they just stop working ? Do the stop an turn lamps work ?
Aug 18, 2016 | Ford Explorer Cars & Trucks
2005 chef Equinox brake light wiring diagram
http://bbbind.com/free_tsb.html free wiring diagrams !
Stop Lamps
The 15A BRAKE fuse located in the fuse block - underhood, supplies battery positive voltage to the normally open stop lamp switch. When the driver presses the brake pedal, the switch contacts close and battery positive voltage is supplied to both left and right stop lamp assemblies, the center high mounted stop lamp (CHMSL), the powertrain control module (PCM), and the throttle actuator control (TAC) module. The stop lamps are grounded at G401 and G403. The CHMSL is grounded at G301.
Jul 23, 2016 | 2005 Chevrolet Equinox LT
I have power in and out of rear stop light switch. No pwer in either wire going to the front stop light switch. any suggestions???
Hi Anonymous, check the tail light bulb they are famous for failing. Replace it with a high quality heavy duty automotive bulb. Please visit the website below for a free wiring diagram:
Harley Davidson Wiring Diagrams and Schematics
Good luck
Mar 24, 2014 | 2001 Harley Davidson FXDWG Dyna Wide Glide
Right low beam stopped working, where is the ground wire run to check that
Do the high beams work?
The ground point is on the apron ( the inside of the fender, just behind the headlight). There is one on each side. From the wiring diagram, there is just a splice connecting power to the lights in parallel for the high and low beams, but the grounds are separate.
If the RH high beam and the LH low beam works, then it is not a ground problem. You could just tap the LH wires to power the RH, but I think that if you look closely the connector for the bulb is probably melted. If that is the case then you will have to splice on a new connector.
The colors are as follows:
RH --> low beam power ( light blue)
LH --> low beam power (white OR light blue)
BOTH high beams --> ( red/white stripe)
Ground --> Black
Sorry, The diagram is too large a file to upload.
Jan 12, 2014 | 2000 Mazda Millenia
What colour wire is the stoplight feed that feeds the stop lights
I'm assuming you have a trailer towing package.
Below is the wiring diagram. It appears the dark blue is your stop lamp wire you may be looking for.
Let me know if anything is different.
Regards,
Apr 06, 2009 | 2007 Chevrolet Uplander LS Minivan
Stop lights are not working, But high stop light works fine
You can pick up a 97 Chev Silverado Haynes mechanics manual. It has all the electrical diagrams towards the back of the book. Canadian Tire has them you may be able to get one off of ebay maybe Amazon.
Jan 13, 2009 | 1997 Chevrolet Suburban
Dodge 2008 Dakota SLT Logo
370 people viewed this question
Top Dodge Computers & Internet Experts
Gene
D. E. Hev
Are you a Dodge Computer and Internet Expert? Answer questions, earn points and help others
