Question about Ovens
Error code FU 46 - Ovens
How do I clear an error code FO on my GE oven
it usually means the touch pad or the oven control is defective.
Dec 05, 2015 | GE Ovens
Electrolux oven error code f130.what to do?
Hey Luciano, I appreciate your inquiry!
From the information you have provided your Electrolux oven is displaying an error code of F130. I have researched possible error codes and it appears that this error code is invalid. I would recommend performing a reset on your oven and you can do that by unplugging the power cord for roughly ten minutes. If you restore power and continue to receive the error code can you please comment? I would be happy to assist you further. -Matt
Nov 29, 2015 | Electrolux Ovens
Is there a sight to find frigidaire built in oven error codes
Good Afternoon Friend, this is Z. I am happy to assist you!
I understand you are seeking a site that provides a listing of error codes on your Frigidaire oven. This information is very rare to find. Is your oven receiving an error code? If so, may I have the error code and with this information I'll be more than happy to help you narrow down the possibilities of the code. Thank you!
Aug 02, 2014 | Frigidaire Ovens
Electrolux oven error code f 136...what to do?
Hello - Could it possibly be error code F13 or F36? According to my research this manufacturer does not have an error code F136. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and see if the error code clears. If it proves to be ineffective, contact a professional to move forward accurately to properly diagnose the unit.
Nov 25, 2012 | Ovens
I keep getting a F6E5 error code on my Whirlpool stove. I have tried unplugging it (overnight) and the error won't go away. Any ideas before I call the repair man?
The error code F6E5 means "Cancel key error". Press the "Cancel" and "Start" keys in the following order: CANCEL, CANCEL, START. Verify the error code displayed on the control by observing for longer then 1 minute. If the error comes back then the control board needs to be replaced..
If this was helpful please rate me Thanks
Jun 12, 2011 | Whirlpool Ovens
Hi Our smeg oven model SNZ91MFX1 has stopped working, and the clock just says Fu 14. Any thoughts on what the fault message means?
did you find out what this meant? I have a smeg cooker which is saying the same and can't find any info about it. Many thanks.
Apr 27, 2011 | Smeg Ovens
What does F1 mean on the magic chef oven?
The f1 error means the something may be wrong with the touch pad on the oven
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Regards
Dont forget to rate this solution
Sep 26, 2008 | Ovens
Kebc207 oven error code E1 F2
This is information from the Tech Sheet.
Fault Code F2 - Error Code E1: Code Explanation: Keypad keytail not connected. Recommended Repair Procedure: 1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 seconds, replace keypad. 3. Replace control.
Jul 15, 2008 | KitchenAid KEBC207 Electric Double Oven
Dacor error codes
HI. the F-1 code is a System Watchdog Circuit failure code.
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Concerning the F-5 code. This is an oven temp sensor failure code. have it replaced asap. ((Check the wiring leading to and from the control and sensor for cracks and fouled structure. if the wiring is bad, replace the harness as well)),
Apr 25, 2008 | Dacor ECS127 Epicure Electric Single Oven
Ovens Logo
70 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
