Question about Whirlpool Dryers
Whirlpool dryer overhead I change termo fuse all the thermostat but is still overhead is cabrio steamer dryer
  • Whirlpool Master
  • 5,323 Answers
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Whirlpool dryer overhead I change termo fuse all t - 25677379-k4ataymuwmgrdb2rqqdy5pxt-5-0.jpg
25677379-k4ataymuwmgrdb2rqqdy5pxt-5-2.jpg Whirlpool dryer overhead I change termo fuse all t - 25677379-k4ataymuwmgrdb2rqqdy5pxt-5-5.jpgt/uploads/images/25677379-k4ataymuwmgrdb2rqqdy5pxt-5-5.jpg" alt="25677379Whirlpool dryer overhead I change termo fuse all t - 25677379-k4ataymuwmgrdb2rqqdy5pxt-5-9.jpg"h_mi" />
Posted on May 07, 2015
  • 864 Answers
SOURCE: NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor.  Check to see if heating element is OK.
Posted on May 29, 2009
SOURCE: whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
Posted on Oct 14, 2009
  • 4 Answers
SOURCE: Whirlpool Cabrio - How do I tell if my heating
If you are comfortable useing a volt meter and a ohm meter I can walk you throught the steps otherwise you need to call a repairman, If you are not getting any heat and the tumbler is turning it is possible the element is bad again only a test meter can tell for sure or you can take the dryer apart and look at the element to see if it is broken make sure the power is turned off at the breaker first also unplug the dryer.
Posted on Apr 17, 2010
  • 523 Answers
SOURCE: Whirlpool cabrio gas dryer does not turn gas on to
first change the ignightor if its a glow plug
Posted on Jul 01, 2010
heatman101
  • 43501 Answers
SOURCE: whirlpool cabrio wed6200sw0 dryer runs, won't heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jul 11, 2010
We need to take apart our Cabrio Platinum Dryer to get it down our stairs.
Whirlpool cabrio dryer repair - YouTube
? 5:22
https://www.youtube.com/watch?v=aIxL38nnOLU
Sep 22, 2012 - Uploaded by Michael Steiger
Whirlpool kenmore safety fuse dryer not lighting GE Maytag. ...Dryer Troubleshooting - Not Drying or Taking ...
How to disassemble a Whirlpool Cabrio dryer
washerdryerrepairhelp.com > Dryers > Whirlpool > Whirlpool Cabrio
Jun 9, 2012 - How to disassemble a Whirlpool Cabrio dryer. Dryers ... If you need to take the drum out, there's a panel that holds it into place similar to the Maytag Neptune design. ... we respect your privacy and take protecting it seriously ...
How To Take Apart a Whirlpool Dryer ' Appliance Aid
Dec 21, 2015 | Whirlpool Dryers
My Cabrio dryer is getting super hot in all dry modes. I have had to replace the thermal fuse. Obviously there is another issue causing this problem. Any ideas?
Melissa,
You probably have a thermostat that has locked in the closed position that is allowing it to continue to heat. I would suggest replacing the high limit and the cycling thermostat. Might not be a bad idea since you would be in there to just replace all of the thermostats, most dryers have three or four.
Jul 01, 2015 | Whirlpool Dryers
Whirlpool cabrio dryer not heating
need to put a multimeter on ur thermal shut off fuse ur heating element and ur thermostats, u can buy inexpensive multimeters that will work just fine..
Jul 26, 2014 | Whirlpool WTW6400SW Cabrio Washer
My starter botton won't work on my cabrio dryer
u need to ometer test the push start button , the thermo fuses and thermostats, of course u have already checked the electrical plug for power? test also to see if it is getting 220 at the cuicut and back of applaince
Apr 27, 2014 | Whirlpool Cabrio WED6400SW Electric Dryer
Changed top thermostat 11060832990 and now pops breaker
Sounds like incorrect wiring, like you have a "hot" wire going to the chassis somewhere. I'd double/triple check the connections. If you only pulled off the 2 thermostat wires, and reconnected them directly back, then it's unlikely that's the problem, but if you disconnected the thermal fuse or other connectors along the way, it sounds like something is hooked back up wrong. Good luck!
Dec 04, 2013 | Kenmore Dryers
Whirlpool electric cabrio dryer no power
change relay board top board under lid upside down left side of dryer
Nov 30, 2013 | Dryers
Whirlpool Cabrio Dryer Wont go past sensing light when I press start. The door is tightly closed and the filter is clean. It just won't even try to start it just just beeps once.
my dryer sensing light was on and dryer would not start, we replaced the sensor fuse and now it works the fuse is in back of dryer close to the bottom on the left hand side very easy to replace cost $11.00 by the way don't call whirlpool they have no clue, wanted to send repair man out to fix it.
Nov 04, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
The heat on our 2 year old Cabrio dryer just stopped working for no apparent reason. Everything but the heat appears to be functioning normally. Help!
Thermostat controls heat. There is also a motor centrifugal switch, in the element circuit, that the motor closes to insure the motor is turning. Try another heat setting. There is more than one thermostat. You may have blown the 'thermal fuse' too, which requires replacement.
It is possible that your element has failed also.
Tripped high limit. Must clean the lint filter and the exhaust vent tube and all the way in to the dryer. Hot air exit is restricted.
Jul 18, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Open Questions:
Dryers Logo
128 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
