Question about JBL Audio Players & Recorders
I need the battery cover for the jbl on stage 4 I was wondering if u sold it if so How much
  • 2,963 Answers
Try mfg website, or eBay.
Posted on May 03, 2015
2 Suggested Answers
  • 3 Answers
SOURCE: When plugged in, the ipod batteries go low immediately.
The JBL On Stage Micro is supposed to disable recharging of the iPod when running off AAA batteries to avoid draining them, but sometimes this setting gets stuck even when the unit is plugged in through the AC adapter. The workaround that I found is pulling out and reconnecting the iPod to the Onstage Micro (while both are powered on) and then unplugging and reconnecting the AC adapter. Sometimes you have to repeat this process, but the iPod should start recharging after that. I tried this on different versions of the iPod nano and this seems to work.
Posted on Sep 26, 2009
Prx615m not turn on
Mosfet, FQP27P06/FQP30N60 got fried in the power output stage, this is a common issue with JBL powered by Crown speakers, let me know more to help a bit more also.
Apr 22, 2013 | JBL Bags PRX615M-CVR Cover Speaker
No more subs in jbl prx-512m
First check the speaker with a multimeter.
If it is OK, then check/repair the Class D amp that drives the speaker,
up to the input stage.
There are board part numbers printed on the PCB and some are
available on line.
Have a tech to guide you ,should you feel to Diy.
Oct 17, 2012 | JBL New Jbl Prx512m 12 Powered Monitor...
Hello I have a JBL on stage 2 that I bought in the
Congratulations. You are among the first to approach us after having done a lot of the research up front instead of considering us a proxy Search Engine secretary.
I'm going with OS200ID as the unit's model number.
The DC input and physical fit are the only considerations for the dock's power - 12V/1.25A.
Item 190555626796 IS indeed a universal voltage (100-240 vac) sourced supply. The seller, DIGIDAVE, http://www.digidave.co.uk/help invites queries, too.
I'd say this is exactly what you need to use the the OS anywhere on the planet with a plug adapter.
Jul 18, 2011 | JBL On Stage Speaker Dock for Apple iPod...
Hi I want to open the case of my JBL on Tour, but I dont know how to. I need to troubleshoot inside to fix this sound problem. Kindly help me.. Nikka
Its pretty late for your post....but today i repaired my jbl on tour...
there are 7 screws to be removed. 2 on thre front upper side, remove the battery cover an you find the first two. then remove the jbl sign, theres another under it. its very hard to remove, i had to destroy my jbl sign. now you have to clip out the cover when you have slided it back, under the back side who was covered, are the last 4 screws. now the nasty part is coming: you cant open it, cause its glued all around. put at first a knife into the slot betwen the upper cover & the under cover, move it around the jbl on tour, but watch out that you damage no electronic parts, or cut off the battery cabel (as i did ;) ) and now you can open the device. my jbl looks really bad after, but it works fine (had issues with the current cable)
Feb 28, 2011 | JBL On Tour Computer Speakers
How can i open the "jbl on stage 400p" for
We just discovered how to break openthis mother. Use a flathead to gently lift the wraparound speaker cover from the lip, and gently work your way around the speaker. Underneath it you'll find a crapload of screws. Then go to town.
Jan 12, 2011 | Harman Kardon JBL On Stage 400P Speaker...
Apr 16, 2009 | JBL On Stage Micro Portable Speaker Dock...
Nano not compatible with On Stage
It will actually work, however, you will not be able to dock the iPod® Nano into the JBL On Stage™. You can connect the audio in cable to the headphone jack of your iPod. That's the only way, hope this helps. Pls rate solution. Thanks!!
Jun 12, 2008 | JBL On Stage Micro Speaker Dock for Apple...
90 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
