The water isn't coming out? It's on but what do I do?
    Top Expert:
  • Washing Mach... Master
  • 43,030 Answers
Like not filling or not draining some things would be easier if we saw it but alas we can not .
Posted on May 03, 2015
Cooling Fan Not Working
if the fan is electric, the problem is probably the fan thermostat. usually fitted into the water pipes near the radiator.
May 06, 2013 | 1996 Ford Escort 4 Door
Water isn't coming out how do I fix that
Hey, sorry you're having difficulty. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1065&cid=ccsocial
Feb 06, 2013 | Bissell 1697-7 Powersteamer Pro Deluxe...
White smoke coming from back of engine it is not water or oil problem
It sounds very much like you have a head gasket blown, or a cracked cylinder. You say it isn't water, yet you have to keep topping up the radiator. So basically, it IS water.
Nov 15, 2012 | 1999 Oldsmobile Silhouette
My washer has gone through the cycle and the door will not unlock. Please help.
TYpically the door wont unlock due to not all the water draining from the tub so the water level switch isn't satisfied the water has drained and wont allow the door to unlock.
The most likely problem is that the drain pump screen is clogged so its not draining and if it isn't draining it wont spin.
To check the pump remove the lower panel and the lower right side will be the pump, unscrew the big white cap a little and use towel(s) to catch the water that comes out ,when all water out remove completly and check for blockage.
GENE
Aug 28, 2011 | Kenmore HE2 Plus Front Load Washer
Water does not come through the water pump at the bottom of the refrg
If water is getting to the water valve then either the valve is not getting power from the dispenser and ice maker or the valve isn't working and needs to be replaced.
Aug 26, 2011 | Microwave Ovens
I have water coming out of the base of the unit in my garage. it almost seems like condensation to me. it isn't like gallons, it's more like the condensation isn't going out the drain tube.
Check your drain tube it is probably stopped up. If you can take it loose from the unit, try to shoot water through it with a sprayer on your hose. It should clear what ever is in it.
Jul 13, 2011 | Heating & Cooling
When I start my dishwasher the check water light keeps comming on. Also the salt light so the machine does not go through its cycle. Can you please advise me the best course of...
Hi, if your unit is getting good water pressure then the problem is going to be your flow meter which is the device that measures how much water is coming into the unit. If it doesn't detect enough water coming into the unit, the dishwasher will hault and give you check water light error. When the error comes up look at the water in the bottom and see if you have enough water in the bottom for a cycle. If not then your flow meter is fine and your unit truely isn't getting enough water which means that either your house isn't giving good water pressure to the dishwasher, or the electronic water valve that connects to the water line from your house is bad and needs to be replaced....
Jun 21, 2011 | Bosch 18 in. SRS56L08 Logixx Slim-Line...
My dishwasher isn`t filling with water the elements are getting hot but no water is getting through any ideas on fixing this problem?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 08, 2010 | Dishwashers
Kenmore top freezer/frig has water coming out underneath applianc
THE HOSE THAT COMES FROM THE FREEZER TO THE TRAY EITHER ISN,T LOCATED IN THE RIGHT POSITION OR IS DETACHED WHERE IT COMES OUT THROUGH THE WALL
Aug 11, 2009 | Refrigerators
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
