How to reset this model after putting new batteries
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
Gloria, some where on the front of the thermostat there may be a tiny hole about the size of a toothpick. If so, usually under that hole is a microswitch on the thermostat circuit board that resets the T-stat back to the factory defaults.
Posted on May 30, 2015
How do I reset flash?
Google your flash gun make and model. Look for a review. It may explain how to.
Sep 22, 2015 | Cameras
Model sc50 has new batteries. horn works, bat condition indicator works. no LED light and unit will not drive. have reset and checked drive lever is in drive. what to look for now?
hi take the key out put lever in free wheel then put lever in drive put key back ..if the circuit is similar as the pride xl it should work ....good luck
Sep 25, 2014 | Pride Health & Beauty
Is there a reset button on a Merit Pioneer 10 scooter
You had better recheck your connections because the batteries are polarity reversed
Mar 20, 2017 | Cars & Trucks
Reset code on hilka safe model no 97002500
I have put new battreys in can not open it how do i reset the code as i do not have the key
Jun 01, 2012 | Cell Phones
I forgot my gateway model ML6230 bios password, i need a new password for it (reset the password).
A method you can try if you don't have a password reset software is by removing the CMOS battery. Remove the CMOS battery then turn the computer on. The system BIOS will be reset and password will be removed. Then you can put the battery back in. Click on this link for the Gateway ML6230 Notebook PC Manual. Check page 36 for CMOS battery removal instructions.
http://support.gateway.com/s/Mobile/Q106/Oasis/8511725_Service.pdf
Mar 21, 2011 | Gateway ML6230 Notebook
The outside temp sender won't work. We put new batteries in it, but it does not send a signal. It will not put an outside temp on the clock.
Simple, the instructions state that when changing the batteries on the outside temp. sensor, you must also change the batteries on the main clock unit. I had same problem when I changed the sensor batteries until I pulled the batteries from the clock and it reset fine. ( Sensor batteries first, then clock batteries. ) The clock will reset to atomic time overnight so don't worry if it doesn't read correctly at first.
Aug 18, 2009 | SkyScan 86709 Atomic Wall Clock
BC300 model odometer registers twice the mileage ridden after putting a new battery
I don't have this model but understand many odometers, like mine, reset the wheel size to wrong setting when battery replaced. Go to setup screen to reset to correct value. Setup screens normally appear if buttons held for about 2 seconds or more. Some models require millimeters and some centimeters. If you don't have a figure for your tyre measure the distance on the ground for one complete revolution of the wheel.
Aug 17, 2009 | Sigma Cycling
I put new batteries in and it still won't turn on
Try resetting the battery, following these directions. They are for an R837. If these don't work for you, try going to the HP website and doing a search for your particular model and checking the FAQ section.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00863607&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3319439〈=en
Apr 18, 2009 | HP Photosmart E217 Digital Camera
1994 jeep
I have the same model.you must do this .put key in door turn it left and right 3 times .then when you get in put key in ignition turn it 3 times left and right .now start your nice running jeep.thanks Ed
Feb 28, 2009 | 1994 Jeep Grand Cherokee
Logitech Wireless Keyboard not resetting evidently after installing new batts.
First make sure the batteries are put in with correct polarity. Although obvious, its surprising how many people make this mistake. (Happened to me too once :)
I am not sure what model you have, so please try the following:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=7652
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=3818
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 29, 2008 | Computers & Internet
Heating & Cooling Logo
453 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
