Question about Panasonic 42 Class 720p Plasma TV TC-P42X5
I was watching TV it shut off and the power button flashed a bunch. I unplugged it waited for a while plugged it back in. It did not turn back on until i held down the menu button on the set.
Turned on for 10 minutes then turned off again power button flashed 12 times. I have unplugged it. the forums say its the sound board but the tear down videos and parts places don't have a sound board for this model. Any help on what the issue is or where the sound board is would be appreciated so i can decide if it is worth fixing. thanks
  • tom cassidy
    tom cassidy May 03, 2015
    unplug short out live and neulral on plug with screw driver
    Genius:
  • Panasonic Master
  • 1,585 Answers
Try jimmys.com
Posted on May 03, 2015
4 Suggested Answers
  • 10 Answers
SOURCE: Power issues: will not turn off or function
Unplug all of the speakers and power on.Its possible that one of the speakers is causing the protection circuit to activate.If powered on and subwoofer works start reconnecting one speaker at a time( after powered off) and retest each time.One Speaker may be bad.Its also possible the output ic is failing under a speaker load.There are no fuses related to this issue.If its not a speaker problem then the subwoofer will need to be serviced.
Posted on Apr 05, 2008
  • 223 Answers
SOURCE: The unit SC_HT67 don't turn on
It sounds like a faulty voltage regulator or diode on the power supply of the stereo. If you can check these things yourself also check for dry joints before checking diodes and regulator/s. If not trust a competant techmnician. Good luck.
Posted on Sep 28, 2008
jdvillanueva
  • 2098 Answers
SOURCE: When i turn on my Panasonic stereo set model
Hi denty56,
F61 is an error code for short and or overload. This will appear once the processor sense a malfunction either on the power supply or on the load (high chance is the output IC). DIY steps are as follow to determine where the fault is : 1. Allow the unit to cool down for an hour. Give proper ventilation and keep away all obstruction from the vent to have a sufficient air flow. 2. Disconnect one at a time the speakers, inputs, from the unit while powering it on.
If the unit back to normal again then you've confirmed that any of the above caused the error code. If #1 is the caused, you have to check also the exhaust fan, clean it as much as possible, replaced if faulty. If #2 is the caused (speaker) check the wire and speakers for short, (input) check the RCA cord for short or replaced if necessary.
If the above simple fix didn't cure the error code, you can try the next steps if you are an electronicsenthusiast. Now after removing the cover, you have to concentrate first on the power supply board. Look for bulged electrolytic capacitor. Leaky capacitor will affect the regulation of the supply and will trigger the error code. Look for dry joints. Check it also in the pre-amplifier stage, main output board where a big heat sink is located. Next disable the output amplifier stage by disconnecting the supply. If the unit come out, make some re-soldering on the board, spot the cold solder and dry joints and then try to connect again. If the error code appear again, high chance that your output IC is faulty but still to be confirmed. Using the disoldering pump and soldering iron pull-out the output IC from the board then try the unit. If the error code disappear, confirmed that your IC is faulty.After trying the abovesteps-by-steps guide and still the symptoms persist this is the time for you to send it to repair shop. Remember that your unit has a lot of parts and only some basic steps have done, leave the expert to troubleshoot the entire unit.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Feb 26, 2011
I found the following blog on the web.
Panasonic Viera Plasma Failure Page
November 14, 2010 ·
Blink Codes and what they mean (8-13):
8 blinks Driver SOS 3 SS Board (SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG BoardDTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Boardwith IC8001
Make sure the inside of the TV is clear of DUST especially by the power supply and fins.
May 02, 2015 | Panasonic Viera Tc-p42x5 42" Inch Flat...
Power problem with Zenith D56W25 56 in. Rear Projection Televisi
you can try to shut the tv off ,unplug the power to tv and anything that is powering the tv[pvr] .now plug in the power to the box first wait,30 seconds or so ,now plug in the tv wait,now turn the t.v. on,WAIT unless it starts smoking just wait.see what happens.
Apr 18, 2010 | Zenith D56W25 56" Rear Projection...
My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
Apr 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
I have a Sharp 32 inch 720p tv, power works, no other buttons do
Unplug TV set from the outlet, wait 30 seconds, plug it back in, select right input with your remote if you using cable box or Punch the channel that you want to watch if you have cable service connected directly to the TV.
Nov 05, 2009 | Sharp LC-32SB23U 32 in. LCD TV
Tv shut off, and wont turn on. It flashes when you press the power button. NO clue at what is wrong.
is the tv on a power strip? unplug the tv from the power strip or wall outlet wait one minute then plug back into the wall outlet and not a power strip. TV should power back on.
Oct 12, 2009 | Sabre LCT371BKA LCD TV
Sharp 46 aquos model LC46E77UN tv turned off power button just flashes on and off tried unplugging and waited an hour and replugged same conclusion power light just flashes
Unplug it hold down the Channel Down button and the Volume Up button unplug it for 10 seconds then plug it back in and continue holding them down for another 10 seconds then release. I had the same issue and this fixed it now I have another though *~*
Oct 01, 2009 | Sharp Televison & Video
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
Mar 18, 2008 | Televison & Video
Lcd sharp tv flashing green light
Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
Jan 06, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
the flashing light often shows malfunction ,check the wire connection of your devices something must be wrong .the surge protector you have is for overpower or low voltage too?Ask your neigbours if they have shame problems
Nov 18, 2007 | Hitachi 46F510 46" Projection HDTV
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Jul 18, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Panasonic 42 Class 720p Plasma TV TC-P42X5 Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
