Question about Hamilton Beach Coffee Makers & Espresso Machines
Why am i getting an error when I try to brew on the single serve side of my Hamilton Beach flexbrew?
This started to happen after I brewed coffee on the pot side.
Check your water level if there is to much water you will get an error message. Try removing some water and try single serve again.
Posted on Sep 02, 2015
  • 60 Answers
SOURCE: Brew Station Deluxe Model 47454
This isn't a calcium issue. It's the product. I'm on my 5th machine. I love the coffeemaker, but every 8-10 months this problem occurs. Contact Hamiltonbeach and give them your product number. Since it's obviously a recurring problem they'll replace your unit...no questions asked.
Posted on Jan 28, 2008
SOURCE: hamilton beach coffee maker Model 49464
Leave the carafe off the hot plate and place the basket in holder with the lip under hinged flange so it sits flat. Then replace the carafe and the basket should not move up when the Pause and Serve button opens. I just bought this pot too and
love it but except for the basket placement problem.
Posted on Apr 05, 2008
  • 3 Answers
SOURCE: I have a Hamilton Beach
http://forumappliances.com/images/Hamilton%20Beach/Hamilton%20Beach%20Parts/Hamilton%20Beach%20P-990021600.jpg
IF BY BOTTOM YOU MEAN BOTTOM OF THE POT, YOU'LL LIKELY NEED A REPLACEMENT POT (CALLED A TANK). REPLACEMNT PARTS YOU NEED ARE NO WHERE TO BE FOUND BY ME AND I HAVE LOOKED FOR HOURS.
Might want to call to assure this will work in your model Brewstation.
This vendor is in canada. $9 CDN is cheap enough.
Posted on May 16, 2008
  • 68 Answers
SOURCE: Hamilton Beach 40540 Brew Station 40-Cup Coffee Urn, Silver
Try to see your manual.
Posted on May 18, 2009
SOURCE: hamilton beach brew station spring problem
The spring goes at the top of the stem, under the filter basket. This keeps tension on the basket, so it will pop up when you remove the cover.
Posted on Feb 01, 2010
It will not make coffee in either the Keurig pods or regular ground coffee. It says PURGE, or NEEDLE after I clean it and use paper clip to remove grounds. What else can I do?
Customer Reviews: Hamilton Beach 49995 FlexBrew Single ...
www.amazon.com/Hamilton-Beach...FlexBrew.../B00...
Amazon.com, Inc.All in all, the Hamilton Beach FlexBrew Single-Serve Coffeemaker is an ... exhibit the same exact problems using the K-Cups recommended by Hamilton Beach.
Hamilton Beach FlexBrew Troubleshooting Common ...
? 3:39
https://www.youtube.com/watch?v=yA2dlGKUBKM
Sep 7, 2015 - Uploaded by Ronald Kretz
Hamilton Beach FlexBrew Troubleshooting Common Problemmust see if you ... Hamilton Beach Single ...
Customer Reviews: Hamilton Beach FlexBrew Single-Serve ...
https://www.walmart.com/reviews/product/21130276
WalmartProblem the model I purchased was the only one they made that uses K Cup. ... MyHamilton Beach FlexBrew Single-Serve Coffeemaker was truly a wonderful ...
FlexBrew® Single-Serve Coffee Maker (49995R) - Hamilton ...
https://www.hamiltonbeach.com/all-coffee-maker...
Hamilton Beach BrandsThe FlexBrew® Single-Serve Coffeemaker allows the flexibility of brewing freshly ...Not sure how much coffee grinds to add when brewing your next cup? ... and thenrunning 2-3 cycles of cold tap water before making the next round of coffee. ... 2016Hamilton Beach Brands, Inc. Trademarks by Hamilton Beach Brands, Inc.
Hamilton Beach FlexBrew 49995 - Consumer Reports Online
Jan 05, 2016 | Hamilton Beach 49995 FlexBrew Single Serve...
I always have coffee grounds in my coffee when I brew a K-cup. Why is that, and how do I make it stop?
The K-cup must be getting pierced on the top, where it lets the coffee grounds out into the cup during the brewing process. This usually means the K-cup isn't seated properly in the basket.
Apr 09, 2015 | Hamilton Beach 49995 FlexBrew Single Serve...
Pressing on button - light flashes - when released turns off - does not brew
Probably bad switch or conections to heating element. Or could be a thermal safty switch has "opened" and will not reset. How old is the machine? A lightly used one may be less than repair postage etc. Or if it is still under warranty use that route.
Mar 09, 2015 | Hamilton Beach FlexBrew Single-Serve...
Single cup side of hamilton beach flex brew does not release water into the cup
The upper tube is plugged and needs to be unplugged. Look at the manual for instructions on cleaning the system.
Mar 24, 2014 | Coffee Makers & Espresso Machines
Keep getting an err message when I use k cup side. Doesn't brew
I have a hamilton beach brewer N k cup when i do k cup it say err what do I need to do.
Dec 24, 2013 | Hamilton Beach FlexBrew 49995R
Set the timer to start brewing, i have always done this with no problem till now
Could be the brewing mechanism or the timer. However, if you get the action you describe on BREW NOW, I am inclined to think the brewer has failed.
Nov 10, 2013 | Mr. Coffee 072179228578 12 Cup Coffee...
Hamilton beach brewstation will not brew
Can you define will not brew? Do you mean no water transfers from the holding tank to the brew carafe? Does coffee not heat up?
Apr 11, 2013 | Hamilton Beach BrewStation 47665
Coffee Makers & Espresso Machines Logo
1,290 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
