Question about Samsung Washing Machines
My WA456DRHDWR/AA Samsung Washing machine is making a grinding sound, like a belt is messed up. How do I diagnose the problem with no error codes?
    Top Expert:
  • Samsung Master
  • 43,059 Answers
Open it up and watch while running .washers do not normally have belts would bet the bearings are going the trip
Posted on May 03, 2015
  • Anonymous May 03, 2015
    You really want a DIY novice to run the machine open?
  • ray gallant May 03, 2015
    what ever you think is only your opinion .
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Error code BE1 comes up at spin time & it stops. Common cause?
    8e1 Front mems sensor error locates on main board check at main board fir loose harness. Probably a bad sensor or harness get both the sensor itself is under too near front right
    Apr 09, 2016 | Samsung WA456DRHDWR: 4.5 cu. ft. King-Size...
    Have a samsung washer model WA17XAR showing OE code and makes grinding sound and does not start
    Hi this is a link to a short youtube video showing error code 0E, This washing starts and stops as well and the guy fixes it.....CHEERS..
    https://www.youtube.com/watch?v=YOvFYcaLp8w
    Mar 18, 2016 | Samsung Washing Machines
    My drum has come loose from the bottom where the agitor is how do I get it apart so I can center it again?
    I would guess that the bearing is loose or bad.If you lay it on its side you should be able to see whats wrong
    Oct 05, 2014 | Samsung High-efficiency Top Load Washer...
    I have a Samsung WA456DRHDWR. The drain pump went bad. I wasn't around so I don't know what happen but when I found it the pump had busted out of its' plastic mounting bracket and the 2 wires were dis
    2 possible problems:
    1. there is a tiny switch in the lower metal base of the machine hit it it might be stuck.
    2. you have a problem with an electronic component in the main pcb called triac. this part is acting as a switch you need an electronic repairer to change it
    Mar 24, 2014 | Samsung WA456DRHDWR 4.5 cu. ft....
    Washing machine was transported, ever since the motor makes a very loud noise
    If it sounds like a grinding noise you may have bent something that is rubbing the pulley.  check under the machine and look for anything comming in contact with the pully of the belt tensioner if it has one
    Good luck
    May 30, 2008 | Samsung Washing Machines
    Washing Machines Logo
    85 people viewed this question
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    shaun taylor
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
