Question about Coleman Electrical Supplies
I have an old coleman powermate 6560 . Its missing the spark plug (which got thrown away) and i can't find ANYTHING on what spark plug to use in this generator.model number is PM0645250
    Sergeant:
  • 415 Answers
The J8 spark plug is typically used on almost all small motors. You can google J8 cross reference for a list of alternatives that will work.
Posted on May 04, 2015
    Top Expert:
  • Coleman Master
  • 44,312 Answers
Contact coleman they should know
Posted on May 03, 2015
  • 13 Answers
SOURCE: Powermate PM0535000-01 Manual
powermate went out of business , but this might help let me know http://www.powermate.com/contact.php
Posted on Sep 27, 2008
protek480
  • 1714 Answers
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
Posted on Aug 01, 2009
sal_kh_sab
  • 98 Answers
SOURCE: Coleman Powermate on/off switch broke off. Is a DIY out of the ?
there is a wire in the back of the control pad...right behind the on\off switch...once it touches the naked body of the gen. it will shut off..
Posted on Oct 11, 2009
SOURCE: coleman powermate 6560 generator won't stay running
coleman powermate 6560 that runs good but wont gennerate power, i tried to exite it by plugging a drill in & holding the trigger in & turnning it backwards but still no power any suggestions?
Posted on Feb 06, 2010
  • 905 Answers
SOURCE: I have a Coleman Powermate 5500 Generator. It is
This engine was not built with quiet in mind, it was built to be cheap. upgrading the exhaust is your best bet and likely the cheapest. Talk to a small engine shop about the possibility of using a muffler from an ATV.
Super Trap makes a fantastic muffler, if it will fit your application (most do). A link has been provided at the end. When you are looking at the various options, you will notice that a rating in db units. Reducing noise by 3db is half the original noise level.
if you can, go with the SuperTrapp. If still noisy (probably won't be), then add on the resonator as well. Downside to using aftermarket is that you will have an exhaust stack / system that sticks out the side of the generator. Upside is that you will be able to think quietly about how much the exhaust sticks out.
And no, I don't have any connection with Jack's, they are just the first hit that came up. Now that you know that something is available, you can do more research on it.
http://www.jackssmallengines.com/Quietmuf_index.html
Posted on Jun 12, 2010
What spark plug does a Coleman Powermate 6875 use
Doesn't seem to be anything online. Phone them and ask.
Specs are here
http://salestores.com/colema21.html
Generator manual with phone number
http://www.powermate.com/generators/0062929_0706.pdf
Oct 05, 2016 | Coleman Electrical Supplies
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
What is the Coleman Powermate 5000W Generator spark plug gap
Powermate 435001 w Subaru EX30 spark plug gap is between ..006 - .007 according to manual.
Sep 22, 2012 | Coleman Powermate Subaru 5000W Portable...
No spark replaced coil no spark does the low oil have anything to do with no spark oil is up to full line
We use growler to test the coil off the engine. To make sure that other components are not the problem, remove any other wires connected to the coil. Always use a new spark plug for testing. Once you have solved the problem, remove the new plug and put it away for spare. If spark with other wires removed suspect faulty oil sending unit or short in wiring or faulty kill switch (test old coil also). Do not replace sending unit however, just check oil before every use. Good luck
Sep 17, 2011 | Coleman Powermate Powermate 5000W...
Sep 29, 2009 | Coleman Powermate Powermate 5000W...
Need a Manual Coleman PM 6560 & side plate. wHERE TO FIND?
Hi wolfin13,
From
Generators / Presure Washers / Home Standby: Customer Service: 1-888-977-2622 Technical Service: 1-800-445-1805 Email: generatorservices@powermate.com
As part of my research, came across this entry from another FixYa expert with some additional info.
http://www.fixya.com/support/t1008210-coleman_powermate_6250_generator
I hope this gets you what you need. If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Jan 03, 2009 | Coleman Powermate Premium Plus 6250W...
Hi wolfin13,
From my response to your earlier message: If you haven't already done so, check out
Sounds like Coleman is having issues, if you know what I mean.
Ihope this gets you what you need. If I can be of further assistance,let me know. If this solves the issue, please rate it accordingly.
Jon
Coleman powermate 6560 generator won't stay running
Aug 17, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
133 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
