Where can I get parts for my old mid 1980s Sears 1/6 HP utility pump model 563.2693? Sears no longer has major Parts. Thank you
    Sergeant:
  • 258 Answers
Ebay
Posted on May 02, 2015
5 Suggested Answers
  • 9 Answers
SOURCE: Have a 15 years old KitchenAid Surcare two speed 1/2 hp motor washing machine. part # 3361989 Machine is still working Would however I would like to know what kind of maintenance it needs and how to g
This machine needs no routine maintenance. If it's lasted 15 years, then you have treated it well, not overloading it with too many clothes and putting a strain on it. The tub rusting out may be your biggest worry. The schematic for the electric wiring, the diagram for the machine layout and the tub will be in the owner's manual.
Posted on May 14, 2009
beltronic205
  • 1456 Answers
SOURCE: water leaking from bottom Sears Model
1st you need to find out where leak is..Is i t just a hose ? or major like hole in drum/ if hole in drum forget repair...
Posted on Nov 16, 2009
  • 1937 Answers
SOURCE: May I Get a drawing of gerscase parts for an old Washing Machine
This assumes that you have a basic top load, direct drive washer.
Following age the Whirlpool / Kenmore Service and parts manuals. (PDF's)
WHIRLPOOL PARTS SITE (Manual for commercial washers but consumer models use the same transmission)
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Posted on Jan 02, 2010
  • 1937 Answers
SOURCE: Sears Kenmore automatic washer model# 110.82872120
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=+110.82872120&pathTaken=partSearch
Also see the Whirlpool / Kenmore Service Manual for these washers:
If it will neither drain NOR spin, the problem points to the Lid Switch.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If it WILL spin but simply won't drain, the problem points to the pump or hoses. The motor directly drives the pump when in spin mode.
I'd pull the cabinet and check the hoses for blockage, and check the pump to make sure it turns and isn't blocked inside.
Posted on Apr 19, 2010
I have a Craftsman 1 hp 12 gallon oil lubricated air compressor with a bad motor/pump. Sears Parts Direct no longer carries the motor. I need the part number of the motor to begin a search for a...
i don't think you need an exact replacement. I think you can go to Harbor Freight and get a 1 hp electric motor with the same shaft size and use the pulley off the old motor. You may have to make a few modifications to mount it but it should work ok as long as the RPM of motors are the same.
Jan 01, 2014 | managemylife.com
Craftsman 2.5 HP edger 536.797512
You need to have the carburetor cleaned out carefully. Do not lose any parts and put them all back the same way.
May 16, 2013 | Craftsman Garden
Jonsered Parts Model 361 & Model E61 Where can I find?
The 361 was a badged engineered machine, it was manufactured by TML in Canada, they produced machines for many other manufacturers, Danarm, Frontier, to name a few, it is an old machine from the mid 1980s, there are no parts available from Jonsered, but try the web for these other makes, Husqvarna had a machine much the same from them the Husky 35, and the Husky 37, try the web for these models.
Good luck
Feb 08, 2011 | Garden
We have a rototiller, craftsman, bought new at sears several years ago. Model No. 944627591, Craftsman 9 HP, 21 inch tine width, rear tine tiller with counter rotting tines. Pinion input gear is sheared...
The model ID starting in 944 indicates your tiller was manufactured by Husqvarna. This division has since been purchased by AYP. A quick online search finds that www.needlawnmowerparts.com lists having one for $55 plus shipping. I have not dealt with this company, so I can't recommend or not recommend them.
It is very common for tiller makers to not offer internal transmission parts. Transmissions are difficult at best to repair and reassemble. Used tillers are available from time to time, check your local classified ads or www.craigslist.com to find one. If you decide to go with a new tiller, i would recommend trying www.northerntools.com or www.mytsc.com to start your search.
As far as longevity on the new transmission, Sears won't guarantee any of their parts longer than 1 year. However, you should expect a replacement part to last as long as the first one did.
Sears doesn't give year models for their equipment, but usually supports replacement parts for at least 10 years. Most equipment manufacturers don't build their units to last longer than 10 years....they want you to buy another one.
I hopethis has helped.
Jan 04, 2011 | Garden
I have a Kenmore 110. (full number is 110-82984810) It has a "ratchet/screw" type agitator. The big fins on the bottom part agitate back and forth, but the center piece no longer moves in a...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11082984810/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
For future reference you might also want to review / print / save the following Whirl[pool / Kenmore Service Manual for these washers:
Dec 26, 2010 | Kenmore Washing Machines
I am looking for a manual for a Kenmore Mid-state sewing machine co. model A type 15 #H262995 Thanks, that is all I know about the machine.
Sears is great for keeping old manuals. Go online to Sears parts and you should be able to enter the model number and bring up the parts available.
Nov 10, 2009 | Sewing Machines
I have a Sears 3 H.P. electric 30 gal air compressor
This link will take you to sears web site, where parts are available. I have linked you to the parts list. If this does not take you there, go to www.sears.com and click on the parts direct tab and enter your model number.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=106.154880&productCategoryId=0703000&brandId=0247&modelName=CRAFTSMAN-TWIN-CYLINDER-TANK-TYPE-PAINT-SPRAYER&diagramPageId=00001&documentId=00001361&pop=flush
Oct 30, 2009 | Air Tools & Compressors
I have a Kenmore Elite 9 yrs old. Water leaks out of the tub when it is filled. It started as a slow leak, but getting worse. Any suggestions for a fix? Thank You, Wayne
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the Sears site sub-components for the agitator, basket and tub. It's possible that one of the gaskets or seals has worn over time.
I'd also pull off the cabinet and check the hoses leading to and from the pump. It's also possible that the pump is leaking.
See the following for how to remove the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Oct 19, 2009 | Kenmore 24032\24036 Top Load Washer
On my Eureka Model 1759A (from mid-1980s), the plastic catch that holds the two parts of the metal body together has broken. I would like to replace the part of the catch that attaches to the top (the part...
This latch is riveted to the body. If you are lucky you may find an old Eureka warranty/ repair center with one on the shelf, or another canister for parts. That will be your best hope.
Oct 06, 2009 | Vacuums
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
