Question about Ford 2008 F-250
How can I get power back to my 2008 ford f250 with dpf-r plus 4.0?
Was getting error codes 25 & 20 and accidentally unplugged dpf-r and truck will not turn. Please help
2 Suggested Answers
wyno62
  • 364 Answers
SOURCE: was connecting flat 4 wire connector to truck,
Usually a short will be corrected by replacing the burnt out fuse. However, I have also found that the earth wire fails when something like this happens, For peace of mind, check the connections behind the plug to ensure tight fit and spray with some WD40. good luck.
Posted on Nov 19, 2009
Testimonial: "THANK YOU"
2003 ford expedition check engine light is on. It is reading a p405 code which is the egr sensor. I have change the sensor and the pig or electrical code twice . I brought the sensor from ford.
This DTC says nothing about changing the sensor or the connector or pig tail ! It's a circuit voltage low code
P0405 - DPF EGR Sensor Circuit Low Voltage Detected See DTC P1400 Problem with wiring or PCM !
P1400 - DPF EGR Sensor Circuit Low Voltage Detected The EGR monitor checks the DPF EGR sensor signal to the PCM for low voltage. The test fails when the average voltage to the PCM drops to a voltage less than the minimum calibrated value.
  • DPFEGR circuit short to GND
  • Damaged DPF EGR sensor
  • VREF short to GND
  • Damaged PCM
A DPF EGR PID reading less than 0.2 volt with the key ON and engine OFF or running, indicates a hard fault.
Sep 01, 2016 | 2003 Ford Expedition
Ford focus 2.0l tdci titanium 55 plate...the car is under boosting,
make and model would sure help someone help you
Apr 17, 2015 | Cars & Trucks
Have a 2008 f450 and the exhaust system was just cleaned it still has no power and will not go over 25 mph it said to drive to clean dpf
To clean the DPF, the vehicle needs to be driven at 50-60 mph for an uninterrupted minimum time of 15 minutes. (Motorway?). If it won't go over 25mph that's a problem. You need a garage that has computer software, that can put the vehicle into forced regeneration. Other option is to have the DPF removed and the ECU reprogrammed, but there is a question about the legality of doing that.
Jan 02, 2014 | 2008 Ford F 450 Super Duty
P00B7 P012F aremy trouble codes and I am getting a Reduced engine power displayed on the dash of my 2008 F250 6.4 what should I do
Hyper extended Thermostat. Have it replaced. This is the cause for both codes and the reduced power.
Jun 18, 2013 | 2008 Ford F 250 Super Duty 4WD
P2002 code is on
P2002 isn't listed code, are you sure about this?
Oct 04, 2012 | Cars & Trucks
Wrench light is coming on and display reads ODO Error, no power in Drive, can only go in Reverse
My 2008 Ford Edge had the same error with the same issue - no power in drive, will only go in reverse. My Ford Dealer is replacing a speed sensor and a turbine sensor. They also recommended a transmission flush and re-programming. Total estimate is 4-5 hours plus parts - about $1,000.
May 11, 2011 | 2008 Ford Edge
The error code P1401 comes up on my Ford Taurus SE 2002. Can you tell me what it stands for and how to fix the problem?
P1401 - DPFE EGR CIRCUIT HIGH INPUT
Your DPFE is no good hate to say but probably was your proplem the whole time none of the other parts not needed except the fuel filter and pcv good PM stuff there. The DPFE is either going to be a silver or black box around where the egr valve is. be sure not to get the hoses crossed when putting it back on.
Keep us updated.
Dec 08, 2010 | 2002 Ford Taurus
P0471 and p2002 codes, Audi A6 2.0 DPF S-Line Auto
The DPF is designed to be self-cleaning to a certain extent if the engine is run for a good length of time the deposits should burn off. I would kick up a fuss with Audi about the warranty, ask them to show its exclusion. Unless the DPF has become physically damaged by something you have done then they need to have it fixed as it is a result of the deficiency in their design. This is not like some damaged tyre, open to abuse by the driver, the DPF is integral to the vehicle operation and through no commission on your part it is not functioning as it should.
Jul 27, 2010 | 2008 Audi A6
Was connecting flat 4 wire connector to truck, accidentally touched hot wire to metal. Now i dont have any power coming to trailer plug on truck. 2008 ford f250 superduty
Nov 19, 2009 | 2008 Ford F 250 Super Duty 4WD
2008 f250 super duty 6.8 deilsel
sounds like an egr valve problem, pull the egr valve out of the intake (2 8mm bolts and pry out with a "ladyslipper" style pry bar, it it is covered with thick soot then this is probably your problem, this problem will often not trigger a code
Nov 27, 2008 | 2008 Ford F 250 Super Duty 4WD
Ford 2008 F-250 Logo
55 people viewed this question
Top Ford Tools & Hardware - Others Experts
john h
Are you a Ford Tool and Hardware - Other Expert? Answer questions, earn points and help others
