Question about Water Filters & Coolers
Can I run vinegar through the Black and Decker model 900144 to clean it?
Used this item for years, hot water spigot is getting clogged.
3 Suggested Answers
  • 958 Answers
SOURCE: Problems with Black & Decker
you have to open it up and look where the water is dripping from. it could be from the rubber hoses that connects the tank to the faucets.
if it's on the hoses, that would be easy to replace, but sometimes the leak would come from the stainless tank whiich would be very hard to replace.
tnx 4 using fixya,
drcool
Posted on Oct 14, 2008
SOURCE: Just want the cold water - Black and Decker 900144
I need to do the same thing. Please let me know if you were able to get this done. It would help me out alot. Thanks you.
Posted on Nov 18, 2010
My hot water spigot no longer works. Is this caused by a build-up of sediment from our years of heavy use, or it is time to upgrade?
It sounds like this is a constant use item, and you do not have the time to descale it. If you have the time, you may want to try to descale the sediment using citric acid or white vinegar. This will dissolve the scale, and after awhile you could soon get water through the spout. Here is a link to the manual:
http://www.bunn.com/sites/default/files/discontinued_manuals/35582.0000.pdf
Apr 17, 2015 | Bunn CDBC 35 Coffee Maker
How do I clean a not self clean ,quick press s506a , not self cleaning black and decker steam iron
Most steam irons can be cleaned deposits by emptying the water and replacing with white vinegar. Let it heat up and use the iron as normal - but on cloth rags instead of clothing. The vinegar breaks down and dissolves the mineral deposits inside that are responsible for sputtering and stains. You can reduce or even eliminate these deposits from forming by using distilled water instead of tap water in the iron - otherwise - run vinegar thru it when it starts acting up. The vinegar "trick" works great on coffee makers, too.
Dec 03, 2014 | Applica Black And Decker Steam Advantage...
Black & Decker Steam Buster SV1000. Can't get to steam (or spray). Never used before but have had for several years. Nothing clogged. 50 water/50 vinegar in water reservoir. Vacuum works fine. Pump...
The impellar or your water pump is on its very last broken fin, time for a mew machine or the long hunt to find a replacement impellar
Nov 06, 2014 | Vacuums
Coffee tastes bad in old and new coffee makers
Have you tried first just running distilled water through it, then again with spring water and then test with enough coffee for 1 cup to see how the cofee taste then. Also you may want to use distilled or spring water when making that one cup of cofee to test.
Dec 17, 2013 | Mr. Coffee Coffee Makers & Espresso...
We have a black@decker stainless dome kettle (red) electric kettle. we've used it for a couple years and it works great, but there are deposits inside basin that we can't get off with soap/water. they're...
Fill it with vinegar and leave to soak overnight/for two nights if really bad.
Any parts which are impossible to fill with vinegar - lids/spouts, soak a cloth or tissue in vinegar and wrap/wedge into....and leave to soak overnight.
Jan 01, 2011 | Black & Decker Black Decker Brushed...
May 03, 2010 | Whynter FX-6SW Free Standing Hot & Cold...
I have a Black and decker DCM100b. It was brewing slowly. I tried rumning the vinegar and water solution and now no water is comming through at all. We have owned it for about 6 months
It sounds like the heating element is gone bad feel the base to check and see if it is hot but be careful no to burn your hand just touch it quickly if it is not very hot the element is gone bad. the heating plate on the bottom acts as the water pump/heater for the unit as well so if it is not hot enough it will not boil the water to cause the water to flow through the machine.
Aug 07, 2009 | Black & Decker AM8 Coffee Maker
Problems with Black & Decker #900144 TopLoad Water Dispenser: It is dripping water constantly and the item is only 4 mnths old
tnx 4 using fixya,
drcool
Oct 14, 2008 | Whynter FX-6SW Free Standing Hot & Cold...
Spacemaker stoping before brewing pot have to keep restarting why?
If you live in an area with hard water it may just be that the calcium accumulation is preventing the water from flowing through the unit. Have you tried running a 50/50 mix of white vinegar and water through the unit? I received a completely clogged unit and then ran the same mix of vinegar and water through the unit, allowing the water to cool each time, about 6 times before completely unclogging it. Make sure to use a fresh filter each time to catch any calcium that may dislodge from the various tubes in the unit.
If cleaning the unit in this way doesn't resolve the problem, without knowing with unit you have, then it sounds like an internal thermostat is getting too hot, shutting down the internal water heater. If that's the case then B&D is using a new design for their internal thermostats, one which resets itself when it cools off, and that thermostat may be bad and kicking off at too low a water temperature in which case your only solution is to return it for exchange or replace the water heater unit.
Oct 03, 2008 | Black & Decker SpaceMaker ODC325 Coffee...
Black and Decker problem
I'm experiencing the same problem after only 1 month !
Mar 09, 2008 | Black & Decker (050876530606)
Water Filters & Coolers Logo
450 people viewed this question
Top Water Filters & Coolers Experts
Tom Chichester
Are you a Water Filter and Cooler Expert? Answer questions, earn points and help others
