Question about Panasonic Viera Tc-p42x5 42" Inch Flat Panel 720p Plasma Hdtv Television
I was watching TV it shut off and the power button flashed a bunch. I unplugged it waited for a while plugged it back in. It did not turn back on until i held down the menu button on the set.
10 minutes later it shut down again. the power button is flashing 12 times over and over i have unplugged it again.
    Master:
  • 424 Answers
I found the following blog on the web.
Panasonic Viera Plasma Failure Page
November 14, 2010 ·
Blink Codes and what they mean (8-13):
8 blinks Driver SOS 3 SS Board (SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG BoardDTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Boardwith IC8001
Make sure the inside of the TV is clear of DUST especially by the power supply and fins.
Posted on May 02, 2015
Testimonial: "This model tv doesn't have an H board to order so what am I looking for?"
  • Thomas Stauber
    Thomas Stauber May 03, 2015
    If sounds like the board heats up and then a sensor shuts it down. Plasma TVs use a lot of power and heat up.
    Make sure the inside of the TV is clear of DUST especially by the power supply and fins before you go deeper into part replacemen.t
Power problem with Zenith D56W25 56 in. Rear Projection Televisi
you can try to shut the tv off ,unplug the power to tv and anything that is powering the tv[pvr] .now plug in the power to the box first wait,30 seconds or so ,now plug in the tv wait,now turn the t.v. on,WAIT unless it starts smoking just wait.see what happens.
Apr 18, 2010 | Zenith D56W25 56" Rear Projection...
My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
Apr 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
I have a Sharp 32 inch 720p tv, power works, no other buttons do
Unplug TV set from the outlet, wait 30 seconds, plug it back in, select right input with your remote if you using cable box or Punch the channel that you want to watch if you have cable service connected directly to the TV.
Nov 05, 2009 | Sharp LC-32SB23U 32 in. LCD TV
Tv shut off, and wont turn on. It flashes when you press the power button. NO clue at what is wrong.
is the tv on a power strip? unplug the tv from the power strip or wall outlet wait one minute then plug back into the wall outlet and not a power strip. TV should power back on.
Oct 12, 2009 | Sabre LCT371BKA LCD TV
Sharp 46 aquos model LC46E77UN tv turned off power button just flashes on and off tried unplugging and waited an hour and replugged same conclusion power light just flashes
Unplug it hold down the Channel Down button and the Volume Up button unplug it for 10 seconds then plug it back in and continue holding them down for another 10 seconds then release. I had the same issue and this fixed it now I have another though *~*
Oct 01, 2009 | Sharp Televison & Video
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
Mar 18, 2008 | Televison & Video
Lcd sharp tv flashing green light
Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
Jan 06, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
the flashing light often shows malfunction ,check the wire connection of your devices something must be wrong .the surge protector you have is for overpower or low voltage too?Ask your neigbours if they have shame problems
Nov 18, 2007 | Hitachi 46F510 46" Projection HDTV
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Jul 18, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Panasonic Viera Tc-p42x5 42" Inch Flat Panel 720p Plasma Hdtv Television Logo
329 people viewed this question
Top Panasonic Cell Phones Experts
Rommel Balcita
Andrew Taylor
Andrew Taylor
Are you a Panasonic Cell Phone Expert? Answer questions, earn points and help others
