Hi I keep getting a ch 67 after the unit starts fine and runs for like five minutes fan on all units work during that five minutes any thoughts would be greatly appreciated
    Master:
  • 602 Answers
Low freon pressure switch is turning it off. As the coils cool down the pressure drops. As time goes on it will run shorter and shorter cycles. In warm weather freon 22 low pressure should be near 70 lb
410A freon about 150 on the low side
Posted on May 03, 2015
Electrolux PHSC39EESS5 refrigerator: EF code, but evaporator fan is working (usually). sometimes at restart, compressor and fan will start, then stop after 1 minute. is there other reason for EF error...
When this happens your fans is getting the incorrect information on how to run, on some occasions both the fan and control to the fridge had to be replaced at the same time. Disconnect the evaporator fan motor and run the unit as normal. If the computer allows the compressor to run at least five mins, just replace the fan motor, if not replace both.
Control board is under the unit Part# 241511102 (only if needed)
Parts number for fan motor P#241509402 both of these parts should be available through your local part house or REPAIR CLINIC, to avoid shipping cost and any return issue you may have.
I hope this helps, good luck
Oct 20, 2013 | Frigidaire FGHC2345LF Gallery 22.6 Cu. Ft....
Lg dehumidifier ch 67 error
Thanks for the post by Posted by Bill L on Jul 14, 2012.
I decided to take a chance and order the new Sensor assembly $20.50 and install it in my LG LD651EBL Dehumidifier which was giving me ch 67 errors. Wala, it worked, the error code is gone and the dehumidifier is now working perfectly! Thanks
Jul 14, 2012 | LG LD651EBL Dehumidifier
Error code 67
Error code 67 is an airflow problem. Either clogged filter or bad blower motor. Unplug unit remove bucket and feel for filter in front behind cover it drops down. Clean filter with water and reinsert. Plug unit in turn to "on", fan should begin to run, after 3-5 minutes compressor should start. If fan does not start it is bad and should be replaced.
Jul 07, 2012 | LG LHD65EBL Dehumidifier
LG dehumidifier LD451EGL with error code CH67
After cleaning the filter, i had to unplug the unit to clear the ch 67 error code before the unit would run again.
Apr 16, 2012 | LG Dehumidifiers
My LG unit starts fine and cools but the fan runs at hi speed only and I cannot select any other speed although I hear a beep when they are seleted
In Auto mode, and jet cool or fast cool (if option is there in your remote), you can't change speed. Keep cool mode and then press fan again and again still you get required speed. Suppose, as you said beep sound is there when you select speed, check related speed terminal in PCB. If power is there, winding open in motor. If no power, replace/repair PCB. Thanks and hope it's helpful.
Jan 26, 2011 | LG LS-K1830CL Cool Mini Split Air...
Hi I have a goodman MSG-18HWN1 heating and cooling mini-split unit. The unit keeps going on and off on a cycle of about 5 minutes. 5 minute, unit not started, unit starts for about 5 minutes, stops for...
Due to abnormal temp of out door.Check outdoor fan motor and compressor and also sensor.
Fan motor not working- rectify/replace fan capacitor.
Sensor defective-Replace it
Compressor high amps-Replace running capacitor.
Sensor misplaced or defective-Place correctly or replace it.
Jan 05, 2011 | Heating & Cooling
When unit starts the condensor fan only comes, not compressor
You need a new fan motor and the correct capacitors for your sydtem I think they are 35 or 45 5 cap. Try a hard start kit on compressor. Are you sure you have the cap wired correctly?Russ
Jul 16, 2009 | Carrier 38CKC036 Air Conditioner
Cooling
Check if the condensar ( outside fan unit) is getting enough free ventilation. IF there is no free air flow you will mostlikely be triping the unit due to short cycling. Ie the unit is pulling its own discherge air causing the compressor to trip due to high back pressure
Sep 04, 2007 | Haier HPAC9M Air Conditioner
LG Dehumidifier
the compressor motor is badly damaged...surprised it is turning on at all...the starting winding is bad, the running winding is fine...the motor is ...well done. new dehumidifier cheaper than fix
May 27, 2007 | LG LD65EL Dehumidifier
Panasonic SC-HT900 Audio problems
http://www.datasheet.in/search.php
Sep 06, 2006 | Panasonic SC-HT900 System
Heating & Cooling Logo
91 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
