Question about Ovens
I have a Pyrex accessories meat probe and the battery has been taken out and I need to know witch one I can put in it
    Top Expert:
  • Ovens Master
  • 52,096 Answers
Sorry but you should have kept the old one and took it with you to buy new or read the number and wrote it down . we have no idea
Posted on May 03, 2015
I need to know How Can I change de meat temperature core in SCC202G Rational Oven.
To change that probe you need to remove the top of the oven and at the front and running from right to left is a tube that has the cable for that probe, if that probe has never been replaced before then you can (WITH THE POWER DISCONNECTED FROM THE OVEN) disconnect the original probe wiring and carefully and using electrical tape join the defective probe wiring less the probe body, you should be able to pull the new probe wiring thru that tube and connect the new probe exactly ware you disconnected the old probe, make sure you take a detailed picture of the connection before you disconnect.
Apr 02, 2018 | Ovens
F3E3 Meat probe Shorted
faulty meat probe, probably a factory defect, if still covered by warranty, return oven for replacement.
Mar 22, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
How do you use the meat probe
Insert the probe into the center of the meat, in an area where it's likely to cook the slowest. Anything above 63 degrees celcius is considered safe for consumption.
Dec 25, 2011 | Jenn-Air Ovens
My GE double oven displays a message to set probe. When I press probe it prompts me to input a code (3 dashes)? Can you provide via e-mail what numbers can be used to set probe?
It is asking for the temperature that you want the meat to be. Example if you want your meat to have a medium doneness then usually it is 150F. You would enter 150. The probe will beep when the meat has reached that temperature
Sep 14, 2010 | GE Profile JTP56 Electric Double Oven
Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
May 10, 2010 | KitchenAid Architect Series KEMC308KSS...
My oven is stuck in probe mode and will not cancel.. what should i do
Measure the resistance of the meat probe on the K-ohm setting. If it's open, then the probe is bad. I'm not finding a spec on the resistance but it should be something in the K-ohm range.
Next stop is to check the meat probe socket. May be gunked up with condensed grease or whatever. Sometimes a light schmear is all it takes to flake it out. Then check continuity from each leg of the meat probe socket back to the ERC, where the meat probe harness connects.
Mar 06, 2010 | Ovens
What is button on the left next to plug outlet on kenmore c880???
As far as i can tell by your model there is no button there is only a meat probe receptacle. if yours doesn't have such a thing it is likely to be an after market part. part number for the meat probe is WB20X5050. hope this helps
Thanks
Oct 11, 2009 | GE Profile JTP56 Electric Double Oven
What is a U80 meat probe error and how do I fix it?
Error U80: Shorted meat probe
1) Food, moisture, or other substance is in the socket or on the oven connection end of the meat probe. Check: Verify proper operation with new probe (replace probe). If still fails with new probe check wiring of housing to eliminate shorting to sheet metal. Solution: Clean socket and meat probe.
2) Bad meat probe (shorted). Check:Use new meat probe to test for correct values in the service screens. Solution: Replace meat probe.
3) Shorted socket or wiring. Check: Test socket at connector J20 on relay board. Solution: Replace meat probe socket.
Functionality when error U80 reported: Cooking and cleaning are available but meat probe options will not be available.
User action/solution:
1) Verify oven connection end of meat probe is clean and no food, moisture or other substance in is the meat probe socket.
2) Call for service.
Aug 26, 2009 | Dacor Epicure EO230 Stainless Steel Oven
Oven will ask for temp probe when i am not using one. it then turns itself off.
As you did not include a model number I can suggest you insert your meat probe into it's receptacle and remove it again quickly about a half dozen times.....maybe even a dozen times. The meat probe plug is like an older style headphone plug. The receptacle that it plugs into may need to complete a circuit for the electronic control. When the probe is not in the receptacle, the receptacle contacts touch to complete a circuit. These contacts may have become dirty from normal oven usage. You will be cleaning these contacts using the probe as I explained. If that doesn't solve the problem you may want to call in a professional.
May 04, 2009 | Ovens
Ovens Logo
55 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
