Question about Dimplex Heating & Cooling
Dimplex opti-mist Elect fire,smoke effect and lights work but as soon as the blow heater heats up it cuts out and has to be switched off at the mains for a period before it can be restarted again.
2 Suggested Answers
SOURCE: dimplex opti-myst fire main effect bulbs not
i've got the same problem - have you fixed it yet??
Posted on Jan 01, 2011
Heater not working but flame effect does
If you have opened the glass door you will see 2 switches and a rotating dial, thermostat. ! switch is heat, the 2nd is the flame effect. it is not serviceable to a consumer unless professionally trained.
Apr 28, 2016 | Dimplex DS5603 Heater
Dimplex dakota heater is working but flame effect is not its led I think not bulbs.
Says you can turn it on and off? Did you knock the switch?
Can I operate the flame effect on the fire without the heat?
All our Optiflame and Opti-myst fires can be operated on a flame-effect only setting, as can the flickering flame effect on our freestanding bar fires.
Is the flame effect expensive to run?
No, to run the flame effect involves powering light bulbs and a small electric motor and in most cases costs no more than a couple of pence an hour. Some of our fires have LED lamps fitted which are even more energy efficient.
Some have bulbs, some have LED.
Example calculations:
Using UK standard average price of electricity of 14p/kWh (source: Energy Saving Trust Feb 2015)
Optiflame LED flame effect only (eg Danesbury) = 0.1p every hour
Optiflame conventional bulb, effect only (eg Cheriton) = 2p every hour
Opti-myst, flame effect only (eg Oakhurst) = 3p every hour
Opti-V single screen = 0.5p every hour
2kW fan heater, on constantly (no thermostat) = 28p every hour
Optiflame lightbulbs for sale. Remove the coals and check for bulbs.
https://store.gdcgroup.co.uk/dimplex/products/index.htm?product_code=FP03022
Dec 23, 2015 | Dimplex Heating & Cooling
Aux heater blowing blue smoke but no heat
That may be antifreeze mist you see. check the heater core
Nov 22, 2013 | Chrysler Cars & Trucks
Fire wont mist ad keeps turning its self off 3rd time lucky at posting this as not a car or truck and it keeps coming up under cars or trucks
You can call Dimplex directly for Tech Support:
Dimplex Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Feb 07, 2013 | Dimplex Compact Electric Flame Stove...
Fire was working fine, then flame effect stopped. Heater still works on both settings, but no flame effect. Tried new bulbs, but still no flame effects, any ideas?
If it is not the bulbs, it is often a melted switch or circuit board.
You can obtain technical support for your stove here:
1-888-346-7539
Monday - Friday
Jan 05, 2013 | Dimplex Compact Electric Flame Stove...
I have 2 Dimplex DS4411 fireplace heaters. One has the fire display, but does not heat. The other has heat, but no fire display. How do I fix it?
The fire display is a simple replacement of the light bulbs that produce the effect.
The heater issue could be a bad temp sensor, or a bad heater.
You can contact Dimplex support here:
1-888-346-7539
Monday - Friday
Nov 28, 2012 | Dimplex DS4411 Electric Heater
On a Dimplex Cavendish CSH 20 the smoke effect and lights do not operate. What should I be looking for\r\nNeil
Right off hand, I'd say the light bulbs are burned out and need to be replaced. The model you listed comes in 2 editions, one with a misting effect and the other without. In both, the bulbs are replaced the same way - by opening the sump door to access the bulbs.
To further help you, I have included a link to the Owners Manual for your model. You may download and print it for future reference.
http://www.dimplex.co.uk/assets/kb/operating_instructions/0/Cavendish_Chesford_Opti-myst_Issue_1.pdf
Hope this helped you resolve the problem. Please let me know. Thanks.
May 24, 2011 | General Heating & Cooling
Motor in dimplex fire/heater not turning
Hello. It could be possible that a piece or some of the foil that gives the flame effect has fallen down on the motor, that creates the heat. This could be causing the noise. I would not think this is an electrics problem.
I would ensure the electric fire is disconnected from any power supply and either open the heater myself or get a electrical specialist to have a look. Then you will see exactly what is happening. A piece of foil may be visible which is catching the motor.
If you decide to tackle the problem yourself write down how to put the heater back together as you take each part out. These parts would be covers etc. It can easily get confusing. That is important.
Feb 02, 2009 | ACE Dimplex (r) Compact Electric Fireplace...
Dimplex Compact Electric Flame Stove Heater
call Dimples !-800-663-6663 ext 358 They will be able to help you out.
Apr 02, 2008 | Dimplex Compact Electric Flame Stove...
Heating & Cooling Logo
75 people viewed this question
Top Dimplex Heating & Cooling Experts
paulcarew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
