Question about Garden
I have 2 mowers alike both 6.5 B&S walbro carb. with primer bulb in filter housing. cleaned screen,& new gasket. nether one will prime gas in to start. what am I missing. had this happen before.
I have only had trouble with this type primer bulb. cleaned carb. & put new kit. & gaskets. billy1534@suddenlink.net
  • 1,169 Answers
It probably that the filter housing is warped from either old age or the screws mounting it to carburetor have been overtighten warping the filter housing.
Remove the filter housing and look at the gasket. I am fairly you will see areas of non-contact on the gasket or where it has been cut into.
Posted on May 02, 2015
I have a Poulan Pro 625 that won't prime. I have changed the bulb and put two fresh gaskets on it. I'm at a loss.
Sometimes the housing holding the primer bulb is warped. Try doubling up on the gasket holding the air filter to the carb.
Jun 07, 2014 | Poulan Pro 22inch 625 Series Briggs ...
Ryobi 410 mini tiller w/Walbro WT149A primer bulb won't prime. New bulb, new fuel lines, hooked up right, carb cleaned. Been sitting for several years.Runs when fuel is pumped into the fuel inlet.
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, !!
Feb 21, 2012 | Garden
Getting my new fuel lines in correctly from gas tank to priming bulb & from gas tank to carb.
on weedeaters,chain saws. most are the same.
line with little filter in gas tank goes to carb. line out of carb to primer bulb
line from primer bulb to gas tank
Jun 24, 2010 | Garden
No gas to carb
There should not be a vent hose--it probably goes to a port on the primer bulb. Check the fuel filter for plugging and the condition of all fuel lines (they should be original rubber, not plastic replacements). Try priming the carburetor with the bulb pump--it should pull fuel into the bulb after several pushes. If nothing, check the condition of the primer bulb--it should be soft without cracks or holes.The primer is supposed to pull fuel from the tank's fuel filter, into the carburetor top section, pass into the lower section through the metering valve which is controlled by the diaphragm, then out to the input port of the primer and out the other primer port to return fuel to the tank. Go to: http://www.drystacked.com for an excellent 12 page article on theory and troubleshooting of Walbro carburetors. Hope this helps!
May 16, 2010 | Poulan Reconditioned Chain Saw 33cc 14in...
No gas when you prime it
1) Check fuel lines from tank for cracks, fuel filter in tank, primer bulb for cracks
2)Remove Carburetor
replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 13, 2009 | Craftsman Garden
Starts and idles but dies when i pull the throttle.
Either clogged or needs cleaning/ rebuild. ITS SIMPLE! ok If you have a Walbro WT series carb "without" a built on primer bulb here it is. First off if the fuel lines disintegrated you MUST disassemble it and clean it out. The MOST infintesimle speck of gas line trapped, can allow good prime and bad operation. OK? Don't be lazy on this. Just be delicate removing the flaps gasket and diaphram. ZAMA GND-12 Is the replacement Gasket and diaphram kit fot that carb. Use a cleaner, compressed air or blow good thru it. OK Now...Primer bulb, Carb, and Fuel tank, re connects: Smaller Diameter line comes from Gas tank (Connect filter screen to this in tank) to the short Straight brass carb connector. Primer bulb suction goes to the bent carb brass connector. If small line brings fuel "in" this other line sucks it back "Thru the primer bulb" and the blow side of the primer bulb sends it back to the fuel tank! So...Small Line brings fuel "TO/IN" carb thru short brass connect on carb. Other carb connect goes to bulb suction "IN", Then primer bulb "Pressure OUT" goes thru the larger tube "back to fuel tank". Trust me I know how frustrating a simple diagram is to find online fo this set up. And if you have a carb problem on top of the hook up uncertainty you got frustration. Not only was online help hard to find (Mfg...etc NFG at all!) My local repairshop in BBrook NJ could not tell me how!!! and thats no lie! Walbro has a "generic" carb diagram but no "hook up info" specifically. Poulan don't list it either. And these things routinly fall to pcs. all 3 of mine crumpled together on yr. 3 of use.
Jul 06, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Replacing fuel tank on craftsman edger and other fuel lines.......do not understand where to hook fuel lines back up?  any diagrams?
Jun 15, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Poulan Weedeater sst25 25cc engine fuel line
May 02, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Snapper SS312 weed eater. Cranks when primed but won't run
I am sorry to say this, but the compression for that type of engine should be atleast 120 psi. Remove the muffler and look at the cylinder, it is scarred beyond repair.
Mar 30, 2009 | Garden
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
