Question about Garden
What are the air fuel settings on a Murray me2550 weed eater
slohry
  • 87 Answers
SOURCE: fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Posted on Apr 10, 2009
  • 62 Answers
SOURCE: poulan ppb 250 weed eater, only runs with choke on,
HOW IS YOUR FUEL LINES. SOUNDS LIKE IT MAY HAVE A AIR LEAK
Posted on Sep 25, 2009
  • 53 Answers
SOURCE: weed eater bogs down
Under what conditions does it bog down? When it just idles? Cold or hot? When you give it gas? When you try to cut?
Posted on May 11, 2010
MOTORWIZJ
  • 1383 Answers
SOURCE: Husqavarna 125L E TEC weed eater won't stay running
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
SOURCE: What is proper gas/oil fuel ratio for TORO Model
50:1
Posted on Jul 02, 2010
Very hard to start the Murray M2500 weed eater
replace the diaphragm in the carby( note her e--kits are as costly as a new carby so check on e-bay for a replacement price
don't use e-mix fuels in small engines
Aug 20, 2016 | Garden
My murray m2510 gas weed eater runs at idle but when i go past fast idle it wants to die. i put a new spark plug in it, it didn't change. what could be the problem? it started doing it last fall.
Sounds like fuel problem. You may want to check the vent on the fuel tank. It can get clogged and won't provide enough fuel to run at higher rpms. I'm not familiar with that engine, but its a problem I've had in the past with weed eaters and chainsaws.
Apr 07, 2016 | Fast Garden
Murray weed eater won't stay running
have to go further in the carb, If you left 'todays' ethanol gas in the weed eater for more then a few months, it probably messed up the Carb. Ethanol gas is very bad for carburators on any machine
Aug 31, 2015 | Garden
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    How do i change a coil wire on a murray 2510 weed eater?
    Murray Trimmer Product Support ' ManualsOnline.com
    www.manualsonline.com/support/murray/trimmer/
    Does Murray Weed Eater MS2550 use straight gas or. Murray ... HOW CAN I DOWNLOAD MURRAY 2510 TRIMMER MANUAL??? Murray Trimmer M2510.
    Mar 13, 2015 | Garden
    Ss30 ryobi weed eater fuel ratio
    I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
    Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
    Poulan ppb 250 weed eater, only runs with choke on,
    Sep 20, 2009 | Garden
    Garden Logo
    75 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
