I have a electric dryer Model WED5810SW0 THAT I WAS TOLD I COULD CONVERT TO 120V from 240v is this true and if so how do i do this?
If you consider doing this the first thing is SHUT THE MAIN BREAKER OFF. Use an auxiliary light source to see when working in a dead panel. Always keep in mind an ARC FLASH ACROSS HOT MAINS HAS ENOUGH HEAT TO PEAL THE SKIN OFF OF YOU.
Before an explanation of how to do it you should keep in mind that this
is for a single receptacle only. If any other receptacles are on the
same circuit they will also be changed to 240 volt receptacles and if
you plug any 120 volt device into them, the 120 volt device will be
destroyed. That said OK, any 120 volt outlet can be changed to 240 volt
by removing the 120 volt circuits neutral, re identifying the white wire
with red or black phase tape and connecting it to a new 2 pole
15 amp breaker. The maximum that this circuit will now load up to is, on
#14 wire at 80% = 12 amps at 240 volts. The 120V receptacle must be
changed to a 15A - 240V receptacle so that 120 volt devices can not be
plugged into it. Never use 2 single pole breakers together because code
requires that on a fault trip both legs of the 240V circuit must be
disconnected simultaneously. OR USED A Quick 220 Voltage Converting Power Supply
Voltage converter buying guide. Voltage Transformer Buying guide.Voltage converters also known as voltage transformers are devices that
convert foreign electricity to power devices from different parts of the
world. A step down voltage converter is a 220 to 110 volts converter. A
step up converter is a 110 volts to 220 volts converter. Our 2-way
converters are voltage transformers that convert power from both 220 to
110 volts and 110 to 220 volts. They also work with 100 volts, 110
volts, 120 volts, 220 volts and 240 volts. This model is a 2 way voltage
converter / voltage transformer available in many different sizes
including 100 watts, 200 watts, 300 watts, 500 watts, 750 watts, 1000
watts, 1500 watts, 2000 watts, 3000 watts and 5000 watts.
