Question about Boating
70 HP evinrude 4 stroke outboard (pontoon boat). New spark plugs all connections good. Will only do idle speed put I. Forward or reverse won't gain speed
  • Boating Master
  • 19,654 Answers
I had the same problem with mine, let me see if I can find the picture I took.
Just above the red arrow on the choke, the linkage has to be firmly clipped in that little black clip. Unless that is in place, you are only throttling one carburetor! Drove me crazy trying to find the answer to that one and it happened after the marina engineers had replaced a leaking fuel hose. Mine was a two stroke, but I bet the linkages are the same to the carbs.
70 HP evinrude 4 stroke outboard (pontoon boat). N - 25677137-pydoskg0kuzfsymgthkoaail-5-0.jpg
Posted on May 02, 2015
  • 86 Answers
SOURCE: 1996 evinrude outboard stalls when put in gear
Start by adjusting your idle mixture screw. Start at 1 1/2 turns out and with the engine in gear at an idle slowly turn the screw clockwise until the engine starts to die, then back off a half turn and that will be your proper setting. If you need to you can bump up your idle stop screw just a touch so it will hold also.
Posted on Aug 10, 2009
  • 6 Answers
SOURCE: 35hp Johnson evinrude outboard not running at full potential
Hi, did you buy your engine used? Sounds like your gonna have to get the carb or carbs cleaned. Its possible you could have a stopped up fuel filter, or not enough spark but i am guessing its gonna be the carbs. They got some gunk in em i bet. Probably old fuel turned to gunk from setting up. I had the same problem on my 40 horse.
Posted on Aug 22, 2009
Testimonial: "Hi, thank you very much for your help, I will strip the carb down and have a look. Once again, many thanks, I am very greatful"
buffalonyman
  • 1865 Answers
SOURCE: oil weight to use for 1989 evinrude 2 stroke 90 hp
The oil is mixed with the gas, just buy 2 cycle engine oil and follow ratio mixture
Posted on Sep 29, 2009
  • 95 Answers
SOURCE: outboard motor won't run under load
I have 1969 5hp Johnson. Starts and runs good, but will only push a 14ft row boat slow at low to medium rpm. When at higher rpm the the motor just revs up and the boat slows down to almost nothing just like it has seaweed around prop.Any help would be great.
Posted on Mar 13, 2010
  • 747 Answers
SOURCE: 1987 90 hp mercury outboard kills when putting it in gear
sound like a fuel issue if the engine set for a long period you may need to clean the carburators sounds like they are clogged
Posted on Jul 07, 2012
2010 150 Evinrude E-Tech. Motor was running great then just shut off. Will not start again.Could it be it needes to be reset, all 4 lights at tach light up showing good.
first bit of advice
do not use e-mix fuels in outboard engines
WHY
because ethanol separates from the fuel if not used continuously so letting it stand between outings is not good
secondly ethanol is hygroscopic which means that it absorbs moisture from the air that is going in via the tank vent and that results in corroded aluminium parts and rusted fuel tanks and outboards operate in a very moisture laden environment
now for the problem
being a late model engine , it should be a 4 stroke and like any 4 stroke engine , check the timing belt/chain, crank/cam position sensors , ignition module
it is important to check all harness connections as salt water rapidly causes corrosion in electrical connections and components
have the service agent do a scan for fault codes remember this
Suzuki out board 2 stroke motors were used in the early suzuki 4x4 cars and modern 4 stroke engines are simply car engines on end
Sep 18, 2017 | Clymer Evinrude/Johnson 5-70 Hp...
50 hp 4 stroke Johnson 2004 starts easy and idles smoothly.Runs very rough when speeding up.when changing oil in crankcase - no oil in oil filter.What happened?
First..
Shop Evinrude Outboard Parts Johnson Outboard Parts
No oil in the oil filter period?? Does the opening of the oil filter face down.. like the oil will drain out if sitting still?
..You need to talk to a qualified professional.. this could be very serious or SOP..
Jul 08, 2017 | Boating
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
What year is a johnson 4 hp outboard serial number b 7643180 model number bj4brccs
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
Sep 21, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 | Boating
1991 EVINRUDE 25 HP 2CYL 2CYCLE IT RUNS ON BOTTOM
get a spark tester that has 2 leads and test spark .
Jan 26, 2010 | Light Outboard Motor Boat Bass Fishing...
1974 Johnson 70 hp outboard, quits on acceleration.
It sounds like your motor is starving for fuel. At an idle, you have adequate flow to keep the engine running. When you call for more fuel...you sputter and quit. Could be a clogged filter or trash in the line or in a jet. Yes you will have some air in the bulb, but not a great deal. You could be sucking air at a hose connection (loosing some prime)...try this, start the engine and slowly accererate, have someone pump the bulb as you accelerate, see if the engine works properly while doing this test.
Aug 27, 2009 | RTO Oar Sockets
4 stroke Yamaha 50HP -Runs rough at all throttle levels
If it has the old points system you will need to set the points also adjust the carburatior screw the screws all the way in and back out 2 1/2 turns then get it to run turn the air mixture screws till it runs smooth. you want it slightly lean then enrichen it slightly, afterword shut the engine down and look at the plugs if they are gray black they are ok. good luck.
Jul 09, 2009 | RTO Oar Sockets
Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Jun 25, 2009 | Boating
Boating Logo
207 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
