Question about Garden
Changing engine need wiring diagram for engine
I'm changing out a 2.8v6 out of an88 s10 blazer to a1993 4.3 vortec I stripped everything out of the 1993 it had been rolled how much of the wiring out Of 93 do iI need do I need to change all wiring
You need the help of a good auto electrician because the new engine will have all sorts of sensors, switches and things to make it fire up electrically that may not have been on the old engine. Only a long look at the two vehicle wiring diagrams will sort this out.
Oct 09, 2014 | Cars & Trucks
I was changing the spark plug wires on my 1992 ford ranger. one at a time.one wire came.i got mixed up i need to see a picture of the wiring from distributor to engine block
what size engine! ill type you a little diagram....
Front of vehicle
coils
3 1
2 4
4 2
1 3 this is for the 2.3, ill type you a little diagram....
Front of vehicle
coils
3 1
2 4
4 2
1 3 Just match the numbers you have on the coils to each side of the block? 2.3 engine
Aug 26, 2011 | Ford Ranger Cars & Trucks
I was changing the distributor and the spark plug wires got mixed up. The vehicle is a 87 caprice with a 4.3 engine
here is the firing order diagram for that vehicle, and let me know if you need any help reading this diagram (it would seem that some people just do not get color coded diagrams) or if you require any further assistance.
Sep 13, 2010 | Chevrolet Caprice Classic Cars & Trucks
Spark plug wiring diagram
If u can't see the diagram go to the link, just match up the numbers on the coil to the engine cylinder numbers.
http://autorepair.about.com/library/firing_orders/bl-fo-5630.htm
Apr 05, 2010 | 1997 Pontiac Trans Sport
Need firing order diagram for 91 s10 blazer
991 Chevy S10 firing order
The firing order for a Chevy s10 depends on which engine you have.
1.9L engine the firing order is: 1-3-4-2 . Distributor rotates counterclockwise.
2.0L engine the firing order is: 1-3-4-2 . Distributor rotates clockwise.
2.5L engine the firing order is: 1-3-4-2 . Distributor rotates clockwise.
2.8L engine the firing order is: 1-2-3-4-5-6 . Distributor rotates clockwise.
4.3L engine the firing order is: 1-6-5-4-3-2 . Distributor rotates clockwise.
Jan 09, 2010 | 1991 Chevrolet S-10
While changing the belt on an aquarius vtd00 dryer 2 of the cables come off the control panel have you a diagram of where they go please
I am afraid you will not be able to obtain a wiring diagram, as they are only available to their own engineers, however, if you can tell me the colours of the wires concerned, I may be able to help you.
Jan 02, 2010 | Hotpoint Dryers
Need to remove and replace starter, would like to be able to see a diagram
Your best diagram is the starter itself...make notes on where wires are attached and what you removed from where. Always remove the positive cable from battery before you begin and never allow wires on one starter terminal to touch ones from adjacent terminal when you replace them.
Remember...your starter turns the engine so it can start...it does not start your engine. Always have your battery charged and load tested to avoid changing the starter because the battery is bad.
Mar 14, 2009 | 1989 Buick Park Avenue
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
