Question about Garden
Losing drive while driving up inclines and while trying to make sharp turns
    New Friend:
  • 30 Answers
If its losing engine power, then I'd say you have water in your carburettor. Drain the tank, if it's a carburettor with a primer then drain the tank and prime it and drain again.
If the engine is running fine but it's losing power to the blades or wheels then it's a belt tension problem. Try tensioning the belts or replacing bushings or pulleys, or even the belts themselves as they can have a tendency to wear on the sides and don't grip properly so they slip. Hope this helps
Posted on May 02, 2015
It is stuck up on the incline and won't come down
If you wish to get some details; check the site linked here. Pull up older posts.....
http://electro-medical.blogspot.com/
May 17, 2016 | Exercise & Fitness
Sharp mebius pcmj750r
This appears to be a Win 2000 or XP machine. These Operating Systems are no longer supported. I recommend you start looking for a newer machine & os. If you have files that you do not want to lose, you could try this... Pull the hard drive out, and use a "USB Hard Drive Adapter" (available fairly cheap online) to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive. Then, you could copy them to a newer machine when you get one.
Jun 27, 2014 | Sharp Computers & Internet
Why does my 1995 nissan pick up lose power and speed on uphill inclines?
If you keep the RPMS (tach) up to 3000 and above (DONT REDLINE YOU'LL BLOW YER MOTOR UP!) At 3000 RPM to 3500 -4000 RPM is where these motors posses what i figure is a power band that handles most inclines. Down shifting included. DRIVE SAFE
Jun 24, 2014 | 1995 Nissan Pickup
Sharp left turn lose brakes and abs light comes on
check the angle of the drive way and the speed you approach it as the wheel may loose traction and stop spinning which immediately activates the ABS system to release the brake action on that wheel
Mar 09, 2014 | Ford Expedition Cars & Trucks
1999 isuzu rodeo 4wd not working
Sometimes just driving the vehicle for a while in the 4 wheel drive high range position will make the 4 wheel drive engage again. When it does engage the light will come on and it will be hard to turn in a sharp circle- hopping, etc. If this works you need to use the 4 wheel drive more often, and it will free up and work better..It may take a couple of miles or more before it goes into 4 wheel drive the first time. To get it out of 4 wheel drive move it slowly backwards and forwards. Then use it or lose it. Remember, never drive in sharp cirles on dry pavement when you are in 4 wheel drive.
Dec 19, 2012 | 1999 Isuzu Rodeo
Hydrostatic on husqvarna cth 180 xp losing power
Check the drive belt. This belt runs from the engine to the transaxle. Look for abnormal wear and if the sides of the belt look glazed/shiny. Check the pulley mechanism that tightens the belt for proper operation and belt tension while engaged.
Try reducing the speed selector. This is equivalent to running in a lower gear. Your tractor works hard just to turn the blade. Going uphill requires additional power, so some reduction in speed is to be expected.
May 06, 2012 | Husqvarna Garden
Turntable won't turn
Hi , unscrew the cover check belt are tear / if tear replace belt , lose the belt tensioner if it has , if not just install incline belt into vevil of pulley.
Jan 15, 2008 | Kenmore 63252 Microwave Oven
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
