I broke the plug at the end of the speaker wires that connects to the mother board. What color wires go where?
  • Anonymous May 02, 2015
    the four wires are red, black, white, and blue.
    Problem Solver:
  • 62 Answers
Google the wiring diagram for the specific motherboard model you have. Pop over to the images section and find a match. It should tell you there.
Posted on May 02, 2015
  • Anonymous May 03, 2015
    I tried what you suggested but wasn't able to find what I need. I need to repair the connector that broke off of the wires, but I don't know which wire goes to what pin on the MB.
Chord plug broke
go to any hardware or home store even dollar shops --where ever u choose to go buy a replacement/repair plug .this is not a hard repair cut off plug end strip cover back 1 inch and strip back the wires separate the repair plug usually 2 or 3 little screws- slide wire up into sleeve and connect green wire to u shaped connection- white to silver color[sometimes the connections are not colored ] -black to goldish connection put plug togeather and ur done
Dec 18, 2011 | Electrolux Vacuums
How do i connect the boston BA745 comp. speakers to my gateway desktop?
Assuming you have the BA745 2.1 speaker set up, all of the cables connect to the subwoofer and then to the computer or the satellite speakers (these are built into the speakers IIRC). Take the cable with the black box (2 pins) to red and green. The red and green plugs go into the matching color ports on the computer and the pins on the black end fit into the jacks between the those for the two satellites. Plug the single end speaker cable into the subwoofer port all the way to the right on the back of the subwoofer. Plug the wire with the two plugs into the matching color jacks (blue to the left, red to the right). Then plug in the power adapter cable in the farthest left jack and plug in the other end to a surge protected power strip (that is plugged in and turned on).
Oct 24, 2010 | Boston Acoustics BA745 Computer Speakers
Speaker wire problem
Yes you can splice the ends onto the existing wires, but first make sure the ends are labeled + or - and make sure you hook the other ends to the speakers the correct way. Before you cut the connectors off of the speaker wires mark one of each of the pairs of the wires with tape, on each side of where you cut it so you can match the wires back up. Are the pre-wired, wires labeled + and -? or red and black? Or one of each pair is a different color wire ie silver and copper? If they aren't labeled its going to be hard to get the correct polarity (+ and -) for each speaker. I hope this helps post back if you have any problems.
Aug 19, 2009 | Philips HTS-3565 Theater System
Restart button in the cpu is not working
I suggest that you will open the cpu and look for wire that will connect from the restart button to the motherboard. If you have set up manual of the mother board, just follow color code of the wire that will be plugged in to motherboard. ASUS and other motherboards have connection of the wires located below the circuit board just in line with the tiny colored wires entwined by pairs.
Jun 22, 2009 | Computers & Internet
Philips Home Theater Speaker Wire (can it be cut?)
Sure you can, Joel.
Put the speakers wherever they will go, and cut the wire from the speaker to whatever length you need to reach your wall terminals. Leave some slack so you can move the speakers if needed. Strip off whatever length of insulation you need to make the terminal connection. Note that the speaker wire will have some kind of polarity marking. There will be a colored stripe or other mark on the insulation, or the conductors themselves may be different colors (usually one wire is copper, and the other tinned so it's silver colored). It doesn't matter which you use for positive as long as you're consistent and use the same one for each speaker.
At the other end where the prewiring comes out for your home-theater system, splice the connector ends you cut off onto the installed wires, following the same polarity. I recommend using an appropriate size insulated **** splice to make the connection. The crimper and splices can be found at auto parts stores, Radio Shack or most hardware stores. It's quick, reliable and makes sure there are no bare wires to short out.
Plug the speakers into the system and you should be good to go. Whip up some popcorn and enjoy the show!
Jan 28, 2009 | Philips HTS-3565 Theater System
The wires connecting my graphics card to the mother board for speakers have come off the board and i dont know where they go. I have an Acer aspire mpasm3641 with an nvidia geforce9500gs card. On the end...
I don't think your two wires came off your video card. Look at your sound card and see if there is a place that has two pins in the middle of a plastic thing where your plug goes in. Actually it is made to fit the plug on the end of your wire.
God Bless Greg
Nov 22, 2008 | Acer Computers & Internet
Swapped mother board
Hi Paul,
see page 8 number 15 for location. Than see page 19, System Panel Header in your manual.
The basic wire color's for positive are red, blue, green & can also be light blue, light green, light red.
Negative wires are usually white or black. Case wire colors do vary from case to case.
To see pin one shown on page 19, (positive + for hard drive led = HDLED+). Bottom row farthest pin to the left of set. Pin two is above pin one. Pin two is, PLED+ (known as power led). Pin 3 is to the right of pin one & is HDLED- (Hard drive led, negative). Pin 4 is above pin 3 & is also PLED-, (Negative for power led). ECT!
6781222.jpg If your new case has an internal speaker (Used for P.O.S.T, power on self test). This would connect to, Chassis Speaker Header located on page 8, number 16. Again, normally only two wires are used across the 4-pin connector. (One at each end of the connector).
To see ASRock's main site for the 775VM800 motherboard click this link:
http://www.asrock.com/mb/overview.asp?Model=775VM800&s=
Good luck Paul!
Run into a snag, just post the issue here.
Mike
Nov 02, 2008 | Asrock 775VM800 Motherboard
Washer broke its saying 6 f
The Duet washer is a good machine, just unfortunate Whirlpool engineers used oxidative circuit board coatings. All the circuit board connections are oxidizing causing the machines to have faulty connections.
We have fixed the problem using this information.
UNPLUG the machine first . Take the top off (3 screws in the back) , remove the mother board box from the frame housing and remove the lid. Now you can see the circuit board.
Carefully remove ONLY one (clip plug-in) at a time. Scrap with a (knife or sandpaper or steel wool ) the edge connector where that plug was, on the circuit board removing the oxidated metal (it may not look oxidated but must be cleaned), Next put ( vaseline or mineral oil) on the edge connector where that plug was, NOTE: Vaseline or mineral oil is a non-conductive oil and will not effect electronic operation but will prevent further oxidation and the erratic operation of the mother board will cease.
Now do the next plug and repeat until completed.
NOTE: We recommend only one plug at a time so you do not get confused where each plug belongs.
Put the cover back on the mother board box and reattach to the frame, then put the lid back on and screw it down. End of any problems.
Oct 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
No sound
u have to plug the speaker in green hole only.
Sep 02, 2008 | HP JBL Platinum Computer Speakers
Connecting Speaker
Dear Big Timmo,
To connect the Speaker Pins u have to check left or right side of u r mother board where u r power wire, reset wire and Hard disk led wire connected to the mother board. it has 12 or 13 male pins. There u will find in writen speaker in the motherboard. I hope now u can connect u r speaker pins..
Regards,
Bittu_8
Feb 15, 2008 | Intel Desktop Board D845GERG2 Motherboard
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
