How to get to menu options
TO auto program channels or add channels
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
If you have't its remote control; you can't select this option. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability.
Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Type in the "brand name only" of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on May 03, 2015
I HAVE A RCA 42" LED TV. I RECEIVE MY SIGNAL FROM AN ANTENNA. I CAN ROTATE MY ANTENNA, SCAN THE TV FOR CHANNELS, AND THIS WORKS FINE. THE PROBLEM IS IF I HAVE TO ROTATE THE ANTENNA FOR OTHER CHANNELS,...
on B:Press the MENU button on the remote.Select Setup.Select Auto Program.Choose Air or Cable.Select Auto Program to let the TV reprogram the channels.Check that the channel is programmed into memory. There are a couple of ways to do this: Use the TV menu system. Accessing this setting varies depending on the model TV that you own. Here are two options that are common on many TV's: Option A:Press the MENU button on the remote.Use the VOL and CH buttons to move through the menu and add any missing channels try this if not r
Do a full reset if this dosnt work
Dec 25, 2013 | RCA L42WD22 42 in. LCD Television
How do i add chanels
In the menu with auto program OR direct enter channels with the remote and in the menu manually add them one at a time(most sets have a add or delete feature in menu for single channels).
May 16, 2012 | Sampo SME-32DL5 32" TV
Will not find digital tv stations
I'll be glad to assist you in locating the digital channels in the TV.
Make sure that the Cable or Antenna Input is connected to the TV. The Cable and Antenna input can be connected to the VHF/UHF Input on the TV. The TV can search for the channels only if the VHF/UHF/CABLE input is connected to the TV. If you're connecting the Cable box or the Satellite Receiver to the Video or HDMI inputs on the TV, then it is not require to auto program the TV. Here, the auto program may be required in the cable box.
To Auto Program the TV, select the Manual Channel Search option from the Menu option and then select the CABLE, AIR or Digital Add-On option depends on the connection. The Digital Add-On option adds any new digital channels that are found to the Channel Scan Database.
This should resolve the issue. Please feel free to get back to us for further assistance.
Thanks for contacting FixYa.
Aug 04, 2011 | Sanyo DP46848 LCD TV
How t o retune sony-hxd 890 after switchover.some channels missing.after pressing menu no info on screen.
You should be able to go into the menu and select auto tune. If you still dont get the channels you thought you had you unfortunatly have to do it the hard way and program by remote. This should be an option under auto tune or may even s be said as add channel on some models.
Jun 21, 2011 | Televison & Video
My tv's channels are only up to ch 35, and we have cable tv connection. I cant utilize my cable connection cause my tv's only programmed up to 35. do we have a way to program it to go up to more than 35?...
I assume you have analog cable TV service and no cable box. Press MENU button on your TV remote. Go over to CHANNEL SETUP. There are four arrow buttons and a button in the middle of the arrow buttons on the TV remote control. Use these arrow buttons to go up, down, left and right. Use the button in the center to select. TV On-screen menu has Video, then Audio, then Channel Setup.
Cable can be set to ON or OFF, you want to set it ON to get cable channels.
Go down to AUTO PROGRAM and select it, press button in the center of arrow keys.
A short delay while available channels are searched so be patient. After Auto Program finishes, press MENU to exit. You can perform Auto Program whenever required.
You can also add or skip channels manually. You will discover more options in the TVs menus.
Feb 24, 2011 | Sony FD Trinitron WEGA KV-36FS320 36" TV
I lost the remote control unit and i need to program the channels for catv. how can do it with the existing buttons ?
Most of the buttons on your remote should be on the TV too,at least the important ones.Look all around the edges for them,top,sides,bottom.To program the channels,press the menu button and search around for channel searching options,perhaps auto-search or antenna.If you auto search,you can get rid of channels you do not want(I dumped c-span and a couple others)by going to that channel after the search,press menu,and you will have to fish around a little because it slightly varies between brands,but eventually there will be an option to add/delete the channel.The channel button or volume button will allow you to add/delete.
Since you did not list your brand and model number,if you send it to me I could check out how much a new one is.I would guess at least $60 though. Good luck!
Jul 27, 2010 | Televison & Video
No channel 3, the tv goes from channel 2 to 4, can't use the cable box
Two options...
1. Connect the Cable Box via RCA cables (Yellow/Red/White) or Component cable if you have a HD cable box and select the appropriate input on the TV to view your programs. This will provide the best picture quality as well.
2. Make sure the cable box is on. Using the original TV remote type in the channel 03 and if this tunes to the channel then go to the TV menu and then go to Set up and then select add/erase and select add.
If typing 03 did not tune in channel 3 then using the TV remote select menu then go to set up and then make sure TV / Cable is set to cable then on the cable box press the channel button a couple of times and then select auto program on the tv.
Jan 03, 2010 | Toshiba 27AF44 27" TV
Dont know how to do a channel scan on my samsung 2333hd t.v
Using the Color buttons on the Remote with the Channel List.
• Red (Antenna): Switches to Air or Cable.
• Green (Zoom): Enlarges or shrinks a channel number.
• Yellow (Select): Selects multiple channel lists.
• TOOLS (Option): Displays the Add(or Delete), Add to Favorite(or Delete from Favorite),
Timer Viewing, Channel Name Edit, and Auto Program menus..
Auto Program
The TV automatically cycles through all of the available channels and stores them in memory.
In rare cases, "Auto program" may miss a few channels due to weak signals and the channels may
not be added to the channel memory.
Air
Cable
Auto
MENU → arrow up, arrow down→enter → arrow up, arrow down→enter →arrow up, arrow down →enter →arrow up, arrow down, arrow left , arrow right →enter → MENU,EXIT.
Hope this helps. I have the owners manual on file.
Sep 01, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
How do you program the montgomery ward model number jsj12248 televsion so that you get more channels?
Hi, jsj means it`s built by sharp, you need to auto-program the set, push menu on set or remote and look through the menu settings for either auto-program or add channels , gl, video-tek
May 17, 2009 | Televison & Video
No channels on list
You have to search for the channels. Go to your setup menu, and go to setup, then select TV, then do auto channel search. It may or may not have to be set on tuner to get to the TV options.
Jun 30, 2008 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
