Question about Garden
Forward pedal went to floor. tractor will not move
Forward dropped to floor now the tractor will not move
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
Sounds like the actuating rod may have come loose from the transmission. The foot pedal is connected to the transmission by a small rod called the actuating rod. The rod is held into place by a couple of spring clips.
Posted on May 06, 2015
Replaced drivebelt on troybilt riding mower now the forward pedal moves mower in reverse?
Sounds like you have the belt running in the opposite direction. You need to Change the way the belt is routed around the pulleys
Jun 18, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Depress drive pedal forward or reverse, tractor will not move
Assume it's a hydrostatic transmission - most probably the drive belt has come off or broken. Be sure to replace it with a Kevlar belt as changing the belt isn't easy and you don't want to have to repeat the process too soon.
Apr 19, 2014 | Cub Cadet Garden
Husqvarna 2754GLS, Hydrostatic forward/reverse pedal will not return to neutral position.
Parts and Diagrams for Husqvarna 2754 GLS 96043004700 2008 01
I suggest following all the safety procedures suggested in the operators manual first!
ENGINE NOT RUNNING,wheels blocked to prevent being run over, check the return spring ref # 161
Apr 12, 2014 | Husqvarna Garden
John deere sabre 2354 hv moves slow forward, even slower in reverse
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
Mar 23, 2013 | John Deere 420,1020,2010,2020,2510,2520...
My John Deere 4310 compact tractor hydrostat transmission does not work. I got on top of a tree stump and now it will not move. Trouble code light flashes one long then three short flashes. Please help.
You likely knocked a wire out of the forward or reveres potentiometers,which are located under the right floor pan and are attached to the foot pedals.If they are in place then they may have bee hit and now need to be re-calibrated,if so call your J.D. dealer.
Jun 14, 2010 | John Deere 4020 Gas & Diesel Tractor...
Will not go forward or backward
SOME JD TRACTORS HAVE A FREE WHEEL VALVE THAT TAKES THE TRANS OUT OF GEAR SO WHILE YOUR PUSHING OR TOWING IT WILL NOT HURT THE TRANS. THERE SHOULD BE A LEVER THAT YOU PULL OR PUSH TO REINGUAGE THE TRANS
Sep 20, 2009 | John Deere 420,1020,2010,2020,2510,2520...
The drive pedal is stuck forward and wont budge along with the brake pedal...
Drop mower deck and have a look.
Both rods run to the rear on the right side.
Possibly something interfering.
Jun 17, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
