Question about HP Photosmart 5520 e-All-in-One Wireless Photo Inkjet Printer, Copy/Print/Scan
Printer has suddenly quit printing Black. Have been thru the various trouble shooting notes,to no avail.
Have even uninstalled and reinstalled, with negative results. All inks are fresh. Has the printhead packed in?
    New Friend:
I cleaned my printer head via the machine and manually. Ended up buying a new printerhead and now can't get ink system failure error message to go away to give me the LED screen. 7500a
Posted on May 07, 2015
    Genius:
  • 1,585 Answers
Try a good clean to printer head
Posted on May 03, 2015
  • Alan Slater
    Alan Slater May 04, 2015
    Have done 6 cleanings in a row, with no effect.
HP LaserJet 4L quit working It's connected to my PC and it's on. All 4 lights are on; 2 green and 2 orange. When I try to print, the paper goes through but nothing is printed on the paper.
Empty cartridge maybe?
Otherwise it's simple: selt-test page(by printer button) printed ok - it's outer problem. Self-page is blank - it's inner problem. And so on... use Golden Section method
Jan 10, 2014 | HP LaserJet 4L Printer
Blank pages with HPC3180
Hi Julie,
First of all, make sure the alignment is complete. As you should be knowing, it prints a colorful sheet whenever you replace the cartridges.
IF you are not able to print from PC, It could be due to corrupted Drivers. You have to uninstall the software and reinstall.
Regards,
Sean
Feb 26, 2013 | HP Photosmart C3180 All-In-One InkJet...
Printer is too slow to print once the command is given from PC
Hi
While printing from the USB Port sometimes slow printout/data transfer will result in slow printing of print jobs. or The printer might be printing slow , pausing in between print jobs , or intermittent printing. The symptom solution is mention below, read and follow the instruction.
Solution 1
After the printer is installed on the USB Port, check the description under the Ports Tab what is selected. Please refer to the figure below : c00873625.jpg Using the USB/ Virtual Printer Port and DOT4/ HP Laserjet 2420, under the Port/Description Tab printer speed will be as per the standard. Whereas using the DOT4/ Generic IEEE 1284 under Port/Description Tab, Printer speed will be very slow. If DOT4/ Generic IEEE 1284 is selected by default, then you have to uninstall the USB driver from the Device manager and plug in the USB cable again. Then it will detect the printer and USB port with respect to the printer model. Insert the Driver CD as prompted and by default it will select the DOT4 HP LaserJet2420 Port.
Solution 2
  1. Insert the HP LaserJet 2400 print series CD-ROM.
    NOTE: If the HP Software does not automatically start, click Start , Run , and then Browse . Browse to the CD-ROM drive at the top of the window under look in and select Setup.exe .
  2. Select Modify Installation . Figure 1: Modify Installation c00369540.gif
    NOTE: If Modify Installation is not available See Modify Installation is not Available.
  3. Select the Language of your choice. Figure 2: Select Language c00369541.gif
  4. Click Next. Figure 3: Setup Wizard c00369542.gif
  5. Verify Reinstalling an existing printer is selected. Under Select the port for this printer , choose USB001 or Dot4_00x and click Next . Figure 4: Choose Port c00369543.gif
  6. Select desired Features and click Next . Figure 5: Select Next c00369544.gif
  7. Click Finish . Figure 6: Select Finish c00369545.gif
Uninstall options
  • First verify if an uninstall options is available. If an uninstall option is available under Start, Programs, HP LaserJet 2410 2420 2430 , use this method to uninstall the printer.
God Luck
Sep 09, 2011 | HP LaserJet 2420 Printer
P703w Printer: My printer all of sudden quit printing in black. ...
Guest
If you are having trouble with your black not printing you may need to reseat the print head. The link below will take you through the process of reseating the print head.
http://www.fixya.com/support/r5947644-reseat_print_head_dell_photo_p703w_all
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
May 18, 2010 | Dell P703w Printer
Epson Stylus CX 4200 won't print color copies of anything
Uninstall the printer software.
Restart your computer.
Download the latest drivers and software for the printer.
Load the software.
Part of the software could have corrupted itself...
Jun 11, 2009 | Epson Stylus CX4200 All-In-One InkJet...
Epson C66, new color cartiges, only prints black
try go to your start/printers and fax
then right click on your printer.
then select printing references
then click on paper/quality tab
then choose color
Hope it helped
Mar 19, 2009 | Epson Stylus C66 Photo InkJet Printer
Printer has suddenly stopped printing envelopes
Just fixed it thanks to Lloyd at Lexmark.com Go to Technical Support > LIVE CHAT. To print envelopes all I needed was to check the print in "Black" only button. Under Quality make sure the Print Color images in Black box is checked, select Apply and OK.
Jan 16, 2008 | Lexmark X5150 All-In-One InkJet Printer
Job stopped!
hey wildd, Try unplugging the printer from the electrical source for "several" minutes. Shutdown the computer too. Turn on the printer, then turn on the computer. If that doesn't work go the whole mile. Uninstall all printers and software. download the latest drivers from Epson. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=23952&infoType=Overview This link is to the epson site and your machine. Download the drivers from here. Have you had any paper jams lately? Make sure there aren't any pieces of paper stuck or any other debris. How about the print properties, or open print jobs? what does it show when the job stops. Let me know what happens. Good Luck, Tim
Mar 13, 2007 | Epson Stylus C64 InkJet Printer
HP Photosmart 5520 e-All-in-One Wireless Photo Inkjet Printer, Copy/Print/Scan Logo
228 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
