Question about Whirlpool Refrigerators
The red light is flashing in the freezer and the ice maker is not working? Any suggestions
    Master:
  • 969 Answers
Replace filter.
Posted on May 03, 2015
The ice maker has stopped making ice. The red light is flashing (in the freezer. Part ot technician?
Hi, The blinking red light is just a sensor that shuts down the ice maker when the door is open so that it will not dump. This should have no effect on why the ice maker is not working unless the little door that blocks the beam does not return when the door is shut again...
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Oct 02, 2010 | Whirlpool Refrigerators
The ice maker has stopped working. The light inside is flashing red. I checked the manual and nothing is stated about the red light flashing in the troubleshooting section. I've checked the lines and...
this sounds like a control board circuit problem..but first remove perishables and defrost freezer ..turn off or un plug..leave refr door closed..freezer door open..if you have lots of water while defrosting you almost cirtainly have froozen the evap coils solid..freezer cannot work like this..after defrost..plug in and see if temperature returns to normal..if it does it won't last indefinately..your probably have a bad defrost timer and/or evap heater gone bad
Apr 22, 2010 | Refrigerators
The freezer and the fridge are not on but the
flashing light stating that its too warm .. compressor probably is not running / power is ok or lights would not be on . look for a bad relay . somethes you can here clicking in back.. that is the comp trying to start .**** hop this helps you mmm leave feed badk pls .
Dec 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker stopped working, red light is flashing, however water is working? What is the problem, how do I fix?
For the red light try removing or replacing your filter.
The ice maker usually has a make ice bar about it inside the freezer. The down position is usually on.
Dec 02, 2009 | Kenmore 23.1 cu. ft. Side-By-Side Counter...
Icemaker not working- red light flashes constantly
The red light should flash twice , pause then flash twice constantly . If you close the flap on the left side , then the light should go off . This shows the optics (ice maker cut off ) are good .
Check the black tube ( fill tube ) , which puts water into the ice maker , to see if it is iced inside . If so , then the water valve behind the refrig is bad . It seeps into the tube and freezes , blocking the water flow .
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then the water valve needs replaced . If it doesn't dump , and stays frozen in the ice maker , replace the ice maker . Also , make sure the coils under the front of the refrig are clean , as this will cause warmer temp in the freezer and the ice maker needs 5 degrees to operate .
Sep 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side by side Ice maker has quite making ice
Open the freezer door and on the right side , make dure the slide is in the on position . If the red light flashes twice , then pauses , flashes twice , pauses , consistently , then close the flap door on the left side of the freezer . The light should go off . If these tests work , then the cut-off optics are good , and the icemaker needs replaced , due to the cubes not dumping . Also check the coils under the front of the refrig , to make sure they are clean of dust , lint , etc.
Sep 15, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker not working
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
May 30, 2009 | GE Profile PSW26P Stainless Steel Side by...
Flashing red light on ice maker control unit inside freezer
I understand the price seems pretty high have you tried an OEM for a better price. I am understanding that your filter is a common filter 4396510 I think is the aftermarket number
Apr 15, 2009 | Refrigerators
Ice maker not making ice.
These Icemakers have plastic gears on the modules that are breaking, also some have thermostats that are malfunctioning. I recommend haveing an experianced tech look at the unit to see if you need the new upgraded indoor ice maker.
Jan 14, 2008 | Kenmore 21.7 cu. ft. Top Freezer...
Refrigerators Logo
46 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
