Question about Garden
Pump shut off and will not get back to capacity
    Top Expert:
  • Garden Master
  • 42,120 Answers
Clean out the pump inlet and around the armature in the pump
remove ant threads jamming the end of the armature in the case.
Posted on May 03, 2015
PHONE SHUTS DOWN UNEXPECTEDLY
To me - it sounds like a battery fault.
Symptoms of a failing battery:
* Device suddenly shuts off, even when the battery have several percent remaining.
* Device drains fast, even when not used.
* Device might just shut off for no whatsoever reason when doing something that draws a lot of power, and will restart just fine.
* Device has a surprisingly fast charge time from empty to full.
If you said yes to those, grab a new battery.
But beware:
There are many fake batteries out on the market, claiming that they have higher capacity, yet very slim in size.
There's a simple rule when it comes to battery capacity:
More capacity = larger in size, which might need a special back-cover. There's no escape from that.
If one would happen to find a such incredible slim battery with super capacity, the battery security circuits and/or chemical makeup probably have been circumvented/changed, and have a high risk of catching fire and/or explode when charging/discharging.
Dec 03, 2013 | Sony Ericsson XPERIA X10 Cell Phone
I have a flotec 1 hp pump. Wife washed 3 loads of clothes in a row and noticed we run out of water a while later. I shut pump off and noticed pressure tank low on air. I put 18 lb. air in tank and...
If in the past your system can build-up pressure up to 40 psi even if the supply valve is open and water is being used in your house, then your pump impeller maybe already worn out that's why its pumping capacity was reduced.
Nov 12, 2012 | Flotec Corrosion Resistant Shallow Well...
When turning on dishwasher it just fills the base with water, tried manually draining and pressing reset buttons to no avail
Most dishwashers kick on a valve to fill with water.
There's a float in there somewhere that triggers the shut off to the filling water.
Once water reaches this cut off level the pump should be throwing water thru the wash arms.
If base isn't filling to capacity...Id look to the drain valve.
If it fills to capacity and stops...the pump may be out or something is obstructing it.
Hope this helps...
Jul 30, 2011 | Neff 24 in. S5453X1 Built-in Dishwasher
Bought a Delonghi dd50pc dehumifier last week for my basement and I have the hose going uphill and out a window but the pump always shuts off after 3-4 minutes, filling the tank instead. Now when I lay...
You really answered your own question. The pump in the dehumidifier only has so much water lift capacity. By trying to run it up and out, you have exceeded the maximum lift capacity. Using a floor drain or even a bathtub drain in the basement will probably work, as long as the hose is not to long.*
However, if you can use a floor drain, there's no need to use the pump function. You can use the continuous drain on the back of the unit. using the drain hose provided for that application.
*The 13 ft lift capacity noted in the Owner's Manual includes whatever length of hose you're using to get to the window. As there is some friction loss involved. But, they fail to point that out.
Hope this helps you and thanks for choosing FixYa.
Jul 27, 2011 | DeLonghi DD50P Dehumidifier
What is the oil capacity of the 2006 roadstar silverado?
The Road Star takes 4.3 qts which is 4.07 liters.
In my experience, MOST Yamaha engines have the oil capacity stamped either near the oil filler cap, or if it has one, near the fisheye inspection glass.
The best advice I have seen to date states the following: Having replaced and tightened the drain plug, remove the dipstick and puur in half the oil. Note that this bike has an oil tank, so having added 2 litres or so, put the dipstick back in and tighten it. Start the bike and allow it to run for around 15 seconds to allow the oil to pump from the oil tank to the engine crankcase. Shut the bike off and add the remaining oil before replacing the dipstick again and checking for leaks.
Hope this helps. Please rate this solution
Jul 18, 2011 | 2005 Yamaha Road Star Midnight Silverado
Dryer shuts off too soon
Probably has to do with door lock mechanism or the drain pump. Does the machine dispkay any error codes like F02 or Dr?
Dec 01, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
My 2004 cummings diesel starts & stalls I replaced the fuel filter canister type and truck was fine. Now it shuts off and restarts after sitting a while?
the engine is starved for fuel,are you sure you put on a big enough capacity fuel filter,they come in different capacities,or you could have a pin hole in the line somewhere letting air into the system,or the fuel pump could be getting weak,you can test this with a fuel pressure tester
Jul 14, 2010 | 2004 Dodge Ram 3500 Truck
Similar problem as ddmarra
If pump starts and shuts down then you can hear a click after about a minute or two it is probally your windings and you will need a new motor.
Jul 11, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Fuel filter or fule Pump?
i,d say start with filter first. if it was the pump it wil not run pump work or dont work
Apr 08, 2009 | 2003 Mitsubishi Outlander
I have a 1/2 hp pump which I use to pump lake water to my irrigation system. The pump takes too long to turn on when the spicket is opened and sometimes too long to shut off when the water spicket is...
when using the spicket you use less flow than your irrigation system so a delay in the pump coming on is normal...otherwise if you are having the same problem when the irrigation is running..a pressure switch adjustment may be necessary...please follow the manufacturer instructions for your pressure switch.
Mar 31, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Garden Logo
200 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
