Question about Garden
Stopped running when shallow - Garden
    Top Expert:
  • Garden Master
  • 46,683 Answers
Pond pumps need water to run or the armature sticks to the magnet in the body of the pump
Posted on May 03, 2015
Shallow water pump keeps stopping
new pump --not big enough for the job
old pump --motor windings problem, faulty start run capacitor
I suspect that as the motor is 1/2 hp if will run good when there is a need for water but under pressure the pressure switch is set to high so the motor overloads and gets hot
Mar 24, 2017 | RTO Wayne 1/2 Hp Shallow Well Jet Pump
I have a Flotec shallow well pump. The motor is buzzing but it will not turn.
could be bad bearings,obstruction in impeller,low voltage,failing capacitor.
Dec 20, 2009 | Flotec Corrosion Resistant Shallow Well...
Pump stopped working while pumping
Yes, most motors are thermally protected. It is usually bi-metallic, and resets itself.
--W/D--
Aug 08, 2009 | Flotec Corrosion Resistant Shallow Well...
Cannot get more than 5lbs. of pressure from pump,need at least 15lbs to run irrigation
YOU MAY HAVE A LEAK DOWN STREAM CAUSING THE LOST PRESSURE. YOU MAY HAVE TOO MANY OUTLETS IN THE SYSTEM. IS YOUR INLINE FILTER STOPPED UP? DO YOU HAVE A PRESSURE GAUGE RIGHT AT THE PUMP WHERE YOU CAN SHUT A VALVE AND SEE IF THE PUMP IS WORKING LIKE ITS SUPPOSED TO? HOPE THIS HELPS, JODY
Jul 18, 2009 | Flotec Corrosion Resistant Shallow Well...
2008 vx110 waverunner... friend ran into shallow water (sand) where he said he got stuck (sand bar) light came on (probably overheat) and engine stopped... engine will crank but wont start..what to check?...
The damage that can result from overheating an engine would be piston seizure. Without the cooling water circulating around the outsides of the cylinders to dissipate the heat from combustion, the piston temperature rises higher and higher. As the piston(s) get hotter, they expand. Being aluminum, they expand more than the liner of the cylinder does, and eventually expand to a size bigger than the cylinder. That is when the seizure happens.
At this point, you need to do a compression test on all 4 cylinders. You should have at least 150 psi on each cylinder. Anything lower than that is indicative of a problem.
Jul 13, 2009 | Yamaha 12V Air Pump
Buick Century 2001 blower motor
Your blower resistor is bad. It is mounted under the passenger side dash behind and to the left of the blower motor. These things burn out short out causing the fan to run constantly and then they just fry and shut down the fan. It is a hard little ****** to get to and you need 1/4 inch ratchet, 6 inch extension a 1/4 inch universal joint and a 5 mm shallow socket and lots of patients. LOL
Dec 17, 2008 | 2001 Buick Century
Garden Logo
193 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
