Question about 1997 to 1999 Pontiac Grand Prix Ignition Lock Cylinder with Key
How do I take off the crankshaft - 1997 to 1999 Pontiac Grand Prix Ignition Lock Cylinder with Key
  • 3,462 Answers
NOT A HOME USER JOB.
Good Luck
Posted on May 29, 2015
Need torque sequence for main saddle bolts . 22 in total for a 2012 chevy Cruze ecotek 1.4l turbo
Special Tools
  • EN-235-6 Installer
  • EN-470-B Angular Torque Wrench
  • EN-658-1 Installer
For equivalent regional tools, refer to Special Tools.
  1. Install a NEW crankshaft position sensor reluctor ring?(1) and the 3?bolts?(2).
  2. Tighten the 3?bolts?(2) to 10?Y?(89?lb?in).
  3. Lubricate crankshaft, crankshaft bearings and crankshaft bearing cap tie plate with engine oil.
  4. Install the 4?upper crankshaft bearings?(2) and the crankshaft thrust bearing?(3).
  5. Install the crankshaft?(1).
  6. Note: The thickness of the sealing bead should be 2?mm?(0.0787?in).
  7. Apply sealing compound?(1) to the outer rim of the groove on the crankshaft bearing cap tie plate. Refer to Adhesives, Fluids, Lubricants, and Sealers.
  8. Note: The complete installation procedure should not take longer than 10?minutes.
  9. Install the 4?lower crankshaft bearings?(3) and the lower crankshaft thrust bearing?(4).
  10. Install the crankshaft bearing cap tie plate?(2).
  11. Note: Do not reuse the old bolts.
  12. Install the 10?NEW inner crankshaft bearing cap tie plate bolts?(1).
  13. Caution: Refer to Fastener Caution. Caution: Refer to Torque-to-Yield Fastener Caution.
  14. Tighten the 10?inner crankshaft bearing cap tie plate bolts in the sequence shown and to the following specifications:
    1. Tighten the inner crankshaft bearing cap tie plate bolts to 25?Y?(18?lb?ft).
    2. Tighten the inner crankshaft bearing cap tie plate bolts an additional 60?degrees, using the EN-470-B wrench.
    3. Tighten the inner crankshaft bearing cap tie plate bolts an additional 15?degrees, using the EN-470-B wrench.
  15. Install the 12?NEW outer crankshaft bearing cap tie plate bolts?(1) and tighten to the following specification:
    1. Tighten the outer crankshaft bearing cap tie plate bolts to 10?Y?(89?lb?in).
    2. Tighten the outer crankshaft bearing cap tie plate bolts an additional 60?degrees, using the EN-470-B wrench.
    3. Tighten the outer crankshaft bearing cap tie plate bolts an additional 15?degrees, using the EN-470-B wrench.
  16. Install the crankshaft position sensor?(1) and a NEW crankshaft position sensor seal ring?(2).
  17. Install the crankshaft position sensor bolt?(3) and tighten to 8?Y?(71?lb?in).
  18. Note: Lubricate the crankshaft rear oil seal.
  19. Install the crankshaft rear oil seal?(1) with EN-235-6 installer?(2).
  20. Use EN-658-1 installer?(1) to strike the crankshaft rear oil seal.
  21. My database showed this info. Only the inner 10 showed a sequence. The outer 12 didn't.
Feb 02, 2018 | Chevrolet Cruze Cars & Trucks
Is my crank sensor faulty, symptoms of a faulty crank sensor 2000 Rodio 3.2 L
Intermittent stalling. Another symptom commonly associated with a problematic crankshaft position sensor is intermittent stalling. If the crankshaft position sensor or its wiring have any issues, it can cause the crankshaft signal to be cut off while the engine is running, which can cause the engine to stall.
Symptoms of a Bad Crankshaft Sensor ' DoItYourself.com
www.doityourself.com/stry/symptoms-of-a-bad-crankshaft-sensor
This makes it an important part of your engine system; a bad crankshaft sensor affects not only the engine speed but also the fuel efficiency of your car.
7 Crankshaft Position Sensor Failure Symptoms ' DoItYourself.com
www.doityourself.com/stry/7-crankshaft-position-sensor-failure-symptoms 1 - Check Engine Light. This can be frustrating as the check engine light can obviously turn on for many different things. 2 - Cylinder Misfiring. 3 - Acceleration Hesitation. 4 - Intermittent Starting. 5 - Engine Vibrations. 6 - Backfiring and Stalling. 7 - Irregular Car Function.
Warning Signs of a Bad Crankshaft Position Sensor ' DoItYourself.com
www.doityourself.com/stry/warning-signs-of-a-bad-crankshaft-position-sensor Ignoring the symptoms of a bad crankshaft position sensor will result in rapid wear and tear of the various parts of the engine and will quickly lead to engine ...
Symptoms of a Bad or Failing Crankshaft Position Sensor ...
https://www.yourmechanic.com/.../symptoms-of-a-bad-or-failing-crankshaft-position-... Jan 6, 2016 - Intermittent stalling. Another symptom commonly associated with a problematic crankshaft position sensor is intermittent stalling. If the crankshaft position sensor or its wiring have any issues, it can cause the crankshaft signal to be cut off while the engine is running, which can cause the engine to stall. ‎Crankshaft sensor · ‎Car is stalling Inspection · ‎How Long Does a Crankshaft ...
Symptoms of a Bad Crankshaft Sensor - Buy Auto Parts
www.buyautoparts.com/howto/symptoms-of-a-bad-crankshaft-sensor.htm Problems you will run into when your crankshaft position sensor has gone bad.
symptoms of faulty crank sensor Google Search
Sep 22, 2017 | Cars & Trucks
How do you remove the crankshaft dumper pully?
Published: 11-May-2011
Engine - V8 4.4L Petrol - Crankshaft Pulley
In-vehicle Repair
Special Tool(s)
Holding Tool Crankshaft Pulley
303-893(LRT-12-080)
Adapter
303-191-03
Bolts and spacers
303-191-04
Remover, crankshaft pulley
303-588
Remover, crankshaft seal
303-D121
Installer, crankshaft seal
303-1100
Adapter - Crankshaft seal installer
303-1100-01 Removal
  1. Disconnect the battery ground cable.
    For additional information, refer to: Specifications (414-00 Battery and Charging System - General Information, Specifications).
  1. WARNING: Do not work on or under a vehicle supported only by a jack. Always support the vehicle on safety stands. Raise and support the vehicle.
  1. Remove the accessory drive belt.
    For additional information, refer to: Accessory Drive Belt (303-05B Accessory Drive - V8 4.4L Petrol, Removal and Installation).
  1. Remove the cooling fan shroud.
    • Release 2 clips from the cooling fan lower shroud.
    • Release and remove the cooling fan lower shroud from the cooling pack.
  1. Using the special tools, retain the crankshaft pulley.
  1. CAUTION: Under no circumstances should the crankshaft setting peg, 303-645, be used in the following operations, to restrain the crankshaft. NOTE: The crankshaft pulley retaining bolt will be very tight.
    Remove the crankshaft pulley retaining bolt.
    • Discard the bolt.
  1. Remove the special tools.
  1. Using the special tools, remove the crankshaft pulley.
    • Collect the locking ring.
  1. Remove the special tools from the crankshaft pulley.
  1. Using the special tool, remove the crankshaft front seal.
    • Remove the outer section of the seal.
    • Repeat the process to remove the inner section of seal.
  1. Check the crankshaft damper pulley and locking ring for damage.
Installation
  1. Clean all the crankshaft pulley mating faces.
  1. Using the special tools, install the crankshaft front seal.
    • Lubricate the seal with clean engine oil.
    • Use the discarded crankshaft bolt with the service tool.
  1. Install the crankshaft pulley.
  1. Install the crankshaft pulley locking ring.
  1. CAUTION: The screw thread in the crankshaft pulley must be cleaned out before installing a new crankshaft pulley bolt. Install, but do not tighten, the new crankshaft pulley bolt.
  1. CAUTION: Under no circumstances should the crankshaft setting peg, 303-645, be used in the following operations, to restrain the crankshaft. Using the special tools, retain the crankshaft pulley.
    • Tighten the crankshaft pulley bolt to 380 Nm (280 lb.ft).
  1. Install the cooling fan lower shroud.
  1. Install the accessory drive belt.
  1. Connect the battery ground cable.
Jan 27, 2016 | 2006 Land Rover Range Rover Sport
Where is the crankshaft position sensor?
    Pontiac G6 Crankshaft Position Sensors - AutoZone
    www.autozone.com/1/.../pontiac-g6-crankshaft-position-sensor...
    AutoZonePontiac G6 Crankshaft Position Sensors including Crankshaft Position Sensor - Duralast (SU8213), Crankshaft Position Sensor - Duralast (SU9540), Crankshaft ... images for pontiac g6 crankshaft position sensor
Oct 28, 2015 | 2006 Pontiac G6
I am changing the timing chain in a 1993 Chevy S-10 with a 4.3L engine. I was told you have to disconnect a wire to reset it but I don't know where the wire is.
Timing Chain: Service and Repair
REMOVAL
Tools Required = Crankshaft Sprocket Puller
1. Remove the timing cover.
2. Remove the crankshaft position sensor reluctor ring.
3. Remove the camshaft sprocket bolts.
4. Remove camshaft sprocket.
5. Remove timing chain.
6. Remove the crankshaft sprocket.
7. Remove crankshaft sprocket key.
INSTALLATION
1. Install the key into the crankshaft keyway.
2. Use the crankshaft balancer installer to install the crankshaft sprocket.
3. Install the camshaft sprocket and timing chain.
4. Install camshaft sprocket bolts.
Be sure to align the camshaft and the crankshaft sprocket marks. Timing marks (Number 4 Firing).
Tighten bolts to 21 ft. lbs.
5. Align the keyway on the reluctor ring with the key in the crankshaft.
6. Install the reluctor ring onto the crankshaft until the ring is completely seated against the crankshaft sprocket.
7. Install the timing cover.
Don't know what Wire you are referring to.
Jul 30, 2013 | Cars & Trucks
How do you know set the couiter balanceto the crank? TKS.
THE CRANKSHAFT VIBRATION DAMPER CRANKSHAFT THROWS AND FLYWHEEL ALL BALANCE THE CRANKSHAFT.IF CRANKSHAFT OUT OF BALANCE AND VIBRATION GOOD AND THE CRANKSHAFT THRUST BEARING NOT WORN.CRANKSHAFT COULD BE BEND.
Mar 21, 2011 | 1995 Toyota Camry
Is there a woodruff key that is located on the outside of the crankshaft that runs the timing chains?
The wood-ruff key is used to keep the crankshaft timing gear in place and on time with the crankshaft, and it does not matter if the engine has a timing belt or a chain because they both use a wood-ruff key to hold the crankshaft timing gear/cog in place on the crankshaft, and if the key is missing or it has been sheered off, then the timing gear will be able to turn on the crankshaft and the engine will loose the timing between the camshaft and the crankshaft. The wood-ruff key is located in a groove on the crankshaft, and the timing gear/cog has a notch cut into it so that it will slide onto the crankshaft and over the wood-ruff key locking the timing chain gear/cog into that position on the crankshaft.
Sep 13, 2010 | 2001 Oldsmobile Aurora
Bolt on crankshaft to remove clockwise or counterclockwise?
prev.gif next.gif Crankshaft Damper/Pulley counterclockwise to remove pulley:
REMOVAL & INSTALLATION
  1. Remove the drive belts from the crankshaft damper.
  2. Remove the crankshaft damper-to-crankshaft bolt. Hold the crankshaft stationary by placing a suitable tool in the ring gear teeth on the flywheel. Fig. 1: Use a breaker bar to remove the crankshaft damper bolt 89613g41.gif
    Fig. 2: The crankshaft can be held stationary by using a suitable tool to place between the flywheel teeth 89613g42.gif
    Fig. 3: Be sure to lubricate the threads of the crankshaft damper bolt to obtain a proper torque reading 89613pi9.jpg
  3. Remove the crankshaft damper from the crankshaft by pulling it straight off the shaft. A puller may be required to remove the damper from the shaft. Be careful not to lose the woodruff key when removing the crankshaft damper. Fig. 4: The crankshaft damper can sometimes be pulled from the shaft by hand 89613pj1.jpg
    Fig. 5: A puller may be required to remove the crankshaft damper 89613g40.gif
    NOTE: If working on a VE30DE or VQ30DE engine, it would be a good idea to replace the crankshaft oil seal when the crankshaft damper is removed. Fig. 6: The timing chain cover oil seal should be replaced whenever the crankshaft damper is removed; this seal is leaking severely 89613pj2.jpg
    Fig. 7: This crankshaft damper may have a problem sealing properly due to the groove that was worn into it from the seal 89613pj4.jpg
    To install:
  4. Install the crankshaft damper onto the shaft, making sure the woodruff key is in place. Dip the damper bolt in fresh oil and torque the crankshaft damper-to-crankshaft bolt to the following specifications:
    • VG30E engine — 90–98 ft.lbs. (123–132 Nm.)
    • VE30DE engine — 123–130 ft.lbs. (167–177 Nm.)
    • VQ30DE engine — 29–36 ft.lbs. (39–49 Nm.) followed by 60–66°clockwise angle torque
  5. Install the drive belts to the crankshaft damper; be sure to properly set belt tension.
Jul 08, 2010 | 1996 Nissan Maxima
Jsut want to know where crankshaft position sensor
Hi!!
here are illustrations of the CKP (crankshaft position) sensor in 2.3L and 3.0L.
Note: In the bottom of the 2.3L drawing says Trottle Position (TP) Sensor, this is wrong, It should say CKP Sensor.
2.3L Engine
The Crankshaft Position (CKP) sensor is located to the left of the crankshaft pulley.
0996b43f80202990.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Crankshaft Position (CKP) sensor location-2.3L engine
3.0L Engine
The Crankshaft Position (CKP) sensor is located just behind the crankshaft pulley on engine block.
0996b43f8020299e.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Crankshaft Position (CKP) sensor location-3.0L engine
The cost of the sensor is $23 bucks at AutoZone.
If helpful, click below
Apr 15, 2010 | 2002 Ford Escape
Crankshaft key busted out broke crank key slot on one side.
sadly there is no fix but a total new crankshaft .
Jan 06, 2018 | Bending Branches Boating
1997 to 1999 Pontiac Grand Prix Ignition Lock Cylinder with Key Logo
61 people viewed this question
Top AM Auto Parts Vehicle Parts & Accessories Experts
geo marin
terry stevens
ray gallant
Are you an AM Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
