Question about Tools & Hardware - Others
How do you wire a gould pump j05n - Tools & Hardware - Others
    Master:
  • 371 Answers
Wire diagram 4 gould gt20
Wiring diagrams for pump motors are usually on the inside of the cover of the wire access cover or on the motor tag. If this is a 1/2 HP motor it could possibly be wired 125V or 250V. Be sure to wire for correct voltage.
Nov 06, 2014 | Goulds Pumps GOULDS GT20...
How to fix double starts from points kicking the breaker
If the breaker is tripping you need an electrician to check wiring, pressure switch shouldn't be a problem. Don't try to work your way around electrical, always remember the unit will last longer if electrical is running properly to unit.
Aug 31, 2014 | Goulds Pumps Goulds RGS2012PA -...
Gould water pump water pump will not shut off ,have replaced preasure stwich &GAGUE,HOLDING GOOD PREASURE
Does the switch click open, if so it is wired wrong. If not it is set to high.
Aug 15, 2013 | Goulds Pumps Plumbing
Goulds pump
check for air leaks in the connections our your pressure switch is bad
Apr 24, 2013 | Goulds Pumps Goulds GT15 - IRRI-GATOR Self...
I need wiring diagram for Gould Century Pump motor 1081 Part # 8-142776-20 1HP 230v/120v
www.bestbuypoolsupply.com/media/motormanual.pdf
This manual has the wiring diagrams both hi and lo voltage for
part # 8- 142776 -20 gould century 1081m 1 hp , pool pump motor 230/115 volts.... plus several similar motors
May 25, 2012 | Plumbing
I HAVE PROBLEM REMOVING THE IMPELLER ON GOULDS
GOULD ..OH BOY HERE WE GO... YOU MUST HOLD THE SHAFT AT THE BACK OF THE MOTOR WITH A 7/16 TAKE THE CAPACITOR OFF (LOOK AT HOW WIRES ARE ROUTED ) OR 1/2 INCH WRENCH THEN UNSCREW IMPELLER..
>BEST TO BRING IT TO YOUR LOCAL POOL PUMP MOTOR REPAIR GUY OR PUMP REPAIR ,USE YOUR ZIP CODE IN YOUR SEARCH.. DON'T TRY TO REPAIR THIS IF YOU BREAK IT IT WILL COST YOU !
May 20, 2010 | Garden
Will #14 be okay for 1/3 hp 115 volts about 120 feet
It depends on how many amps the motor is. #14 wire will handle up to 7 amps at 100 feet. If it is less than 7 amps it should be okay. If the wire gets very warm after running then you may have to go with #12.
May 07, 2010 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
I have a 1/3hp goulds pump not working i have changed the capacitor and the centrifugal switch but it still does not work; does not come on what must i look at next.
Check the continuity of the service wires. If they are good, check the resistance of the windings. You may have an open motor windings.
Jun 08, 2009 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
Tools & Hardware - Others Logo
101 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
