Question about Car Audio & Video
Have a ch1001 shaper image 100 cd changer stuck in Jammed mode? Tried powering off and unplugging. No luck! Help!
    Sergeant:
    Champion:
  • 219 Answers
There is usually a tiny pin hole at the front were you insert something like a paper clip that overrides the lock and allows you to pull the draw out manually.
Posted on May 02, 2015
  • 1 more comment
  • Toni Digiovanna May 03, 2015
    Thank you so much for your help. I found the pin hold and when pressed I'm getting ERR 115E Any suggestions?
    Thanks again!
  • Bob Bond
    Bob Bond May 03, 2015
    usually the pin hole is a manual override to get the door to the changer out, you do this with the power off & once you have disengaged the lock with the paperclip or thin rod, you tease the drawer out gently with the power off so you can retrieve the disc, & hopfully cure the problem before turning the power back on.
    Thanks again. But it's not a drawer per say. It's a vertical slot that slides to the left and allows you to load discs into slot. It's a standing juke box. I did try paper clip with power off also.
dj_relly999
  • 4070 Answers
SOURCE: 2002 Explorer indash cd changer malfunction 'cd error'
its an optical problem, you may try cleaning the lens or try replacing a new one.
Posted on Jul 09, 2009
SOURCE: Their is a CD stuck in my 2004 Dodge Durango VES
Had the same problem. Find a Bic pen, take it apart. The "plastic rod" which holds the ink is small enough to insert in the same slot as the CD. Insert it on the far left side of the player and jiggle it around. Then hit the eject button. I have had this problem twice and both times this solved the issue.
Posted on Dec 17, 2009
  • 306 Answers
SOURCE: jammed cds in a 6 cd changer ford ranger 2002
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Posted on Feb 06, 2010
SOURCE: Ford F150 with 6 disc cd changer that is stuck
I have the exact problem as of last week when my battery and altenator died. I tried to have it fixed at ford, but they said it was broken. Did you have any luck?
Posted on Feb 08, 2011
SOURCE: alpine cha-5624 cd changer
Need to order a 6disc container for CHA 5624;I lost the original:(. Tom H. Willett
Posted on Mar 05, 2012
DVD changer is jammed on my Panasonic Sa-pt770 Receiver
if you have 2 tiny screw drivers, if not, the tips of a butter knife might be skinny enough, you can try to insert them a wee bit into both sides of the tray and pry outward, carefully of course, and unjam the tray
Mar 09, 2013 | Panasonic Sa-pt770 Receiver Only For...
6cd cartridge is stuck in the interchanger in my bmw 5 series how do i get it out
Magazine-type CD changers have a common failure mode caused by a CD stuck between the player mechanism and the magazine. It may be necessary to resort to removal and some disassembly to get access to the stuck disc
Feb 14, 2013 | Car Audio & Video
Cd are stuck can not eject and cds will not play can hear motor trying to delete but it wont happen
Have you tried to unplug the unit. And leave it unplugged for about 10 minutes. If it is mechanically jammed this will not help. But if it is the firmware that is scrambled, then this will reset it. If it is mechanically jammed, then you might try tipping the unit on the back, then try ejecting it from that position. I would try clearing the firmware by unplugging and leaving for 10 minutes first.
Jan 19, 2011 | Car Audio & Video
Jammed cds in a 6 cd changer ford ranger 2002
Feb 05, 2010 | OEM Systems Car Audio & Video
1990 Lexus ls400 CD changer (in trunk) does not open.
probably cd stuck in it good luck getting it out best bet car radio store
Sep 20, 2017 | OEM Systems Car Audio & Video
How do I supply power to this cd changer?
Below is an image of Jack PCB inside unit and Fuse is marked that need to be checked.
Apr 26, 2009 | Sony CDX-602 10-Disc CD Changer
Clarion arx9270 error
Typically means the CD is stuck, has a reading error, or the magazine is stuck. If jammed, you'll have to clear the stuck CD which may require disassembly. Try removing power and rebooting.
If all else fails, I recommend contacting a local car audio professional, or you may contact Clarion customer support directly by clicking here:
https://clarion.com/xe/en/user-support/inquiry/contactus
I trust this information has proven beneficial.
Jun 18, 2017 | Clarion ARX9270
Cd jammed in mini cooper cd player.
decided to take car to dealers for them to fix on warranty.
Mar 28, 2008 | Car Audio & Video
CQ C5301U
can you check and see if plugged in or if power is getting to cd changer first, if so then check for jammed cds, in no jammed cd then reset system. should see some kind of reset on changer or radio and start over
Aug 15, 2007 | Panasonic CQ-C5301U CD Player
Car Audio & Video Logo
204 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
