Computers & Internet Logo
James Minor Posted on May 02, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Part # for the (2) CCFL backlight bulbs for Dell ST2410b Monitor? (Preferably already assembled, so no need for soldering)
I have a Dell ST2410b purchased new in 2009. What is the part # for the (2) CCFL backlight bulbs? A fast and secure source to purchase would be appreciated too...(Preferably already assembled, so no need for soldering)Thx!
danoyachtcap
Level 3:
Top Expert:
  • Dell Master 2,907 Answers
  • Posted on May 02, 2015
danoyachtcap
Dell Master
Level 3:
Top Expert:
Answers
2907
Questions
Helped
1274826
Points
52081
3helpful
My laptop screen will not say on for a normal time period. I change the inverter board but the screen still turn off. Why?
you are getting display when the backlight bulb of the monitor is working,when the back light bulb is going off you are not getting the display... in some computer the backlight bulb of the screen is the part of lcd screen assembly..your computer model has got one CCFL BULB WITH DISPLAY ASSEMBLY..The item number of your comput's lcd is - NXK702-0293,resolution-WXGA+(1440*900),type-Matte,backlight connector-2 pin,video signal connector- 30pin
Power supply to the screen backlight keeps going out
You may have a faulty inverter or defective CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
1helpful
My monitor on my Dell laptop went completely black while I was on it. I have tried turning it off and back on, and the monitor is not working at all
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
www.ladparts.net
2helpful
2answers
D600 Latitude laptop - LCD showing ghost/dim images
Connect an external monitor to your laptop and power it up, if you seethe normal Windows images then the video card and laptop is OK and theproblem is the backlight.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Dimimage and/or dark display on the laptop's LCD screen indicates a faultyLCD backlight and it could be the inverter that supplies high voltageto the CCFL lamp or it is the CCLF lamp is nearly burnt out or burntout, most likely this is the case.
Check out www.lcdparts.net for parts, repair service and DIY info.
Thank you Sir, Have a nice day.
My Dell flat panel monitor flashes on and off what can i do to fix it...
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Light bulb bad?????
You may have a faulty inverter or a faulty CCFL lamp.
A defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
1helpful
Need help for my Dell Inspiron 9400 Laptop
Try and determine what is wrong with your LCD screen first and you can then decide the best course of action. Follow these instructions to determine the fault and then check out LCD Parts WEB site for parts, replacement LCDs, service and DIY info..
You may have a faulty inverter or loose power inverter connection. OR
Check out
www.lcdparts.net
3helpful
My dell LCD does not work. computer work fine with external monitor. Some light came on briefly and it went dark again. I can see the deskdop with the flashlight in the background. I spend many hours talk...
You could have a defective screen - a defective inverter or a CCFL lamp, follow this to determine the fault.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
2helpful
Lcd screen black on laptop. External monitor works.
Defective CCFL backlight may has the following symptom:
1helpful
Monitor Problems
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
