Question about Garden
'99 4-stroke 70 HP starts great idles then put in gear and won't get out if idle speed ?!
  • 2,210 Answers
70 hp what?
Posted on May 02, 2015
2 Suggested Answers
  • 173 Answers
SOURCE: hi , my saw starts
It sounds like you are going to have to rebuild the carb or replace with new one.
Posted on Nov 24, 2010
Testimonial: "i decided to take apart the carb i dint have a carb kit accessible so did a good cleaning and put it back together .. i t now runs great .. thanks for putting me in the right direction ... cheers."
Runs and starts great but won't idle
Hi, Emmett and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Leaking accelerator pump.
4. Loose low-speed jet.
5. Plugged low-speed jet.
6. Contaminated or plugged low-speed circuit.
7. Enrichner valve is not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have nice a day.
Motorcycle Message Board Motorcycle USA
2 stroke dirt bike problem Won stay running Please help motorcycles
Honda 650 Won Idle
http://www.sportbikeworld.com/forums/179-atv-dirtbikes/30570-bike-runs-fine-wont-idle.html
Mar 21, 2016 | Motorcycles
70 HP evinrude 4 stroke outboard (pontoon boat). New spark plugs all connections good. Will only do idle speed put I. Forward or reverse won't gain speed
I had the same problem with mine, let me see if I can find the picture I took.
Just above the red arrow on the choke, the linkage has to be firmly clipped in that little black clip. Unless that is in place, you are only throttling one carburetor! Drove me crazy trying to find the answer to that one and it happened after the marina engineers had replaced a leaking fuel hose. Mine was a two stroke, but I bet the linkages are the same to the carbs.
May 02, 2015 | Boating
My 50 ho 4 storke was stored for over a year it started like a dream and idles great but when you advance the throttle to mid range it seems to de tune and misses like crazy until you bring her back d
It sounds like the high speed passages in the carb are gummed up. If you have not done so already, you should probably rebuild the carb.
Feb 08, 2014 | Boating
Lawnboy help
ck. governor linkage connections
Jun 18, 2013 | Garden
1987 60 hp mariner idle & high idle great, stumbles/ stalls in gear on take off, head gasket or poor idle adjustment?
Clogged idle circuits in your carbs. Clean jets and passages.
You can try suck dirt out, therefore: Screw the idle mixture screw out ( almost totally ), give full throttle ( 1 second ) and then hold your hand against the carb air intake.
This will give maximum suction and can suck the dirt trough tje circuits.
Also, first drain the carb(s) to be shure there is no water in it...
Aug 22, 2017 | Light Boating
Whenever i put my blazer in gear it dies
I'm assuming it's the 2.8, I'm not sure when they started putting the 4.3 V6 in them.
Anyway, a few things come to mind when something won't idle.1. EGR valves. If they are open at idle, it won't idle. It's open at cruising speeds when the engine is warm, but not at idle or full throttle.
2. Idle air controller (IAC): This is a little electrical valve located on the side of the throttle body. It regulates the amount of air that the engine needs to idle at the correct speed. It makes up for stuff like cold temps, being in gear, or having the A/C on at idle. They also get full of junk and jam up, or simply fail electrically. Replacement is extremely simple.
3. Ignition timing. If the timing is late (********), engine vacuum is lowered and it struggles to idle, even without the load of a transmission in gear.
4. Vacuum leaks. Crunchy old vacuum hoses make everything worse.
Apr 07, 2012 | Chevrolet Blazer Cars & Trucks
Two stroke weedeater starts,idles, but boggs down when gas is applied. it won't reach top end speed.
have a look on side of carby should see 3 small screws a high and a low idle screw , when running unsrew the high idle srew slightly and it should fix
Sep 18, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
I need to know the high and low settings on husqvarna35
Turn both jet needles CW to stops (lightly), then turn each screw out CCW 1-1/2 turns. This is a basic setting which should allow the engine to start and run. Start the engine and allow to warm up, then pull the throttle full on. Adjust H needle CW until the engine starts to speed up, but still 4-stroking. Proper final adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for better idle, but still allows the engine to 'follow the throttle'. Set the idle speed screw so that the chain stops turning, but the engine will continue to idle. Hope this helps!
Jul 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a 572 crate motor 620hp. Car runs great on highway.But if i get at low rpm or traffic and come to stop car wants to stall. Seems like carb is problem . I see you changed to holleys Why? Is this a...
Try setting the idle speed up a little--the racing cam in this engine will not allow idle very well at best. An improvement in the ignition system performance will help starting. This engine wasn't made to poop around in traffic.
Sep 07, 2009 | Chevrolet Chevy Cars & Trucks
93 Lincoln Conti. Runs rough in gear
Probably a bad idle air motor, it controls idle electronicaly
Aug 30, 2009 | 1993 Lincoln Continental
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
