Question about Garden
Oil is coming out at the air filter on my mower
  • 2,027 Answers
Do not tip the mower over when you clean under neath as well as it will mess things up as well.
Posted on May 02, 2015
    Problem Solver:
  • 18 Answers
You have overfilled the engine oil.
Oil leak on my riding mower where it could be coming from?
could be from a sump problem and blowing oil out of the air filter inlet hose
Sep 07, 2017 | Garden
I have a Toro lawnmower oil is coming out on the filter side of the lawnmower...what could be the problem
1) has the mower been turned on its side recently?
2) Oil level? too full? gasoline smell ?
3) Replace the air filter
4) When cleaning mower, always keep the air filter up. Turn it on its left side.
Mar 29, 2017 | Toro Garden
A lawn mower that gas comes out of the exhaust.
It sounds like the float in the carburetor is stuck in the open position.This will allow fuel to flow through the carb and out the muffler.
May 04, 2015 | Garden
Cub cadet 1440 oil all over engine, in carb, and plugs come out black with oil all over them
Is it coming from the Breather hose? try taking out the air filter and see if that stops it. If air filter is clogged , it will cause Crank Pressure.
Also check oil level if too high it will do this. Sometimes the carb will let gas past and into crankcase filling teh crankcase above 'Full' mark
Sep 25, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Overfilled lawn mower and now it is will not start.and when i try to start it it start for 2or 3 sec and stall out and oil come out of the exhaust.
Overfilled with gas or oil? More in likely you tilted your mower over to far to the air fllter side. The oil has soaked your air filter with oil. Change the airfilter and wipe spark plug off.Once it fires up it will smoke untill it burns the oil out carb. Remember never lean mower to air filter side..Good luck
Aug 17, 2013 | Garden
Replaced blade and now oil coming air filter
If you have tipped the machine on its side rather than tipping back on the handles, the engine oil will spill from the engine breather and be fed into the back of the air filter box, you now need to remove the filter cover and filter, run the engine until the smoke clears, if the air filter ia a paper cartridge yo will need to replace with a new filter.
Jun 13, 2013 | Husqvarna Garden
Lawn mower throwing oil from muffler
If the mower has been tipped it will have sent oil up the breather and into the back of the air filter box, this will soak the paper filer and smoke badly, remove the air filter cover and filter, run the engine with these removed until the smoking stops, now replace the filter with a new one, when tipping the mower only tip it back on the handles, not from either side.
Jul 07, 2012 | Briggs & Stratton Garden
Oil coming from line from engine feeding into air
More than likely your air filter is clogged and needs replacing. If that is the situation the carb needs air and is pulling suction on the crankcase breather tube siphoning up oil instead of just burning the vapors. If it was a busted ring the oil would be coming out the exhaust and burning blue smoke.
May 01, 2010 | Mtd 22" Yard Machine Push Mower
Oil leaking from air filter area of push mower and mower smoking
You have overfilled the oil tank. White smoke is only a hassle, not a serious problem. You have to empty some of the oil and change the gas. Clean the air filter if it is the spongy type with Dawn Dishwashing Liquid, rinsing and drying it well before reinstalling. The white smoke will stop soon as it is still in the gas that is in the carb. If the case is that you haven't filled it with oil prior to this smoke then you must be mowing on a hillside and the gas tank was on the lower side allowing oil to leak into the gas. Same solution.
Jun 24, 2009 | Poulan Garden
Oil coming out of my champion lawnmore r484
you likely will need a new air filter and a carb cleaning. when mowers are turned on their side. oil will seep past the piston and if your intake valve was open it can pass thru into the carb and also spoil your air filter. I am assumeing you have a paper air filter. start by taking off your air filter. then you should also pull the spark plug, place a rag covering the hole. then pull the cord a couple times. chances are that you will blow the oil out of the cylinder. I would recommend a oil change.
Apr 08, 2009 | Garden
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
