Question about Dryers
Changing dryer belt
Filter is in the front and most instructions show a top filter. How do I dismantle to change the belt?
    New Friend:
  • 30 Answers
Through the rear if it's a front loader
Posted on May 02, 2015
The belt attached to the blower wheel on my Whirlpool Cabrio dryer has come off. How do I reattach it?
Unplug the power cord of the Whirlpool dryer from the electrical outlet before installing a new belt. Remove the lint filter from underneath the lint filter cover. 2 Unfasten the screws underneath the lint filter cover with a screwdriver, setting the screws in a safe place. Slide a putty knife between the dryer top and the cabinet near the front, lifting up on the knife to detach the top from the plastic clips on the cabinet.3 Flip the dryer top back against the wall so it is resting on the rear hinges. Locate the screws on the inside of the upper front panel near the top.4 Unfasten the screws on the inside of the upper front panel with a screwdriver. Lift the panel up off the metal clips on the front of the dryer cabinet. 5 Unplug the door switch connector from the back of the upper front panel by hand, setting the panel out of the way. Slide the putty knife between the lower front panel and the dryer cabinet, pulling the knife away from the cabinet to detach the panel from the plastic clips on the cabinet.6 Place a couple of wood blocks under the lip of the dryer drum to hold it in place. Locate the idler arm near the motor at the base of the dryer.7 Move the idler arm forward to relieve the tension on the belt. Take the belt off the motor and idler arm pulleys, lifting the drum up and sliding the belt off the drum.8 Install a new belt around the dryer drum, looping it over the idler arm and around the motor pulley. Move the idler arm back into position to add tension to the new belt.9 Remove the wood blocks from underneath the lip of the dryer drum. Plug the door switch connector into the back of the upper front panel by hand.10 Slide the upper front panel over the metal clips on the front of the dryer cabinet, securing the top of the panel with screws. Fasten the lower front panel to the front of the dryer cabinet, pressing the panel onto the plastic clips by hand.11 Flip the dryer top back down onto the top of the cabinet, pressing down to secure the top to the plastic clips on the cabinet. Fasten the screws underneath the lint filter cover with a screwdriver.12 Slide the lint filter back under the lint filter cover by hand. Plug the power cord of the Whirlpool dryer into the electrical outlet.
  • Oct 11, 2011 | Whirlpool Dryers
    How do I change the drive belt?
    Unplug the dryer.
    Remove the lint filter.
    Remove the 2 screws at the lint filter opening.
    Use a putty knife between the top lid and the front panel to release the clips.
    They are about 2 inches in from right and left sides where the top meets the front panel.
    Lift the lid towards the rear of the dryer.
    Look inside the top right and left corners of the front panel and remove the screws holding the front to the cabinet. Remove the door switch wires and set the door aside.
    Place the new belt over the drum,ribbed side towards the drum.
    Look under the drum for the belt tensioner. It is S shaped with a wheel on it.
    Place the base of the tensioner in the slots below the motor pulley.
    Feed the right side of the belt through the opening under the wheel with the smooth side of the belt touching the wheel.
    Place this side of the belt over the motor pulley with the ribbed side touching the pulley.
    Replace the front panel.
    Hook up the door switch wires.
    Replace the panel screws.
    Reattach the top lid and lint filter screws. Replace the lint filter.
    Plug in the dryer.
    Jan 03, 2010 | Kenmore Dryers
    Kenmore dryer squeeling
    FIRST ALWAYS UNPLUG THE MACHINE ANYTIME YOU WORKING ON IT ,
    it sounds like if you can see some black dust you have bad wheels i will suggest to replace the drum wheels.the belt an the tensioner since you can get all of them for under 40 dollars IS CHEAPER IF YOU ASK FOR A DRYER KIT .
    is worth to do it all since you are there, in order to open it you have to take the 2 screws off the top (filter panel) remove the filter panel, then you may need to use a putty knife to pry the top open (front of the machine top cover an front cover you will see the clips maybe 3 inches away from the corner, then one open remove the front panel 2 screws 5/16 lift an tilt the door an your in, lift the tensioner an remove the belt from the motor, lift drum an remove it then ur in,,,,,,,to assemble follow steps back n ur done!
    May 18, 2009 | Kenmore 83142 Electric Dryer
    Heat cycle stops/goes off
    1. Changing from 3 to 4 wire hookup on a electric dryer
    2. Door switch replacement help for a common door switch
    3. Dryer basics - Venting problems and power supply
    4. Dryer basics - timers and how they work
    5. Dryer basics - power cord problems
    6. Dryer basics - dead dryer
    7. Dryer *general* repair flow chart....Click here
    8. Gas dryer smell
    9. How do dryer thermostats work?
    10. How long can my dryer vent be in length?
    11. How to change a common rear drum seal
    12. How the belt is suppose to look at the motor and idler pulley
    13. Help on replacing dryer motor and some wiring tips for the 279827 motor
    14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
    15. Help for storing an appliance
    16. Important Disclaimer
    17. I dropped something down the lint filter area....help!
    18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
    19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
    20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
    21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
    22. Inglis, Whirlpool and Kenmore electric element changing procedures
    23. Inglis, Whirlpool and Kenmore dryers - air flow
    24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
    25. Inglis, Whirlpool and Kenmore style dryers - belt change
    26. Inglis, Whirlpool and Kenmore dryer general motor problems
    27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
    28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
    29. If your drum belt looks like either of these....change it!!
    30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
    32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
    33. Pilot flame help
    34. Sample wiring diagrams
    35. Test for ohm meter checking on electric dryers with no heat
    36. Taking apart an Duet or HE3 dryer for a belt change
    37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
    38. Timers and some common Auto dry troubles and solutions
    39. What is a grounded element?
    40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
    May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
    Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
    8. Gas dryer smell
    19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
    Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
    Change rollers
    Hello, Unplug dryer from wall remove filter at top remove 2 screws under the filter, take flat screw driver pry top up on both sides at the front. With top up remove 2 screws that hold the front panel to the cabinet now the front panel can be put to the side. release tension from belt and remove the drum. Now the rollers are right in the rear and they support the drum. change rollers and reassemble. good luck
    Dec 26, 2008 | Kenmore 63942 Dryer
    Install dryer belt
    more information needed to specifcally match the model
    however dryers are all similar so
    generically, UNPLUG dryer
    A:top mounted lint filter (kenmore maytag(New))
    • remove lint filter
    • remove screws in lint filter housing
    • with putty knife or other flat blade depress lock tabs at front corners of top body panel
    • tilt top panel up
    • remove screws 1/3 way down each side, remove door switch wires
    • remove front panel set aside
    B:dryers with screws at bottom of front panel (maytag speedqueen)
    • remove screws from bottom of front panel
    • tilt front panel up
    • remove door switch wires
    All
    • pull drum forward & out
    • examine drum felts, rollers, and slides for wear replace if worn
    • wrap new belt round drum at old wear marks
    • insert drum
    • wrap belt round motor pully
    • pull tensioner pulley hard to end of travel against spring
    • wrap belt round tensioner pulley
    • release tensioner
    reassemble
    Oct 19, 2008 | GE Dryers
    I need to replace the belt in my ge dryer. how do i get the back off to get to the inside. we have unscrewed every screw and it doesn't seem to want to come off.
    whirl pool and most other manufacturesdryers are front serviceable for belts depending on dryer top pops up (2 srews under filter on whirpool top filter dryers )2 front clips push those in top lifts ..2 screws on inside front panle take out front lifts off
    Apr 26, 2008 | Dryers
    Roper gas dryer
    FIRST UNPLUG UNIT!!
    Remove 2 screws by filter area on main top.
    Grab back of dryer and pull top forward while holding dryer in place with knees. Do this to pop up top on front left then front right. Remove 2 screws holding front panel 2 side panels. They are at top front of side panels, inside.
    Pull front panel out at top and pull up to remove front panel. Put belt around drum with grooved side toward drum.
    Nov 08, 2007 | AEG T57800 Electric Dryer
    Dryers Logo
    50 people viewed this question
    Top Dryers Experts
