My DVD-rom does not read any disk i out in, ive checked my drivers and everything is working. what could this be?
    Master:
  • 602 Answers
DVD ROM'S do not read CD'S
Posted on May 03, 2015
DVD RAM change to CD Rom when i inset a disc
Check your computer drivers for that drive. It may be a driver error. It has happened to me before and I fixed it by reinstalling the drivers. It should be a software issue if you can still read CD disks.
May 16, 2012 | Computers & Internet
My dvd rom have some difficulty to read some DVD.. But not all i can read the matrix 1 but not the matrix 3... Any suggestion
A DVD rom driver can read DVD disks only. DVD Recorded, DVD ReWritable disks cannot be read on the DVD rom driver. Acquire an external DVD RW driver to make possible any recorded digital formats readability.
Dec 21, 2010 | HP Pavilion a1630n PC Desktop
Lite on DVD Combo disk read failure
You could take the drive out of the encloser and hook it up. There could be a flaw in the enclouser ive had that happen before to me. I just took it out and put it in standard if this dosent work then there is a flaw in the dvd burner
May 20, 2009 | AMD Duron 1.3 GHz (cpu-amd-1.3g-o)...
Cd rom wont read disk
first reload you cd rom drivers then shutdown and, restart check your cd rom
Apr 28, 2009 | Sony VAIO Notebook
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Srinivas
Apr 12, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
DELL laptop does not read blank DVDs
the combo drive you listed above is a cd-rw/ DVD-ROM....meaning that it will play and burn cd, cd-r, and cd-rw disks. the dvd rom will only be able to play dvd-rom and dvd-r disks providing they are in the proper format. check that the disk in question is not a dvd-rw or (+2) disk. the drive will not recognize that a disk is in the drive if the disk isnt compatable. try a dvd movie, if that works then a dvd-r, if that works then try a dvd-rw +1. if the last option doesnt work then you will have to stick with the dvd-rom and dvd-r, or purchase a dvd-rw drive to install.
GOOD LUCK AND DONT FORGET TO RATE MY POST!! :D
Mar 18, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Mar 09, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
My computer will not read any of my disk or install
when you say disk did you mean hard disk? if you do... did you recenlty install a new hard disks?... if you did... did you check the jumper-master-slave configuration when installing the new hard disk?
only one hard disk can be configured as master in each ide channel. set up to master (not single) the one on the end of the ide cable and set up to slave the one attached to the midlle of the ide cable.
check that both hard drives are properly attached to the cable and that the power cable is properly seated.
when you say disk did you mean cd rom disks or dvd disks?
does it work in other computers? if it doesnt.. you cd/dvd disks may be the problem
are you trying to read a dvd disk on a cd rom only drive... you can't read a dvd in a cd rom drive.
if you cd/dvd rom drive should read the disk you're putting in, check in device manager if your system detects the cd/dvd rom drive. if it doesn't: check the physical connections (reseat ide cable, check jumper configuration for slave and master on your cd/dvd rom drive and check that the power cable is properly seated), check also in device manager the properties of the cd/dvd rom drive and check if it says on device status if the device is working correctly. if it doesn't post the error code that it may give you or google a solution with error code.
suggestion.. be more specific when posting your questions.. that way it will be easier for a solution to be provided as your issue could be interpreted in different ways
Sep 24, 2008 | HP Computers & Internet
Playing PC DVD roms problem
Dvd drives can read from both DVD and CD however due to technological limitations most DVD-ROM or RAM read up to slightly higher speeds for CDs than DVDs.
When burning DVDs professional companies that make prerecorded disks burn their disk at low speeds in an effort to achieve both compatibility and low errors, that is the reason their DVDs play on most DVD-ROMs. However DVDs me and you burn at home and work at high speeds are prone to errors and incompatibility with low reading speed drives.
As a result if your DVD-ROM has a low maximum reading speed then it can only read those prerecorded DVDs and only DVDs recorded at low speeds provided thre are not scratched.
I believe you managed to read those DVD movies if they were pre recorded.
Nov 29, 2007 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
Dvd-rom not able to read pc dvd game
What is the game title and manufacturer? Can you read/play any other type of DVD on this drive?
Mar 12, 2007 | Lite On LITEON DVD-ROM16X, 21600KB/sec...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
