Question about Garden
Oil coming out at the air filter - Garden
  • Garden Master
  • 2,540 Answers
I agree with the above answer but I will add if you tip the mower over to clean the under neath it will cause the oil to run into the piston area and mess up the engine intake as well.
Posted on May 02, 2015
  • 400 Answers
It sounds to me as though you (or someone) has overfilled the oil. Check, and drain out the excess. I am afraid you will have to replace the filter, if it has been oil soaked as you cannot clean it out.
Replaced blade and now oil coming air filter
If you have tipped the machine on its side rather than tipping back on the handles, the engine oil will spill from the engine breather and be fed into the back of the air filter box, you now need to remove the filter cover and filter, run the engine until the smoke clears, if the air filter ia a paper cartridge yo will need to replace with a new filter.
Jun 13, 2013 | Husqvarna Garden
I have a worthington tow behind compressor, and I have a ton of oil mixing in with the air, it makes a huge mess. I have replaced the filter, any other suggestions
you stated you replaced the filter.Was it the separator filter? the separator filter is located inside the separator tank. the separator tank is where you add oil. If this filter is bad it will cause oil and air to mix and get into the air. Also there is a 1/4 inch line that comes from the top of the tank . this line has an orffice in it If the orffice plugs oil can carry over into the air.
Sep 18, 2011 | Worthington Air Tools & Compressors
86 harley oil leaks out carb when you start it
Your crankcase vents into the carb air filter. This was required by the EPA. All crankcase vented pressure has to be cycled through the engine. So, If you'll look behind your air filter to the rear of the bike, you should see a pipe coming from just behind the oil pump up to the backside of the air filter. The air pressure exhausted from the crankcase has an oil mist in it. There are baffles in the pipe but sometimes during servicing, these baffles get left out. Still, even with the baffles, there is some oil mist that makes it's way to the air filter. This oil builds up over time and causes a drip out of the air filter. Regular cleaning of the air filter assembly reduces this.
If you're getting more than the usual amount of oil, your engine could be "oil sumping". This is where the oil in the oil tank seeps past the check ball valve in the oil pump and builds up in the bottom end of the engine. When you start the engine, the oil pump cannot pump it back to the tank fast enough and it's blown out the crankcase vent tube right into your air filter. You can "reseat" the check ball and may be able to get it to stop doing this.
Or, you could remove the crankcase vent tube going up to the air filter. Put a piece of tubing about six inches long on the nipple coming out of the engine case and plug the hole in the backside of the air filter backing plate. Then, the oil will directed onto the ground instead of into your air filter.
Good Luck
Steve
Aug 19, 2011 | Harley Davidson FXR Super Glide...
Gardner denver air compressor is blowing oil, need help
Is this a rotary screw compressor? If so, is it blowing oil out of the air filter or out of the discharge air lines? If it's blowing oil out of the air filter you have a oil stop valve or minimum pressure check valve bad. If oil is coming out of the discharge air you need to change the seperator.
Nov 15, 2010 | Air Tools & Compressors
Engine oil coming out of air filter
If the tiller was lying on it`s side the oil would flow into the carb. and filter.
You will have to remove the carb. and wash it out. Check there is not too much oil in the engine.
May 20, 2010 | Troy-Bilt Pony Garden Tiller
Oil coming from line from engine feeding into air
More than likely your air filter is clogged and needs replacing. If that is the situation the carb needs air and is pulling suction on the crankcase breather tube siphoning up oil instead of just burning the vapors. If it was a busted ring the oil would be coming out the exhaust and burning blue smoke.
May 01, 2010 | Mtd 22" Yard Machine Push Mower
What types of air filter and oil filter do I need for my 2006 Suzuki gsr?
hi mate if you go on ebay and type in gsr600 service kit it will come up with air filters oil filters and oil and its quite cheap
Aug 24, 2009 | 2006 Suzuki GSR 600
The air is coming out of the filter instead of intake . Craftsman Air Compressor 12-gal 1hp model 921.166400
if acualy exhaust / engine pressure is coming out of filter it likely to be a bad valve...does engine blow smaoke or oil? is there also pressure coming out of oil crankcase?....let me know , we'll diagnose it! good luck, marty
Jun 14, 2009 | Craftsman Air Tools & Compressors
Honda ruckus oil on air filter
There shouldn't be any oil on the air filter. Take the air filter out and try drying it out (a blow dryer would come in handy) to make sure the liquid is not water. If it is oil, take it back to the dealer as it is still under warranty.
Apr 03, 2009 | Hartford VR 150X Motorcycles
Oil blow out the breather
An overfull oil tank will do it. Even if not overfull just about all harley's will blow oil out the air filter. Unless there is a bunch of oil coming out, it's not a problem What I've found is that the air filter eventually gets saturated and then starts to leak through. The level in the oil tank doesn't seem to matter. If you change the air filter the problem goes away, until the new one gets saturated and then it starts all over again. My plan is to get a K&N air filter, which you can clean yourself and save having to buy a new air filter every 4,000 miles or so.
Nov 20, 2008 | 2006 Harley Davidson XL 1200 R Sporster...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
