Whirlpool WWDC 7410, about 3 years old, Completely dead
Fuse ok, mains goes to control board, replaced control board. Still no function or lights at all.
  • 2,210 Answers
You don't say what make model year etc but sounds like the pcb is dead. Is it under warranty? If not trawl the web at appliance spares sites or ebay. You'll need the info off the sticker on the back.
Posted on May 02, 2015
Why does my whirpool wwdc 7410 not start cycle?
you may have a bad door switch. I would check that the wires are still connected to the switch and that they are not broken or damaged.
May 12, 2014 | Washing Machines
Portable AC is completely dead
Technicians trick. Power goes into board but not out.. Bad board. Replace it. The only repair on a PC board should be done but someone who does it everyday. I've made that mistake before.
Jul 02, 2013 | Whirlpool ACP102PS Portable Air...
Microwave stopped working
The main fuse in the microwave is probably open, causes are! door switch, magnetron, inverter board, "if 7 years old or less" and possibly the keypad control board. I recommend having it checked out.
May 08, 2012 | Samsung Microwave Ovens
Oven was running, suddenly stopped and now is completely dead. Power in plug is live. Fuse appears to be good.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Dec 29, 2010 | Whirlpool MH7140XF Microwave Oven
MY VP42HDTV WILL NOT DO NOTHING WHEN I PLUG IT IN WHAT COULD IT BE.
Hi if you plug it in at the mains and switch it on and you get nothing not even the standby light then this points to either a fuse been blown so check the fuse in the plug failing that it will mean getting a new power board fitted, now if the telly is more than say 2 years old i would say its not worth getting fixed as the chances are you will replace the power board and then you will start having problems with the inverter, soyou could end up throwing money down the drain.
if its less than 2 years old and its totally dead check the fuse in the plug change it anyway and then give it a try but if its still totally dead then this points to either the fuse been blown in the telly this is a little clear glass fuse located where the mains cable plugs into the main power board, if this fuse is not blown also then the whole power board will need replacing.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Nov 28, 2010 | Vizio VP422 42 in. Plasma TV
My washer went on control lock and now it wont turn on i tried to unplug it but nothing works
Would plug something else into outlet to make sure your power supply is ok. If you remove bottom panel in front(three screws) or top panel(three screws in back and slide panel back slightly to raise off) there should be a tech sheet with some suggestions. If it is less than a year old call for warranty service. Keep kids away with panels off. If unit is completely dead a guess would be main control board on top, but that is just a guess.......
Jan 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool GGw9250Pw3 no power on Control Panel Inside light works
In my case, the problem was a dead main board. The board cost $190 and the overall repair cost $335. I will never buy another Whirlpool due to this experience.
Dec 11, 2008 | Whirlpool GGW9250PL Gas Dryer
Whirlpool GH518XP
Sounds like it got hit with a power spike which could have burned out the low voltage components, (Control panel). How's your insurance coverage?
May 22, 2008 | Whirlpool GH5184XPQ Microwave Oven
Replaced light bulbs, lights still don't work
there is no fuse power comes staight from the transformer on the board. the only possible fuse is the main fuse that will kill all the power
Nov 01, 2007 | Whirlpool MH6130XEB/Q Microwave Oven
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
