Question about Miele W1926A Front Load Washer
Miele W1926. The red light over the faucet icon is on at the end of the cycle and the final spin cycle doesn't go on.
"doesn't" go on
  • Jake Sysk May 03, 2015
    The machine filling for the wash cycle shows the water control valve is working. The timer is failing at the final spin. one contact on the timer has broken off
  • Larry Kaplan
    Larry Kaplan May 03, 2015
    Thanks. I will raise your issue with the repair man before a water valve is replaced.
    Master:
  • 602 Answers
Check the screen filter where the cold water line attaches to the machine. Clean both hot and cold.
Posted on May 03, 2015
  • Larry Kaplan
    Thank you. Did that but still not working after reattached. I'm told it is probably the intake water valve that costs $250 to purchase from Miele plus service charge to replace.
My miele wt945s takes in some water after final spin so clothes at bottom of the drum end up wet. Can I stop this happening
There is a problem with the programming of the control board if this is occurring.
All you can do is turn off the water to the machine at the end of the full cycle and then run the spin cycle again to dry out the clothes. Then no water can enter the wash drum.
Otherwise you would need to turn off the water each time before the spin cycle concluded and thus before the machine began adding water again.
Dec 08, 2015 | Miele Washing Machines
How to put top back on miele w1926
1 Remove stacking kit from top of unit.
2 Reatach the two plastic clips to the back of washer.
3 engage the two slots on the washer top into the clips , pull forward drop lid down on top of washer then secure with two screws on either side of lid.
Dec 29, 2013 | Miele W1926A Front Load Washer
Miele W1926 check inlet light flashes at he end of rinse fill
Hi Yugin.That indicates your machines water inlet valve is faulty.(Means it's taking less water then normal)Please check this steps & do it fast before water inlet is finishes:1-Turn your machine on & run empty with pre-wash cycle first.2-Please ajar the detergent drawer & check runing water on compartment one 3-Please press pre-wash button & compare the running water volume on compartment two.If the running water volume 1 is less then 2 or vs.water valve needs to be replace.That's causing problem.I hope that helps.Thanks.
Jul 26, 2010 | Miele W1926A Front Load Washer
Miele W1926 check inlet light flashes at the end of rinse fill. When the fill ends, the light goes off. I cleaned all 4 filters at the intake hoses. The problem still exists. What does it mean?
Hi dear.According to what you're saying,It has faulty water inlet valve.Machine unable to get enough water to do it's cycle in given parameters in time period & starts giving error but before the cycle complates,however it takes enough water,that's why error lights goes off.If you can,you need to change the valve or call service department.I hope that helps.Thanks.
Jul 25, 2010 | Miele Novotronic Premier 500 Front Load...
Miele W1926 washer shakes more then usual when spinning at low speeds. Could it be problem with shocks? How to open the machine? Thanks
I'd start simply.
They do move over time and if the floor is not even the machine will be out of balance.
If you have not done so check the machine is still level and all feet are solidly on ground.
Try to shake the machine by hand and see if is solid on the ground. There are leveling legs under the unit you can adjust.
Hope this helped. Please rate answer if it does.
Mar 11, 2010 | Miele W1926A Front Load Washer
Miele W1926 washer makes a banging sound when it spins
if i were you fist of all open door then you will see the silver drum on the inside lift the silver drum upwards from the top of it and if you feel a knocking sound then the bearings have worn out expencive to replace them,as sometimes you have to have a complete new drum.rgrds,paul
Jul 07, 2009 | Washing Machines
Miele W1926 water light flashes
That happened to me too. If the machine is a few years old and the hoses are not kinked it's possible the water inlet valve needs to be replaced. On this machine there is a triple cold water valve and a single hot water valve. Mine needed the triple valve and it is about $300 if I remember. Check to see if it's the cold or hot water valve by looking at the water filling through the soap drawer for cold or hot water cycles. When the valves go bad they run but the output is very low which causes the light to flash because it can't fill to the correct level.
You can get to the valves by taking off the top. If you don't feel comfortable working on your own machine have a professional do it.
Apr 25, 2009 | Miele Novotronic W1918A Front Load Washer
Miele w828
Hey you! I want to Miele w828 Final Spin Cycle 1100rpm Part 1/3 of 3/3 Part 1of3/3 of 3. Do you understand? Great Now let get to work.
May 24, 2008 | Washing Machines
Miele W1926A Front Load Washer Logo
218 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
