Tub clanging/very noisy when in spin & especially in final spin. Shakes entire machine & stacked dryer. Tech replaced the tub. What could it be?
  • 2,210 Answers
Replaced the tub? I would have gone for the tub bearings worn out. If you reach in and grab the tub is there a fair bit of movement? The other option is 1 or more of the dampers or support springs have failed or come off. If the top lid comes off (You don't give any machine details) switch off or unplug, remove top lid and have someone with some knowledge have a look inside and check the above. You may find the spring lying in the bottom of the machine casing. If there's nothing found you may have to resort to an appliance engineer.
Posted on May 02, 2015
My washer/dryer combo Frigidaire washer dosn't spin water out of clothes completely after spin cycles the clothes is still very wet. On the 1st spin cycle drum dosn't spin just makes noise,the 2nd and...
Good Afternoon Friend,
I understand your Frigidaire laundry center, model# FGX831CS, is not spinning water out of your clothes completely. I see that on the first spin cycle the drum is not spinning and is just making noise, and on the second spin cycle the drum spins to the left very slowly and loudly. First check to see if your washer is overloaded. Try taking some clothes out and spinning them again. Secondly, make sure that the load is not out of balance. Try rearranging the clothes to allow for proper spinning. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 19, 2014 | Frigidaire FGX831CS Top Load Stacked...
I'VE GOT A WHIRLPOOL STACKING WASHER DRYER COMBO BOUGHT APPROX 2002. wASHER WORKS FINE, pUMPS WATER OUT FINE BUT ON SPIN CYCLE SEEMS OFF BALANCE AND MAKES ALL KIND OF BANGING NOISES. i EVEN TRYED SPIN...
Transmission bearing has failed. The transmission has to be replaced as a unit.
The transmissions are relatively inexpensive (around 150 to 175 dollars) I have replaced 3
of these and they are rather difficult.
Apr 12, 2011 | Whirlpool LTE6234D Top Load Stacked...
Spin dryer on my twin tub washing machine does not drain properly. There is water at the bottom of the tub
I 've got twin tub w/machine service is not spinning and draining, can you pls tell me how to solve the problem?
Thanks
Oct 06, 2010 | Samsung Washing Machines
Kenmore laundry center stacked washer/dryer washer tub shakes almost violently on spin cycle.I may have changed setting during spin cycle.Tub is off balance.The appliance cabinet is balanced and on a solid...
Head over to the manufacturer's website.
www.SEARSPARTSDIRECT.com and enter your full model number for an expanded parts diagram and ordering information.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 11, 2009 | Kenmore Washing Machines
Washer noisy while spinning
You probably have a balance problem. You will have to get a service tech to replace the shock absorber/stabilizers (there are 3) in the unit.
Jan 31, 2009 | Kenmore 98702 Stacked Washer/Dryer
The wash machine makes big noise when spin
if unit is brand new remove shipping strap in back,,if you had this unit awhile most likely you broke a tub surport,,you have three..if you want details how to replace which is no small feet,,post question how to change tub surport and i will walk you though
Dec 25, 2008 | Whirlpool LTE5243D Top Load Stacked...
Kenmore stack washer/dryer model#11098752790
Check your lid switch ,if its not engaging replace it.
Jun 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Washer/Dryer Combo purchased in late 2000
Call a local repair tech. I know one in Milwaukee :)
Seriously, your machine needs some possibly expensive repairs beyond a novice's skills. The dryer has a felt bearing around the front of the drum that is probably worn out. Check on the rear bearing and the belt at the same time. The washer may need a new transmission, belt, tub seal, and spin bearing. That's an involved repair. Expect to pay extra for labor, but the total bill should be less than the $800 - $1400 for a new machine.
Mar 12, 2008 | Kenmore 24032\24036 Top Load Washer
Noisy dryer
Don't turn the tub to much this may make the belt run off track . If the machine makes a rumble at the beginning and at the end or when u stop the machine and restart it it is probably the blower wheel,it is made of plastic ans wears out on the motor shaft.
Apr 05, 2007 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
