Question about DeLonghi DE500P Dehumidifier
Unit runs but does no dehumidifie.How is this fixed?
  • Shawn DuRee May 17, 2015
    Hi Sanford Jaffe, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Temperature has a lot to do with it. can you please tell us the ambient temperature?
    Master:
  • 530 Answers
Probably leaked all the freon out
Posted on May 17, 2015
I have a delongji DEM 10 dehumidifier and it keeps switching to pause, I have cleaned filter switched off for a while but it still won't come on
follow this steps and fix it. God bless you
Unless you are licensed and qualified professional, do not try to repair a dehumidifier by yourself. If your unit is running constantly yet there is no water in the tank, try lowering the temperature control. If the problem persists, there may be a problem within the refrigeration system. You may need to pull the filter and clean it. Also try wiping off the unit itself. When the water tank is full, the unit will shut off and will not run until the tank is emptied. The dehumidifier shuts off by a safety switch in the back of the unit. If the switch is not working properly, you may try manually pressing the button or slightly bending the switch.
    Motor If the fan motor is damaged or will not work, no cool air will be coming out of the dehumidifier. The unit, however, may still run. You may need to replace the motor. If the coils in the back of the dehumidifier constantly freeze, try turning off the unit for an hour or re-locating the unit to a higher position to allow the room to heat up. If your water tank is constantly full and you are emptying it on a daily basis, you may have a water leak somewhere in the room with the dehumidifier.
    Oct 30, 2013 | DeLonghi DE500P Dehumidifier
    I have a Maytag 45-Pint Dehumidifier M7DH45B2A which hasn't been used for a year. Now, the fan runs but the only think in the bucket is drops of greenish liquid. Is there an easy fix or just buy...
    There are many reasons why a dehumidifier willnot work or collect water.
    Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
    Dehumidifier is running but no water is in bucket
    heatman101
    Jun 27, 2011 | Maytag Dehumidifiers
    I cannot get this thing to stay on. The fan runs for about a minute then shuts off. I have tried unplugging it and plugging it back n and I have tried adjusting the percentage on the unit but it will not...
    heatman101
    Apr 11, 2011 | GE ADER65LN Dehumidifier
    The Dehumidifier is not collecting water. How do you get this fixed?
    First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again.
    Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue.
    This situation will have to be addressed by a qualified technician.
    Good luck.
    Aug 12, 2010 | Maytag M7DH65B2A Dehumidifier
    I have Delonghi DE500P dehumidifier was running but doesn't pump water. how can i fix it.
    First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
    Good luck
    Aug 11, 2010 | DeLonghi DE500P Dehumidifier
    Unit doesnt seem to be removing humidity. its
    Check the auto defrost sensor. They are known to become defective. Bypass or remove the device and unit will run normally, almost. WARNING: without the defrost sensor the unit will tend to ice up in cooler ambient environments. If sensor is removed watch carefully and only use in summer months. The dehumidifier may also be fixed by replacing the sensor but the design for repair is different and requires a costly modification.
    Jul 17, 2010 | GE AHG40LJ Dehumidifier
    The dehumidifier isn't taking the moisture out of the air.
    is the compressor in the unit hot to the touch,or are the coils freezing and thawing when it runs<if so you probably need to add some R-134a refrigerant,these type of units are notorious for losing all or part of their refrigerant charge,but unless you have the equipment to remove old refrigerant and vacuum the system down and recharge it it can get costly
    Apr 15, 2010 | LG LHD45EL Dehumidifier
    DeLonghi DEN500P Dehumidifier Humidistat
    I have the delonghi DEN500P and the unit runs but does not condense any moisture? The appropriate buttons have been set to bring the unit humidity setting well below humidity in room
    Aug 03, 2009 | DeLonghi Dehumidifiers
    Runs all the time, not collecting water
    I don't know your particular unit, but my guess is that the compressor is bad. If it is old, it may not be worth fixing.
    Sep 19, 2006 | Goldstar DH504EL Dehumidifier
    Dehumidifier Compressor is not working
    this unit is very simular to an air conditioner except it has a humidistat instead of a thermistat.. if your handy with a continuity tester unplug the unit find the humidistat and check to see if its open or if its good then call the company at 1 800 322 3848 or contact the web site at customerservice@delonghiusa.info Good Luck
    May 31, 2006 | DeLonghi DHE90 Dehumidifier
    DeLonghi DE500P Dehumidifier Logo
    470 people viewed this question
    Top DeLonghi Dehumidifiers Experts
    Mike Kolbay
    Level 1 Expert
    Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
