Question about Ovens
My oven lost power right in the middle of bakingcookies. We checked the breaker no problem unplugged and replugged still no power. Can you tell me what is wrong
The oven is 3 years but only used two and not much at that
  • 720 Answers
Sounds likely that the heating element has burnt out...easily replaceable via eBay for correct part....or internal wiring has dislodged from the switch pot or element ends.Always disconnect power when removing covers and replacing elements or checking for loose wiring burnt wiring or loose connectors.
Posted on May 03, 2015
  • 473 Answers
If it is totally dead--no power, you need to start checking the main power supply lines. Make sure you shut off the main breake to the oven. Then start at the connection where the house lines hook to the oven. If this is a built in oven it will be in a junction box directly behind the oven. If it is a free standing range/oven it should have a big 240 volt power cord on it connected to the range with 3 screws. Many times if connections are not tight when first installed, those loose connections will burn to the point they no longer make a good connection.
Posted on May 02, 2015
What to do if your kenmore oven says off when trying to bake?
You have no power to the unit at all. Check the outlet and breaker box. You have have popped a fuse.
Jan 03, 2015 | Kenmore Ovens
We had a power outage and now the oven will not come on. cannot set clock etc.
Have you checked your breaker box? It could be that the breaker for the range popped to the off position. If the breaker is still on, try carefully unplugging the range, leaving it unplugged for a few minutes, then plugging it back in.
Dec 27, 2010 | Maytag 30 in. Electric Single Wall Oven...
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Thermador SC301T heating elements not working (top and bottom). elements look fine, oven turns on but elements stay cold.... any help would be appreciated. thanks, Tony
Its the thermal safety switch. When it trips - it cuts any power from reaching BOTH elements. Open the oven door - at the top wehere the oven latch is - remove the long black panel. In the middle - on the right is a small cylindrical switch...push down on the top - in the very center...it will rest the switch (like a circuit breaker) and then reassemble. Just did it on mine (2nd time) and it fired right up. Good luck
Jul 09, 2009 | Thermador SC302T Electric Double Oven
4 Elements and Oven not working
If there was a power surge when the power went out or came back on, it could have fried the controller.
Jan 16, 2009 | Frigidaire Ovens
Oven cut off in the middle of cooking
From what you say you seem to have no power to the oven, Check for blown fuse or tripped circuit breaker, check connections in plug. do you have a reset button anywhere, check your user manual.
Dec 10, 2008 | Kenmore 47783 Electric Single Oven
G.e electic profile slide in oven
All three codes, very odd, f3 f4 pertain to oven sensor short, or connection issue, f5 also asks to check resistance of sensor , so id try replacing oven sensor. sort probe located on top left or right side of oven cavity, 2 screws hold it place(sometimes youget lucky and will remove from front, if not you need to remove back panel and unplug and replug new sensor.cost for part can be $40-100, depending ion model
Feb 24, 2008 | Ovens
Fisher&Pakel Oven os301
re-boot, I shut the breaker down for a few seconds and bingo, problem fixed
Aug 07, 2007 | Fisher and Paykel OS302SS, Stainless Steel...
Ovens Logo
79 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
