Question about Westinghouse Televison & Video
Banner across top says HDMI error unable to display video (H1005-HDCP link integrity check failed) How do I get the banner off?
    Top Expert:
  • Westinghouse Master
  • 74,243 Answers
Sounds like corrupted firmware.
Posted on May 03, 2015
    Master:
  • 371 Answers
Replace your HDMI cable.
Posted on May 02, 2015
    Sergeant:
    Champion:
  • 267 Answers
Replace the HDMI cable.
Remove banner
Bad HDMI cable. You can't bend it too sharply or pull on the cable. These are fragile.
May 02, 2015 | Westinghouse LD-4655VX 46" LED TV...
Why am I getting the HDMI Error. Unable to display video(H15005 - HDCP link intergrity check failed?
The hdmi outputs on the uverse receivers are garbage, I recomend using them. Go to Walmart and buy a component cable install it and never worry about the hdmi error again.
May 29, 2014 | AT&T UVerse
Cant get hd to work
What is HDCP?
HDCP stands for High-Bandwidth Digital Content Protection, a copy protection scheme to eliminate the possibility of intercepting digital data midstream between the source to the display. The format designed by Intel and licensed by Digital Content Protection, LLC using an authentication and key exchange procedure before video and audio is presented. Products compatible with the HDCP scheme such as DVD players, satellite and cable HDTV set-top-boxes, as well as few entertainment PCs requires a secure connection to a compliant display, the process often described as the handshake. Due to the increase in manufacturers employing HDCP in their equipment, it is highly recommended that any HDTV you purchase is compatible. Although most video devices support high-definition video over component output, analog connections are scheduled to phase out in the future or possibly forced to limited resolutions output.
Why is it important to me?
Although manufacturers are still making most products with at least component HD output, new generation of products like HD-DVD and Blu-Ray devices will limit the analog output resolution (Analog defined as Component or RGBHV). The highest resolutions these devices can output (720p/1080i/1080p) will be available on via the digital (DVI or HDMI) connections that employ HDCP encryption. Any new HDTV purchase should have a digital HDCP compatible input.
It is important to note that HDCP is currently not a standard used in PC monitors, and almost none of these displays have Component inputs. Although PC monitors are HDTV capable, HDCP encryption limits this type of use. If you use an HTPC and want to ensure dual use of your new flat panel display, look for HDCP compatibility.
How does it work?
A simple answer is that an HDCP session will result in the exchange of keys between the source and display device. The source device will query the display to make sure that the equipment is HDCP compliant before video is shown. Non-HDCP devices such as PC's and older model DVI products will work with any DVI compliant display, but the HDCP compliant boxes will show an image only on HDCP compliant display.
Other products affected by HDCP are scalers, switchers, and splitters (distribution amps). While these devices do no authentication for key exchange, they must be able to transmit the presence of HDCP if the video is handled (processed) in any way. Due to the two different formats of digital connections, occasional inability for proper communications may result in loss of interoperability. The newer format, HDMI was designed to be backwards compatible with DVI and in most instances, the two signal types are easily adaptable, but older devices may not always work well with in-line devices like scalers or switchers. These problems can sometimes be fixed in "firmware' although that is not always the case. Incompatibility is often displays on-screen as a snowy image or an error message.
Hope this explains it for you.
Jan 08, 2011 | Televison & Video
Hdcp error mesage when connected to my freeview hd box.
What is a HDCP error? Here is a real life situation that happened that could happen to you. You just bought a Blu-ray Disc Player and connected it to your older HDTV with a HDMI cable. When you tried playing a Blu-ray disc a HDCP error was shown on the screen. The movie wouldn't play.
This is a known issue with HDCP, and it's one of the biggest hassles consumers will have to deal with when utilizing a HDMI cable on their HDTV. You will get a HDCP error if you try watching HDCP encoded content when using a HDMI cable.
The problem is that if HDCP exists anywhere in the video stream then all devices and cables accessing this content must be HDCP compliant. If one device or cable isn't HDCP compliant then you get a HDCP error.
The only solution is to either replace the HDMI cable with a non-digital cable or replace the HDCP-less device. This could mean buying a new HDTV. In fact, I worked with a reader last year troubleshooting a HDCP error on his TV. What happened is that he bought a Blu-ray Disc Player and connected everything properly only to get a HDCP error. After a few emails back and forth we discovered that his HDTV wasn't HDCP compatible, which is why he got the HDCP error.
The reader ended up buying a newer HDTV with HDCP, and his Blu-ray Disc Player worked perfectly with HDMI cables.
Nov 22, 2010 | Televison & Video
How do I get rid of error message across top of TV that reads "Your television cannot support HDCP video over your high definition connection (H1001)".
Use component cables instead of hdmi cables. I know this isn't the best solution, but HDCP is not used over component and the video quality is just about as good.
Jun 04, 2009 | Westinghouse SK-26H240S Television
H1005 error
I played with going to another HDMI outlet and then back to the original and it seems to quickly reset itself and the message dissappeared!
May 23, 2009 | Panasonic VIERA TH-C50FD18 50 in. Plasma...
Have hdcp error flashing on front display
HDCP is copyright protection for HDMI ensuring that you can't copy the protected material.
Did you connect some new DVD player or new TV to the receiver? However the error should clear once you disconnect everything from HDMI. If not, try to restore the receiver to factory defaults.
Apr 11, 2009 | Yamaha RX-V461 AV Receiver
Samsung hl61750a - unable to display video service over hdmi
I was using an hdmi cable purchased online. A friend told me that it might be the 'cheap' hdmi cable. I tried a set of Monster hdmi cables and problem solved. So all hdmi cables are not the same.
Jan 29, 2009 | Samsung HLN5065W 50" Rear Projection...
Televison & Video Logo
110 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
