Question about Sewing Machines
Does anybody know why soon as I turn the machine on it makes a weird noise and the screen says raise needle bar and presser foot. I've tried everything, can anybody help?
  • 35 Answers
Hmm. Raise the foot with the presser foot lever. You have to raise the foot up to get the fabric under the foot in order to see.
Posted on May 03, 2015
  • Ann Blauwiekel-Gietzen
    Ann Blauwiekel-Gietzen Oct 16, 2015
    Did you ever find an answer to this???
I am getting a message to raise presser foot and needle bar then turn on. The presser foot seems to be up. I dont know what the needle bar is. Please help?
The needle bar as the long vertical bar that the needle is attached to. Hand rotate the handwheel until the needle is at its highest position before it begins to descend.
Nov 13, 2016 | Sewing Machines
I've borrowed a memorycraft 300e from a friend. I've used it without incident for a few days but suddenly without any issues now whenever I turn the machine on I get an error message
Did you check the needle down button. Be honest and return it. Price one and wonder why you borrowed something so expensive. She may know what to do. But dont tinker or try to fix it. It seems like a fixable error. You probably afraid to tell her. But you stressing yourself out. If you borrow it you probably know a cheap embroidery machine is about $500. Just get it back and maybe she won't snap its probably something simple.
Nov 03, 2014 | Sewing Machines
How do I fix the following problem with my Janome MC9000 sewing machine?
Unfortunately you are probably not going to be able to fix this.
It needs a sensor adjusted (probably), or a component replaced.
Sep 25, 2014 | Janome Memory Craft 9000 Computerized...
Bar that hold the sewing foot is loose
If the comment already posted did not answer your question, here is another thing to check. If the screw that attaches the foot and ankle to the presser foot bar is tight, and the foot can still be moved, it is likely that the presser foot bar has become loose within the lifting mechanism. You could save yourself some trouble by taking your machine to a sewing machine repair shop, but if you would rather avoid that expense, do the following. Remove the needle bar and take up mechanism cover on the left side of the machine. This is held on by a single phillips head screw on the back side of the machine, which, with the back of the machine facing you, should be on the top right side of the machine. Once this cover is removed you will be able to see two vertical metal shafts, one is attached to your needle clamp and needle, and should be in the front. The other is the presser foot bar, and will be behind the needle bar. There should be a small allen screw about halfway up that shaft that tightens onto the bar. With the presser foot properly positioned on the needle plate, tighten this allen screw. Don't tighten the screw too tightly, as this can damage the presser bar, just make sure it's nice and snug. Make sure the presser foot raises and lowers properly, and re-attach the needle bar cover.
Hope this helps.
Mar 16, 2014 | Brother CS6000i Computerized Sewing...
I can't get the foot to lower and raise.
it sounds like it's out of time--here's how to fix it
to adjust the pressure on the presser bar and in turn the foot, locate the thumb
screw at the top of the machine
by rotating the thumb screw clockwise, you will increase the pressure, a counter
clockwise turn will decrease the pressure
the correct height of the pressure foot from the needle plate is 7mm.
to adjust this clearence loosen the screw & adjust the pressure bar through
the guide
secure the screw firmly when the correct adjustment is obtained
the distance between the presser bar lifting arm & the presser bar guide should
be 0.5mm ..( be sure the needle bar does not rotate left or right during the
adjustment process. the needle must be center of the presser foot & needle
plate hole,, if this is not centered re-adjust to the center of both needle foot
& needle plate hole.
Apr 07, 2012 | Sewing Machines
Kenmore 385. 15343600
Remove bobbin, presser foot, needle. Tip machine back on towel gently. Unscrew plate--don't lose screws! Do not service in presence of children and curious pets. Put foot pedal next to you on tabletop. Use Zoom Sewing Machine oil. Any part MOVING that are NOT gears get one drop oil. Any DRY ONLY gears get dab of Singer sewing machine lubricant. Replace screws. Secure screws. Open left front compartment & one drop oil @ top of needle bar. Open race shuttle (where bobbin case fits in). One-half drop oil of on oscillating hook (bottom left - hand corner...smear that oil around! Insert NEW needle all way UP in needle bar groove, flat needle shank toward back. Turn handwheel towards you and raise. Raise presser foot so that threading locates all tension slots a's you pull thread TAUT from spool to each tension slot and left to right through silver, metal take-up lever, and down to tension bracket, pass needle, then pull 6" thread towards you and thread from FRONT to BACK of needle. Place bobbin into case and "thread" it. Set presser foot on DOWN position. Turn handwh towards you, dipping needle into needle plate. Make loop with bobbin thread, pull towards you. Place a good 7" underneath presser foot (both threads). Let machine RUN on 24" scrap to distrubute oil/lube. That's it! Jimmy
Apr 05, 2012 | Sewing Machines
I have a singer 4552 (portable) and I am having a prblem getting the zipper foot attached. Also I am having a problem getting the design stiching to work. I can get the red design stiches to work but not...
Hi. Here's how to attached the zipper foot.
To Attach the Zipper Foot
1. Loosen the large screw at the left of the presser bar and remove presser foot (You do not need to remove the screw).
2. Hook the prongs of the Zipper Foot around the presser bar from the back, and tighten the presser-bar screw.
3. If the raised edge (zipper or cording) is to the right of the needle, adjust the Zipper Foot by loosening the thumb screw at the back of the foot and sliding foot to the left of the needle. If the raised edge is to the left, slide foot to right.
4. With presser foot down, check its position by lowering needle into side notch, making sure it just clears the foot.
5. Tighten thumb screw to lock foot into position.
When raised edge is placed to right -- adjust foot to left of needle.
When raised edge is placed to left -- adjust foot to right of needle.
Sep 04, 2010 | Singer Sewing Machines
How do I install my darning foot?
First, raise the presser bar, remove the presser foot, the presser foot holder and screw.
Turn the handwheel to bring the needle to its highest position.
Place the darning foot on the presser bar and make sure that the metal bar of the darning foot is above the needle clamp and put the screw back on and tighten.
As the needle bar raises and lowers, the foot will hop up and down slightly.
Make sure that you always lower the presser bar when using this foot. Lower the feed dogs also if your machine has this feature.
Aug 20, 2009 | Kenmore 15343
Presser foot lever does not lift presser foot
If you can remove the cover on the left side you will see the presser foot bar. On the bar there will be a screw that may be loose. Turn the handwheel until the needle is all the way down and lift the foot manually until just before it makes contact with the needle clamp and tighten the screw on the presser foot bar.
That should do it.
Jan 07, 2009 | Sewing Machines
How to connect the walking foot for ls-2125i? I have removed the snap on presser foot. Unscrewed the leg so I could screw on the foot. The white piece to the right does not fit on my screw so it just...
Turn power switch to "0"
raise the needle to highest position by turning the wheel toward you(counterclockwise) and raise the presser foot lever
release the foot by raising the lever located at the back of the presser foot assembly
place a different presser foot on the needle plate so that the bar on the presser foot is in line with the slot on the shank
lower the presser foot lever and fix the presser foot onto the shank. If the p foot is in the correct location the bar will snap in you should hear a click or snapping sound let me know if this helped thanks! amy
Jun 24, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
146 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
