Question about Health & Beauty
Can you help removing old batteries to replace
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 26 Answers
As long as they are replaced with new, then you can replace batteries. Rechargeable batteries leak though, use regular ones.
Posted on May 02, 2015
How do I remove/replace the hp compaq presario cq60-615DX internal battery. Not the CMOS one; the other large one at the back. There is no slider/lever. thanks
In order to remove the battery pack you should slide the Lock key to the Unlock position and keep it there until you have removed the battery. In the following video (at 00:08) you can see how to do it and replace the CMOS battery also. Hope that helps. How to replace the CMOS Battery in the Compaq Presario CQ60 Laptop
Here is the manual you can read more and see how to on page 46.
http://tim.id.au/laptops/hp/hp%20g60%20compaq%20presario%20cq60.pdf
Feb 18, 2014 | HP Compaq Presario V2000 Notebook
Batterys loose charge quickly
Your battery pack is worn out. You will find the correct battery type at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace, start by removing the lotion packet cover on the back. Remove the screw on the back near the bottom to remove the pointed bottom of the shaver. Then remove the 4 screws to remove the battery compartment cover and access the batteries. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Mar 12, 2011 | Norelco 7737X Electric Shaver
How do I change the batteries on my WW60X? I can't find my manual but was able to open the battery cover to get the number for the batteries. Now I can't get the batteries out of the scales. ...
Your Instruction Manual is here:
http://www.conaircanada.ca/pdf/en/ibs/en_WW60XC.pdf
Battery Replacement Instructions
1. Turn over the scale and open the battery door. (Push ribbed switch and pull up)
2. Replace old batteries with two new 3V Lithium batteries (CR2032).
3. Close battery door.
4. Properly dispose of old batteries.
There is nothing holding the batteries in place once the battery door is opened. If the batteries are difficult to remove, use a small screwdriver to gently pry up on the battery or simply after opening battery door invert the scale and shake.
Mar 10, 2011 | Conair WW60X memory electronic Weight...
I have a Remington Microscreen2 shaver. The rechargeable battery no longer will take a charge and I need to replace it. The problem is that I can find no instructions for removing the battery from the...
You will find the correct battery type at shaveroutlet.com. See link below. You will need two
http://shaveroutlet.com/shaver-replacement-parts/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
To replace the batteries, start by removing the foils and cutters. Then, gently pry off the rubberized grip on the front. This will reveal two screws at the bottom. Remove screws. Then gently pry off the silver metal plate that is at the top of the shaver. You can then gently pry the front and back case apart.
Inside, you will find a circuit board with the batteries attached. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Mar 10, 2011 | Remington MicroScreen 2-300 Electric...
Need to replace the batteries in a norelco 5821xl
norelco battery replacement NiCd two batteries pack for electric shaver philips norelco 5821xl replacement parts.
Feb 06, 2011 | Norelco Reflex 5821 XL Electric Shaver
I NEED HELP REPLACING THE NI-CAD BATTERIES ON MY SPECTRA 8865 XL
You will find the correct battery type for model 8865XL at shaveroutlet.com. See link below.
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. You can unsolder the batteries from the circuit board but for easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to do this yourself, you can have shaveroutlet.com do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Jan 12, 2011 | Norelco Health & Beauty
PROBLEM: WILL NOT TAKE A CHARGE. DEAD BATTERIES (?) - WOULD APPRECIATE PROCEEDURE NEEDED TO REPLACE BATTERY(S) FOR NORELCO ELECTRIC SHAVER MODEL 5821XL. SHAVER IS SEVERAL+ YRS. OLD AND IN EXCELLENT...
Dead batteries will cause the shaver not to charge. Batteries for model 5821XL can be found at shaveroutlet.com. See link below
To change, remove two screws on back and remove back cover. Remove plastic clip that is in the way of removing batteries. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to repair the shaver yourself, shaveroutlet.com can do it for you. See link below
Dec 31, 2010 | Norelco Reflex 5821 XL Electric Shaver
Rechargeable batterys need replacing
You will find the compatible replacement battery at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
Remove back of shaver by taking out 2 screws on the back near the bottom. With back removed, you can access battery. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Dec 01, 2010 | Philips Philishave HQ5812 Electric Shaver
The norelco shaver 8175 won't hold a charge
Sounds like the battery is bad. It will need replaced. You will find a replacement at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-8100-series-liion-battery-cell-p-578.html
To replace, first remove the back cover by removing 2 screws. Then you will need to remove a second 'inner cover' by removing an additional 3 screws. You can then access the battery. For easiest replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Sep 29, 2010 | Philips Norelco 8175XL Electric Shaver
How to open Philips shaver 7110X to replace batery
Remove 2 screws on the back to remove outer cover. Once removed, you will see 3 more screws that must be removed on the inner cover. Remove screws and cover to get to the battery.
When installing the battery, I suggest that you use a modified installation technique. This is to break the tabs off of the old batteries rather that removing them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can them solder the tabs from the new batteries to the old existing tabs
You will find a battery for your shaver at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
Feb 12, 2010 | Philips 7110X Electric Shaver
Health & Beauty Logo
71 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
