Belt routing for husky 13aj791g731 - Computers & Internet
    Brigadier General:
  • 3,400 Answers
How do I hook up my throttle wire to the carburetor on my 1991 husqvarna 40 chainsaw (or route it)
Also as old as my Husky 37.
It appears to route the handle and to the carburetor mounting area.
Here is the IPL for the Husky 40.
http://cdn.husqvarna.com/ddoc/HUSI/HUSI1998_AAaa/HUSI1998_AAaa_I9800044_.pdf
Dec 02, 2014 | Garden
Where can I find the deck belt diagram for a husky 42 inch 17 hp riding mower
Many Husqvarna tractors have a schematic decal of the belt routing on the underneath of one of the foot plates.
Jul 07, 2012 | Garden
Need to find out how to replace belt on WL65 cambell hausfeld air compressor
Not sure how easy it will be to locate repair instructions if they are not in your manual. However maybe the diagram of the pump is all you need. Just click on the first link below. It will open up the pump diagram. #14 is the belt.
I also included the link to the site where you can get a look a at the parts list and order parts for your compressor.
Hope something here helps.
If not please let me know and I'll try and describe the proccess for the belt remove to you.
Pump diagram:
http://www.mastertoolrepair.com/images/WL390100-Pump.jpg
Compressor diagram and parts list:
http://www.mastertoolrepair.com/wl650003-wl650102-wl650102aj-wl650202-wl650601-p-28707.html
Pump parts list:
http://www.mastertoolrepair.com/wl390100-p-17694.html
Nov 19, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Need a diagram on how to refit fan belt
Like a lot of people...you didn't post your engine size....so out of these 11 photos, please choose the correct one for your application:
Accessory drive belt routing—1.8L (AEB/ATW/AWM) engines
Accessory drive belt routing—1.8L (AWP/AWV/AWW) engines 2.0L (AEG/AVH/AZG/BDC) engines without A/C
Accessory drive belt routing—1.9L diesel (ALH) engines without A/C
Accessory drive belt routing—1.9L diesel (ALH) engines with A/C
Accessory drive belt routing—1.8L (AWP/AWV/AWW) engines 2.0L (AEG/AVH/AZG/BDC) engines with A/C
Accessory drive belt routing—2.0L (ABA) engine without A/C
Accessory drive belt routing—2.0L (ABA) engine with A/C
Accessory drive belt routing—2.5L (BGP) engine with A/C
Accessory drive belt routing—2.8L (AFP/BDF) engines
Accessory drive belt routing—2.8L (ATQ) engines
Accessory drive belt routing—4.0L (BDP) engine
Oct 31, 2009 | 2003 Volkswagen Passat
Need the napa belt number for this. or wherever i can get a belt for it.. i dont have the belt that was on it
Measure this with a tape - go to NAPA and tell them what you are doing and give them the distance around the two pullies. The NAPA affiliates I have used in the past have had a very liberal return policy if I was in error.
Oct 21, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I can ask this two ways were does the line from the prime button go when connecting to tank The place beside the tank breath? If so did I lose a part because it is way to small for line. If anyone had a...
An IPL (exploded parts list) displays fuel system routing. The fuel routing on these saws is among some of best illustrations offered by Husky. The site was having a problem when I checked so be patient. Just type 345 (nothing additional) in the model number, remember to check "Illustrated parts lists" here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky that week
Gl Lou
Oct 09, 2009 | Husqvarna Forest & Garden No.967012396 345...
How do I change the timing belt on a 2003 Tiburon
2003 Hyundai Tiburon 2.7L MFI DOHC 6cyl
Inspection
Inspect the drive belt for signs of glazing or cracking. A glazed belt will be perfectly smooth from slippage, while a good belt will have a slight texture of fabric visible. Cracks will usually start at the inner edge of the belt and run outward. All worn or damaged drive belts should be replaced immediately.
Removal & Installation
  1. Raise and support the vehicle.
  2. Remove the engine splash shield.
  3. Rotate the drive belt tensioner clockwise to release the drive belt tension.
  4. Remove the drive belt from the alternator.
  5. Slowly release the drive belt tensioner.
  6. Remove the drive belt from the accessory drive pulleys.
To install:
  1. Install the drive belt to the accessory drive pulley.
  2. Rotate the drive belt tensioner clockwise.
  3. Install the drive belt to the alternator.
  4. Ensure the drive belt is properly aligned and seated into the grooves of the accessory drive pulleys.
  6. Install the engine splash shield.
  7. Lower the vehicle.
Fig. Accessory drive belt routing-3.0L and 3.5L engine
Fig. Accessory drive belt routing-2.5L and 2.7L engines
Fig. Accessory drive belt routing-2.4L engines
Fig. Accessory drive belt routing-2.0L engines
Fig. Accessory drive belt routing-1.5L engine
Fig. Accessory drive belt routing-3.0L engine
Fig. Accessory drive belt routing-2.5L engines
Fig. Accessory drive belt routing-1.8L and 2.0L engines
I hope help you with this (remember rated this help) Good luck.
Sep 15, 2009 | Hyundai Tiburon Cars & Trucks
Belt Replacement on Husky Q26 Air Compressor
YOU HAVE TO TAKE COVER OFF LOSEN THE BOLTS ON THE MOTOR SO THE MOTOR SLIDES TO THE RIGHT SO THEN PUT THE BELT ON THEN GET A CAR JACK AND PUT BETWEEN MOTOR AND PUMP DO THE JACK UP TILL BELT GETS TIGHT AND TIGHTEN BOLTS UP ON MOTOR X4 GOOD LUCK
Aug 25, 2009 | Air Tools & Compressors
I need a new belt for my Husky air compressor but I don't know
This is a simple way to replace your belt without the old one for comparison. Use a piece of rope thick enough to fit inside the pulley, (cloths line works well). Simple wind it around the pulleys marking where the two ends meet. Cut and measure it. Take the piece of rope and measurement to a auto parts store and ask them to match it up. An automotive belt will work fine.
If this is a flat belt they should still be able to help you.
Aug 07, 2009 | Air Tools & Compressors
Need a belt diagram for a husky 42 inch riding
If you have your model number and serial number handy, then enter both here to view available manuals.
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10451
I hope this helps.
DROPNDEAL
Jul 19, 2009 | Garden
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
