Question about Amana Washing Machines
The wash machine will not start the door seems to be stuck
    New Friend:
  • 6 Answers
The wash machine will not work unless the door is closed and locking is engaged.Check door lock something may have broke !!
Posted on May 02, 2015
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
My washing machine started as usual, but after going to empty the machine it seems to be stuck in the spin cycle. Any ideas? Can the machine be reset?
Have you tried unplugging the power and leaving it unplugged for a few minutes to try and reset itself? If that doesn't help then please provide the model number - should be located on the door somewhere.
Sep 16, 2014 | Maytag Washing Machines
The locking mechanism seems to be stuck on my Frigidaire front loading washing machine. When the door is closed it buzzes and machine won't start.
Hello Craig, thank you for your post!
I understand that the door lock on your washer is stuck and washer will not operate. Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately 2 minutes and turn on the washer. Select a normal cycle and verify if the washer will start. If your washer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Thanks for allowing me the opportunity to assist you!
Oct 27, 2013 | Frigidaire Washing Machines
Opening the door after a wash
Turn program selector to "off". Turn selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
Press "start / pause" until the start / pause light flashes.
OR
First, unplug the machine and turn off the water supply. On the lower right of the front panel is a 6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Pl click if helped.
Mar 18, 2013 | Bosch Logixx WFT 2806 Front Load...
The washing machine seems to have stopped during it's cycle ad the door light has come on, now it is stuck with the door light on and I'm not able to reset it, change functions, start a wash,...
From your desciption it seems to be indicating that there is a problem either with the door lock or more likely the door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 19, 2011 | Electrolux Washing Machines
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Jul 11, 2009 | LG Washing Machines
Washer stuck
i am assuming that water comes in at the start of cycle and machine does not then progress. Points to a timer fault unfortunately. These timers are expensive and quite hard to fit. don't recommend repair in view of age of appliance.
honestly can't see how related to sock problem
Jun 26, 2008 | Washing Machines
Kenmore Front Loader stuck in "LOC" and every button produces "ERR"
Look for the 2 buttons on your that have a lock symbol.  Pushing & hold both for 3 seconds.  This toggles the child proof mode.
Nov 20, 2006 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
52 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Terry Schneider
Mike
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
