Question about Saws
How do I change the blade on a Ryobi electric miter saw
    New Friend:
  • 6 Answers
Remove centre bolt on blade anticlockwise.Blade will have to be stopped from rotating.Blade will slip out of carrier.NB note direction of blade for refit.
Posted on May 02, 2015
How can I fix a jammed Ryobi miter saw blade?
Probably go a piece of wood between black and safety cover. Unplug from power before checking
Apr 30, 2014 | Ryobi 18 Volts Cordless Miter Saw 18v P551
Ryobi mitre saw jamming when cutting
There's a normal adjustment process of squaring the blade to the table, page 19 of your manual. If the blade is not square to the table then it will bind. Here's the link for the manual, see page 19.
http://manuals.ryobitools.com/system/files/400/original/TS1342_942_eng.pdf?2011
Dec 21, 2013 | Ryobi ZRTS1342L Factory-Reconditioned 14...
I have the blade bolt off of my ryobi miter saw but the blade wont come off of the spindle
tap the blade on the back side to loosen it off. The wood sap has probably dried out and is acting like a glue on the back flange washer.
Feb 13, 2013 | Ryobi ZRTS1342L Factory-Reconditioned 14...
12'' Ryobi miter saw with loose blade
You may need to use lock tight on the threads. Also replace the standard washer with a lock washer if possible.
Mar 12, 2009 | Saws
Loose replacement blade
I completely removed the blade and put it back on, tightening the locknut, and now it works perfectly. The blade has not come loose and have used the machine for the last 3 months. The only thing I can think of is that somehow I didn't have the blade correctly installed in the first place, although it didn't wobble or anything.
Jan 25, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Changing the saw blade on a Ryobi Mitre saw
There may be a push button type blade lock, and on many of these saws the retaining bolt for the blade is backwards threads, e.i., looking at the top of blade retaining bolt, turn it clockwise to loosen. This would normally tighten, but in the case of many of these saws, it loosens it.
Jan 04, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
How do I remove the guard?
Lift the guard up and you will see a nut holding the blade. You should not have to remove guard to change blade. Make sure unit is unplugged before working on it.
Dec 24, 2008 | Ryobi ZRTS1342L Factory-Reconditioned 14...
RYOBI TS254 change saw blade???
should have blade lock button remove blade with proper size wrench reinstall new blade in reverse remember some of these the loosening of the blade will be clockwise so if nut dont come loose try clockwise to loosen good luck
Apr 22, 2008 | Irwin Miter Saw Laser Guide Attachment...
Saws Logo
591 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
